05-20-2024, 07:24 AM | #23 |
Rep 156
05-20-2024, 08:34 AM | #24 |
Rep 196
I installed Eibachs last weekend, not happy with the drop - doesn't look like it changed at all. Having to remove the front axle was a nightmare also.
05-20-2024, 08:36 AM | #25 |
Rep 156
05-20-2024, 04:16 PM | #26 |
Rep 3,703
Surprised you didn’t notice, it’s not super aggressive but it’s a full inch drop in front and .6 in the rear, it was definitely noticeable to me. No real settling time either, I measured before & right after install.
05-21-2024, 02:25 PM | #27 |
Rep 259
I wonder if some x5's have more worn out springs than others, so sit lower? My 50i looks like it has a good stance on the stock springs but I do plan on getting the Eibach's because one of the rears is broken, and the Eibach from what I understand is the least aggressive?
05-21-2024, 03:28 PM | #28 | |
Rep 3,703
05-21-2024, 04:27 PM | #29 | |
F15 daddymobile
2420
Rep 3,573
check out the spring pic here: https://f15.bimmerpost.com/forums/sh...9&postcount=26
05-21-2024, 05:34 PM | #30 | |
Rep 3,703
05-22-2024, 02:12 PM | #31 |
Rep 28
The “European” version of the Eibach kit includes the rear springs. You will need a few other parts to install the rear springs.
I purchased the kit a few months ago to lower the front and have the rears on stand-by in case I had issues with the rear air springs and wanted to switch. Has anyone removed/coded the chassis function restricted warning message?
2013 335i xdrive (pwg): BMW MPE, BMS Chargepipe, BMS Wheel Spacers 10/12, BM3 tune, M performance Calipers, Qi wireless charger, Bilstein B4 EDC suspension, Eibach Pro Springs + F80 bumpstops, Zimmermann Formula F rotors, Active Autowerke FMIC
05-22-2024, 07:25 PM | #32 | |
Rep 156
I’ve wondered this too. I’m assuming my oem springs were still solid, because I did notice a drop on mine. |
