      03-06-2021, 10:26 AM   #1
Radekxpl
The General
55
Drives: F15 X5 35D & E46 M3
How to activate rear seat leg room lights ?
Does anyone know how to activate these lights? see picture, can't find info on these no where. Any help greatly appreciated.
      03-06-2021, 02:58 PM   #2
The Libertine
The Libertine's Avatar
Drives: 2021 Porsche Macan
Never even knew these existed?
      03-06-2021, 03:24 PM   #3
CatalinP
Drives: BMW X5 F15 2014 3.0xd
Do you have the Lights Package?
      03-06-2021, 05:37 PM   #4
Radekxpl
The General
55
What do you mean by light package ? I have the color under dash light led if that's what's you referring to.
      03-06-2021, 05:39 PM   #5
Radekxpl
The General
55
I'm assuming they need to be coded if anyone can guide where to find this option?
      03-06-2021, 08:07 PM   #6
XxBBVTMxX
XxBBVTMxX's Avatar
So mine come on only when I activate the "Interior Lighting Design". It's a soft white (while vehicle is off) regardless of what color you have activated. Not sure if it matches the color when the vehicle is on.
They turn on anytime you open a door or if you press the dome light button.
Clearly, if yours do not come on and you have the lighting package, then your fiber bar is disconnected from the LED, broke, missing, or the LED is out.
      03-07-2021, 03:27 PM   #7
mrfochon
Drives: X5 F15 M package
Drop the last 7 of your vin we can check for you
      03-07-2021, 11:55 PM   #8
Radekxpl
The General
55
I checked my display and I don't have the same opinions as you do it appears.
      03-08-2021, 01:13 AM   #9
XxBBVTMxX
XxBBVTMxX's Avatar
That's it, it's just written differently because you don't have B&O. B&O center speaker has a light you can turn on, that's why my portion of the menu is different.
After you activate it, check for the lights on. ??
      03-08-2021, 08:00 AM   #10
Radekxpl
The General
55
Yea I have does on and the lights on both seats do not turn on once I open the door or turn on the dome lights. 🤷
      03-08-2021, 08:02 AM   #11
mikeson
mikeson's Avatar
Drives: 2016 X6 M package
Hmmm, mine are on all the time.
Whenever car starts, it stays on until I turn off the car.
Mine is 2016 model.
      03-08-2021, 08:56 AM   #12
XxBBVTMxX
XxBBVTMxX's Avatar
Then you have to check the connector.
Remove the back trim and check it out. Be careful as the LED wire doesn't have a ton of slack for you to pull it out.
Remove back cover, reach up top to unhook the cable, remove completely and check that your LEDs aren't burnt out or that there's something wrong with your fiber glass (crystal that sits above that actually lights up). Only thing I would do.... this should narrow it down.
      03-08-2021, 09:52 AM   #13
blue dragon
Which seats do these come with? My comfort seats do not have these
      03-08-2021, 09:56 AM   #14
XxBBVTMxX
XxBBVTMxX's Avatar
Sport seats.
      03-08-2021, 10:50 AM   #15
CatalinP
Yes, they do...
      03-08-2021, 12:04 PM   #16
Radekxpl
The General
55
Will try that and update my findings, but it's seems weird that both of the seat lights would have this same connection problem, since either one is not working.
      03-08-2021, 12:38 PM   #17
blue dragon
Yes, they do...
https://www.realoem.com/bmw/enUS/sho...diagId=52_3859
Looks like only the sport seats have that back/light
      03-08-2021, 12:54 PM   #18
CatalinP
You might want to check that again using a VIN from a car with comfort seats... I have comfort seats and those light stripes...
      03-08-2021, 01:04 PM   #19
1230vani
1230vani's Avatar
653
Drives: G05 40i LCI
Yes, they do...
2017 model onwards the LED strip was removed. Also the light in B&O door speakers (not tweeters) was also removed. I know because i had a 2015 model (both with B&O and lights package) 2017 also has different water nozzles for front windshield and some other small changes. 2018 you can no longer tilt rear portion of the sunroof.
CatalinP589.50
      03-08-2021, 01:14 PM   #20
blue dragon
I have a MY '17, that would explain why I don't have them.
      03-08-2021, 05:22 PM   #21
devlinsky
Correct, I have them as well with comfort seats. What's weird, they barely glow when they're on - never noticed them before and I discovered them thanks to this topic.
How do I make them brighter?
      03-08-2021, 07:17 PM   #22
XxBBVTMxX
XxBBVTMxX's Avatar
Here you go
https://f15.bimmerpost.com/forums/sh....php?t=1123087
Just turn up your brightened, I just noticed they are on all the time... but I keep my brightness down so you can barely notice them .
