02-04-2023, 06:57 PM | #24 |
Rep 117
02-04-2023, 07:01 PM | #25 |
Rep 4,106
02-04-2023, 07:07 PM | #26 |
Rep 117
Same here. And in the interest of a proper review, I've also been paying closer attention to handling on current bags under a lot of different conditions and in all 3 suspension modes, to really keep the before characteristics in mind. I'll try to replicate as best I can with the new bags.
02-06-2023, 03:32 PM | #27 |
Rep 117
So, brief first impressions are very good! They installed very easily, and didn't leak overnight. I didn't have leaks before either, but it means install was correct. So far I've mostly only driven in traffic, but I did get to open it up and also take some exit ramps pretty hard. They definitely feel better and firmer, in a good way. Not at all harsh just feels more solid. The rear feels like faster responses. I didn't have much bounce at all before, and I seem to have even less. The exit ramp felt really good, flatter than the stock bags. I was surprised how different they looked. The Bilstein rubber felt much better. And I had to pull the stock bag and extend it to see where the top clamp was. The Bilstein it's always visible, and also not in a fold like stock. And the diameter at that top clamp was a LOT bigger on the Bilstein. I wish I remembered to measure the diameter, but it's significant, as seen in the pic. I will try to get some more driving tests later or tomorrow and update more. But so far it's a good impression. |
02-06-2023, 04:13 PM | #28 |
F15 daddymobile
2350
Rep 3,510
When you say "the rubber felt much better," what do you mean? like it felt thicker? or more pliable?
02-06-2023, 04:25 PM | #29 |
Rep 117
02-08-2023, 04:10 PM | #31 | |
Rep 117
So, I still haven't had a chance to drive that much, but impressions are still good. Not as dramatic of an improvement as I hoped and wanted, but more than I expected, if that makes sense. I was afraid they would be no different, or worse, softer. Went over some rail tracks and it felt solid. Squat on hard acceleration is reduced, and that was one of my goals. And the rear feels less soft around turns and bends, also a goal. I still want to get some higher speed tests, especially with some dips in the highway. I think for my preference, it might still warrant a rear Coilover setup and bypass the air system. But since these are similar price, it's nice to have a very good alternative to the Arnott bags, and from a very trusted name like Bilstein. I'd be very curious how someone with stock suspension (not lowered) thinks about them at those heights. |
02-09-2023, 10:39 AM | #32 | |
223
Rep 304
02-09-2023, 10:51 AM | #33 |
Rep 117
The Bilstein measured 9" fresh out of the box. I didn't measure either one while on the car. But the stock measured 7" on the bench after I took them out of the car. The design is different though. The stock one had the top clamp down in a fold. So I had to pull the stock apart a lot to see that clamp. That's what's in the pic. You can see how most of the stock is brown and faded, but the top few inches are still black. That part was down in a fold. I'll see if I have other pics to explain better.
02-09-2023, 10:56 AM | #34 |
Rep 117
Here we go. This was as removed from the car-
And this was after I extended the stock one to see the top clamp - I would be really curious what an oem one measures brand new out of the box. I'm also curious about the F07 5 series GT bags too. Bilstein makes a set for that car too. |
Chilled363.50 |
02-09-2023, 03:09 PM | #35 | |
Rep 4,106
02-09-2023, 04:07 PM | #37 |
Rep 1,019
ENDEE666 Are you able to measure your ride height to fender? I'm on the Arnott's and think am having an issue where overnight they slightly drop and then hold indefinite.
So are you able to measure to the fender flair, after a drive and in the morning? My full thread. https://f15.bimmerpost.com/forums/sh....php?t=1925231 |
02-09-2023, 04:28 PM | #38 | |
Rep 117
The topic here is the ride quality and handling of the different bags. There are an abundance of other threads that discuss leak issues. |
02-09-2023, 04:36 PM | #39 | |
Rep 1,019
02-09-2023, 05:46 PM | #40 | |
Rep 117
Good luck with your issues and your other thread though 👍 |
02-09-2023, 11:26 PM | #41 |
Rep 4,106
02-09-2023, 11:37 PM | #42 |
Rep 117
Definitely an improvement over stock airbags. Especially comfort wise when in comfort mode, and less lean and squat. Once I do some more driving under better testing conditions, I'll update more.
