      09-11-2016, 12:55 AM   #419
XXX5
Drives: 2014 X5 F15 50i M Sport
No, nothing in there. All the noises are creaking and rattling hard plastic type noises.
      09-25-2016, 10:38 PM   #420
admranger
Retired Curmudgeon
admranger's Avatar
Drives: ‘19 X3M40i
I get what sounds like the old engine knock sound when accelerating uphill in normal setting on the 40e. I'm not lugging it (shouldn't it downshift) but more mid-throttle acceleration from a steady 35mph or so. X accelerates, but the sound is so pre-knock sensor era cars it's odd.
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS
Diper46.50
      09-26-2016, 03:44 PM   #421
spike5150
Drives: 2020 X5 M50i
Originally Posted by F15GorDe View Post
Re-initialize your rear window,(hold the button up for 11 seconds).
Unfortunately this did not solve the problem. Tried it with car running, then power on only. Tried rear window switch and drivers switch for rear window.
      09-26-2016, 03:49 PM   #422
F15GorDe
F15GorDe's Avatar
Drives: F15d, F10
Sorry that didn't work.
I haven't tried it on anything newer than the early 2000's.
Was worth a shot.
      09-26-2016, 10:22 PM   #423
spike5150
Was worth a shot.
I appreciate the help. Will just have to let the dealer sort it out. Minor annoyance right now.
      09-26-2016, 11:07 PM   #424
F15GorDe
F15GorDe's Avatar
Drives: F15d, F10
Would be nice to know if the solution doesn't require being plugged into the computer.
      10-09-2016, 09:31 AM   #425
XXX5
Update, dealer worked on it and almost all of the noises are now gone. Time will tell if it stays this way but I am much happier now.
      10-09-2016, 08:17 PM   #426
chanoo749
Drives: 2015 BMW X5 s35i
Experiencing rattling from dashboard,
Took it to dealer but "no issue found" as always...
Before it was green but after performing engine oil level, it turned to red....
Tool it to dealer, performed engine oil change at 7,000 miles...
      10-23-2016, 01:23 PM   #427
flexfusion
Drives: 2016 F15
Great Car
I'm a shame they got the steering wrong....BMW management should fire every member on this team. They screwed up a perfectly great SAV.
lofrese1264.00
      10-28-2016, 01:16 AM   #428
Baunton
Baunton's Avatar
England
320
Drives: X5 45e 2021
No Time displayed
Has anyone had this as an issue before;
In the winter I always set my Auxiliary Heating to on before I leave home.
Got in the car this morning and it was cold. I thought maybe I had forgotten to set it the night before so I checked the settings display in iDrive and there was no time selected....my clock has no time..my sat nav said I was not going to arrive at my destination and the trip display had zeroed out!
I went into settings and time/date on the menu and ticked the auto UTC box.
Everything then re-set itself for the correct GMT +1 time...VERY ODD
Mr.Raj3.00
      10-29-2016, 08:48 AM   #429
lofrese1
Drives: BMW F90 M5
This has happened to me too.
I would guess from the vehicle sitting overnight the heater core turns cold and just blows out cold air since the vehicle is not running.
I would say if the vehicle set just for a couple of hours there would still be some thought of heat left in the heater core. But for sitting overnight I would think not.
Baunton319.50
      10-29-2016, 08:50 AM   #430
lofrese1
Drives: BMW F90 M5
I agree the steering feel is somewhat numb in the F15.
But with the DHP fitted to the F15 in sport mode really does do a good job of making you feel more connected to vehicle.
      11-16-2016, 11:59 PM   #431
kanvas
kanvas's Avatar
Drives: V8
CHECK ENGINE LIGHT is on
Car settings in iDrive says all systems are OK, however.
2014 X5 xDrive50i
      11-17-2016, 12:38 AM   #432
Almaretto
Almaretto's Avatar
2376
Drives: Test Vehicles
For how long?
      11-17-2016, 11:28 AM   #433
kanvas
kanvas's Avatar
Drives: V8
Originally Posted by Almaretto View Post
For how long?
Two days so far..
2014 X5 xDrive50i
      11-17-2016, 12:57 PM   #434
Almaretto
Almaretto's Avatar
2376
Two days so far..
I would scan car with ISTA+. Usually if false positive, then CEL goes away after half a day.
kanvas649.00
      11-17-2016, 08:05 PM   #435
kanvas
kanvas's Avatar
Drives: V8
Thanks for the advice. I'll maybe get an OBD II scanner. Or maybe I'll take it in to the dealership ASAP but they'll probably ask around $100 for labor
2014 X5 xDrive50i
      11-17-2016, 08:18 PM   #436
Almaretto
Almaretto's Avatar
2376
ISTA+
kanvas649.00
      11-22-2016, 12:13 AM   #437
Wing Co
Germany
239
Drives: BMW M135i & 911 GTS
Car had first service after 22 months and only fault is the rear hatch motor has given up and now only opens by hand. New part ordered and to be fitted but it takes a day as the car has to be updated when it is replaced (I didn't even bother asking why!).
PS: Started working today, but AD said bring in and they'll change motor anyway - 21 Dec.
      11-25-2016, 05:10 PM   #438
whapslim
Drives: 17 X5 35i MSport
At 700 miles my driver's side seatbelt assembly decided to jam and wouldn't pull out of side pillar. Dealer ordered a new kit and replaced it. Other than that, all good for the first 2,000!
      12-03-2016, 09:44 PM   #439
admranger
Retired Curmudgeon
admranger's Avatar
Drives: ‘19 X3M40i
I'm getting a creaking noise every time I turn the car on. HVAC vent moving internal to the dash I guess. I'll let the dealer worry about it at the first oil change.
      12-06-2016, 06:25 AM   #440
pragueX5
pragueX5's Avatar
Czech_Republic
157
Drives: 2021 X5 M 40d mildhybrid
1. FAULTY A/C
TWO instances where the A/C (on highest setting) was loud but barely any air came out. Both occurred during the summer, 90F weather. It self-fixed by turning off the car and letting it sit for a bit before starting up the car again.
2. MOOD LIGHTING
For a while, the mood lights that go around the cabin and the rear seats changed colors on its own (not while driving); I realized this every time I started the car. One day, it's red. The other day, blue. It has stopped doing that for a while, however.
3. LED LIGHTS
ONE instance where the LED ring lights (?) didn't turn on when unlocking the vehicle with the key fob. A little bit of driving around fixed (?) the problem.
4. WIND NOISE
Please let me know if this is a common problem among F15 owners, but while driving at freeway speeds (65mph +), I hear wind noise coming from the door seal. This is not normal, correct?
** CURRENT STATUS OF CAR **
Nearly 8,000 miles. Considering that many of the aforementioned issues have not occurred for a while, I wonder if they commonly happened when one breaks in the car.
Hi, did you get the WIND NOISE sortet, I have a2016 car and it still does it!!! so clearly no manufacturing desing fix taken by bmw yet
