      03-10-2020, 08:06 AM   #1
bizkid72
Drives: Bmw X5 Xdrive40e
Export X5 Xdrive40e
Hi.
I’m interested in buying a BMW X5 XDrive40e and import it to my country.
Question: Previous cars I have imported have been from Canada, where everything is in metric (when it comes to instrumentation), does the BMW X5 eDrive40e, have option to change settings to metric instead of Imperial (Celcius, Kilometer, etc.)
Rene
      03-10-2020, 04:56 PM   #2
corduroy
Drives: '16 X5 xDrive40e (F15)
I can change it from miles to kilometers and other metric measurements. Settings, Language/Units and the settings are there. Only the analog portion of the speedometer still lists Miles (kilometers in smaller font). If you convert to the full digital speedometer, I think it'll have everything in metric displayed.
Edit: not sure if the Canadian version will list the metric speed in a larger font than miles on the analog speedometer.
      03-10-2020, 11:24 PM   #3
sj22
Drives: 14 F15 50I
Just get a 6wb.
      03-11-2020, 12:06 AM   #4
Kraftwerk AG
Kraftwerk AG's Avatar
460
Drives: Mein F Fünfundachtzig Einhorn
Originally Posted by bizkid72 View Post
Hi.
Rene
Check with Taatsi He just imported one from Canada to your country. https://f15.bimmerpost.com/forums/sh....php?t=1699816
“Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
― Jeremy Clarkson
      03-11-2020, 01:52 AM   #5
gwes
Drives: 2017 X5 40e
6WB isn’t compatible with the 40e.
If you have a HUD then that’s where you’ll see MPH, otherwise the cluster is only in metric (Km/h).
      03-11-2020, 11:54 AM   #6
-c-
-c-'s Avatar
Drives: bmw
From what I heard you can do the mod but your battery information and battery percentage won't be available.
Otherwise it will work as normal.
      04-01-2020, 10:52 AM   #7
Taatsi
Greenland
14
Drives: BMW X5 F15 and X5 E53
My 40e from Canada had metric cluster and i used bimmercode to change to metric. cluster and idrive language can also be changed to danish etc.
      04-01-2020, 11:01 AM   #8
gwes
Drives: 2017 X5 40e
You used bimmercode to change the cluster to mph? How does the speedometer work?
      04-01-2020, 01:04 PM   #9
Taatsi
Greenland
14
the cluster were already on km/h. i believe most bmw in Canada already shows km/h printet in cluster. the digital speed and also temperature can be changed with bimmercode
      04-09-2020, 07:39 AM   #10
gwes
Drives: 2017 X5 40e
Okay, you don’t need to use BimmerCode to change that, it can just be done in iDrive under units.
