06-30-2014, 11:11 AM | #67 | |
Rep 5,262
Start directly into sport plus?
No Make the crash warning assistant thing not be on on startup? Haven't looked into it cause i don't have Driving assist plus Default to auto start stop being off? Yes. But you should have default to last setting already... which is basically the same... if you leave it of it says off.... if you leave it on it stays on Quote:
06-30-2014, 11:27 AM | #68 | ||
Rep 2,384
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
06-30-2014, 03:12 PM | #69 | |
Geboren zu Fahren!
12
Rep 376
Drives: F25 X3
Have it on my X3 and use it often.
2011 F25 X3 2.8 (in service)
2009 E90 328i (retired) 2007 E92 335i (retired) 2005 R53 MINI Cooper S (retired) 2002 E53 X5 3.0 (retired), 1999 E46 328i (retired) |
06-30-2014, 03:17 PM | #70 | |
Rep 5,262
I'll removed it from the sheet if it doesn't work... i put it cause i saw it was comfirmed to work on other models edit: actually i forgot to code it.... i'll do it tonight and let you guys now... i think should show "weather" under AM FM etc Last edited by pikcachu; 06-30-2014 at 03:27 PM.. |
06-30-2014, 03:48 PM | #71 | |
Geboren zu Fahren!
12
Rep 376
Drives: F25 X3
I'll post a pic of my X3 screen later tonight, if needed. This would be interesting, as then the FM receiver has the capability to receive 162.xxx MHz, which previous generation BMWs have had on most their models. Only the recent 1 & 3 models did they start dropping it.
06-30-2014, 05:23 PM | #72 |
Geboren zu Fahren!
12
Rep 376
Drives: F25 X3
Here are a few pics from my X3 in the iDrive menu:
06-30-2014, 09:09 PM | #73 | |
Rep 5,262
You can see how the low beam goes back to the left when high beam is off and goes back to the middle when high beam turns on |
06-30-2014, 09:25 PM | #74 |
Rep 5,262
07-01-2014, 11:22 AM | #75 |
Geboren zu Fahren!
12
Rep 376
Drives: F25 X3
Bummer.
07-05-2014, 09:57 PM | #76 | |
***** noob
1380
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Any pics?
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
07-06-2014, 07:20 AM | #78 | |
***** noob
1380
Rep 10,479
2006 325xi (Sold)
07-12-2014, 04:33 PM | #81 |
Rep 49
did my coding the other day but hadn't had a chance to come back and post. i can confirm that MAPPING_SIDEMARKER_L_OUTPUT and MAPPING_SIDEMARKER_R_OUTPUT both are working if you want to update the spreadsheet.
one issue that i am having is with CLM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK which is supposed to unlock the doors after turning the engine off. for some reason it is only unlocking my driver side door and not the passenger side. can anyone confirm whether it is supposed to unlock both doors or not? seems kind of pointless if it's only going to unlock the driver side. |
07-12-2014, 07:34 PM | #82 | |
Rep 1,040
07-12-2014, 08:01 PM | #83 |
Rep 5,262
07-13-2014, 09:20 PM | #84 |
Rep 176
I have done coding many times and successfully coded many features.
However, today, I wanted to code something else but couldn't manage to do it. The mapping of ECU doesn't match anymore with what I have on my excel file. For example look what I get for the FEM Body. Any idea how to fix this? |
07-13-2014, 11:08 PM | #86 | |
Rep 5,262
07-14-2014, 11:23 AM | #87 |
Rep 176
My FEM Body doesn't match the spreadsheet.
For example, I used to activate the feature "close windows with FOB". In the spreadsheet, I must find the line 3053 KOMFORTSCHLIESSUNG_FB But if you look at my sprint screen, the line 3053 doesn't match anymore. |
07-14-2014, 11:50 AM | #88 | |
Rep 49
another note, as has been mentioned in regards to the F30 BC_V_KORREKTUR does not seem to be working. the speedometer still reports ~3 mph faster than what the waze app reports my speed is. while not a standalone gps unit it does match what we get in our other car so i assume it is accurate. |
