| 06-04-2025, 01:11 AM | #221 | |
Rep 23
Yeah I definitely put some thought into removing everything, I generally prefer that route instead of the hack job method. But my car's been down for over a month now (not for this, the delete was a "well while I'm here" thing) and I'm eager to get it back on the road, and didn't want to bother with pulling the bumper to get the tanks out. |
| 06-04-2025, 10:45 AM | #222 | ||
Self Proclaimed Roundel Junkie
816
Rep 1,769
That’s all good info. I would try and go back to plugs and disconnect before cutting. If you can get some, Kroil is a much better penetrant than PB Blaster, but you’ll likely have to go to Amazon to get it. As for the nozzle, I just zip tied it up to a bracket on the side of the trans. Didn’t want it hanging. I’ve since removed the forward tank and SCR module so I might get back in there and try to remove the whole nozzle. You can get the drivers side DEF fill and hoses as well. That tank is integral to underbody splash guard attachment though, so leave that one. Mine was empty so once the hoses were off it, I just left it in place. As mentioned, as much clutter, weight, and dead parts were removed as possible. Good luck. 👍🏻👍🏻
2013 E82 1M3 - Carbon Black/Black S65/DCT Track Toy
2018 F15 X5d - Carbon Black/Nutmeg Individual Oil Burner Tow Rig 2021 G07 X7 M50i - Tanzanite Blue/Ivory White & Night Blue German American Family Rig Former Family: '13 F25 X3 35i, '11 E91 335is, '11 E90 M3, '10 E70 X5M, '14 F30 328d, '03 E46 330i Dinan3 ZHP, '04 E46 330i ZHP, '12 F25 X3 35i |
| 06-04-2025, 10:47 AM | #223 | |
816
Rep 1,769
| 07-24-2025, 11:29 AM | #224 |
Rep 246
Drives: F15 - 2018 BMW X5 35d - Stock
Last week switch from Tunezilla Stage 1 to Stage 2 tune. Exhaust plumes are easily doubled to triple even though only went up in HP by 20. Noting this to see if anyone has this going on wasn’t expecting this much more exhaust cloud especially between 3500 and 4500 rpms. I wonder if it isn’t getting enough air. Entire back of car has layer of dust after a dew days.
| 08-07-2025, 12:28 AM | #225 |
Rep 760
believe this is normal. Mine gets dirty after 3-4 days, noticeable around exhaust exists. But, I don’t roll coal unless I floor it. And it only happens for about 2-3 seconds.
Also wanted to share since I decided to upgrade my exhaust manifold. Loving my SAV even more now. |
LateParty2018X535d166.00 BreakMyWallet4.00 |
| 08-09-2025, 11:28 PM | #226 |
Rep 12
Drives: 2011 335d M-Sport
Good evening, where did you get that header and did it require additional tuning. Also can anyone offer some help with the bimmertune egr delete, I can figure out what hardware that came with the kit is used to plug the very rear coolant line on the back of the block.
| 08-10-2025, 07:15 AM | #227 | |
![]() 47
Rep 61
On the back of the block, use what looks like an oil drain plug from the kit. If you email Bimmertune, he’ll respond with more detailed pics. |
| 08-10-2025, 09:54 AM | #228 |
Rep 760
I got it from Europe. It’s made when ordered, so you have to wait just under 8 week to have it delivered. Check it out at https://www.stopping-power.co.uk/pro...ubular-manifol And yes, you need a tune for it or you’ll get a CEL. Last edited by XxBBVTMxX; 08-10-2025 at 08:21 PM.. |
LateParty2018X535d166.00 |
| 08-20-2025, 11:15 PM | #230 | |
Rep 760
Your engine designation is N57D30A, and you purchased the wrong delete kit. This is the one you need for your engine variation… https://tafmet.pl/english/en/egr-val...553475692.html Last edited by XxBBVTMxX; 08-20-2025 at 11:33 PM.. |
DrHarryX53.00 |
| 08-30-2025, 08:58 PM | #231 | |
Rep 246
What does this upgrade do exactly? |
| 08-30-2025, 09:32 PM | #232 |
Rep 760
| 08-30-2025, 09:40 PM | #233 | |
Rep 246
Switched from Stage 1 to Stage 2 recently and really enjoying it, had some potentially serious problems but got em sorted because added a high flow air intake that required MAF sensor scaling/programming and got all kinds of limp mode and rail pressure low warnings, plus exhaust cloud way too much, but fixed it with going back to stock but had to do engine adaptations reset used AI help. Something else to consider: I added the Darkside Intercooler- kept that highly recommend. Slightly firmer acceleration performance gains IDK but def peace of mind with IATs confirmed 25 to 60 degrees lower than before (I ran a ton of bimmerlink logs). Thx for this.. How did you get it tuned? Unfortunately my tunes from tunezilla are off the shelf so not sure of who to go to to get fun add ons like this tuned. Last edited by LateParty2018X535d; 08-30-2025 at 09:41 PM.. |
| 08-30-2025, 09:44 PM | #234 |
Rep 760
I got all my stuff from Darkside. Tunezilla for tune. I had zero issues with my tune. If your vehicle is tuned, you’re good to put on an aftermarket exhaust manifold.
What air intake you have that you had to calibrate MAF? Last edited by XxBBVTMxX; 12-29-2025 at 07:05 PM.. |
| 08-30-2025, 09:54 PM | #235 | |
Rep 246
https://www.darksidedevelopments.co....for-x5-x6.html https://www.darksidedevelopments.co....ction-kit.html Last edited by LateParty2018X535d; 08-30-2025 at 09:55 PM.. |
XxBBVTMxX444.50 |
| 08-30-2025, 10:02 PM | #236 | |
Rep 246
Used Bimmerlink logs a ton, ran tests, fed data into AI for analysis and did again and again until confirmed fixed. Amazing Last edited by LateParty2018X535d; 08-30-2025 at 10:03 PM.. |
XxBBVTMxX444.50 |
| 09-08-2025, 07:00 PM | #237 | |
Rep 11
Also, the kit you linked to isnt the one suitable for the N57 with the transcooler. That kit has no connector pipe for the transmission lines To answer my own question, you do not need to blank the port with anything as it only communicates to the EGR port on the front of the engine which has already been blanked off. In the end I decided to keep the transcooler so it wasn’t an issue in the end. |
| 09-09-2025, 03:17 PM | #238 |
Rep 760
I don’t understand anything you wrote. To receive better help from the community, post on the correct forum. ✌🏽
| 09-18-2025, 06:03 PM | #239 | |
Rep 1
| 09-28-2025, 09:42 PM | #240 | |
Rep 246
Tempted to delete muffler for more sound but have a feeling too much for my taste in luxury car… header could be sweet though… Also I didn’t like the3” performance air induction pipe and too many error codes, turbo whistle too much over engine but did get a performance air filter… seems nice/very modest sound and response gain maybe. Last edited by LateParty2018X535d; 09-28-2025 at 09:52 PM.. |
| 09-28-2025, 09:49 PM | #241 | |
Rep 246
Did a reset of engine adaptations and kept running tests and exhaust clouds went away while parked and revving engine basically none. Now just a sweet plume at mid to full load or launch which is fantastic for many reasons. Look into adaptations reset and see if that’s a good idea… let us know what you find! Edit: also I didn’t have that much exhaust at idle. If reset doesn’t work consider adding Diesel oxidation catalyst to down pipe (I believe that’s where it goes) Last edited by LateParty2018X535d; 09-28-2025 at 09:51 PM.. |
| 10-03-2025, 06:32 AM | #242 |
Rep 760
No, unfortunely I don’t have a sound clip. And these days have been crazy windy so it would be difficult to make one right now.
I have all new piping, DPF downpipe delete and the resonator that Darkside sells, and a new less restrictive muffler from vibrant with dual exhaust tips. |
| Bookmarks |
