01-26-2021, 08:41 AM | #1 |
Rep 30
Chassis Stabilization: Drive moderately - Error message
2014 X5 35D
I raised the car to do transmission work, replace the filter/pan and ZF ATF oil. To access those 3 bolts on the back of the pan, I jacked up the transfer case about 1 inch. After the job was done I was greeted with that message (Chassis Stabilization: Drive moderately) Now I am not sure if I broke any plug or any connector from the transfer case motor. I tried resetting the system by using software but I was not successful. Any insight? I had no issues at all before raising the truck to work on. This is driving me nuts omg! Thanks, folks |
01-26-2021, 10:17 AM | #2 |
Rep 165
Prob you got the code when you were working on the car... try to clear the code using a obd2 device so the computer could reset or try to leave the car locked and walk away for 30 minutes so the computer could hard reset by itself.
Good luck! |
01-26-2021, 12:48 PM | #7 |
Rep 30
01-26-2021, 01:44 PM | #9 |
Rep 30
Cross member
01-26-2021, 03:48 PM | #10 |
Rep 79
You are correct. This is the tool I meant.
01-27-2021, 03:56 PM | #12 |
Rep 6
Chassis stabilization error
I as well get that same error on occasion. Started a couple weeks ago. Along with that error, also came the
Parking Brake Reduced error as well. Not sure if these two are related or not. Indy shop quoted $1,700.00 to replace parking brake module and register it. Couldn't give me an answer on the chassis stabilization error though. Thought it was a low voltage battery issue but that turned out not to be the case. ?? |
01-27-2021, 07:18 PM | #15 |
Rep 165
Hey sorry to go off topic here but I'm amazed that you're getting 600 miles on your X5! I know it's because you have a diesel but WOW! I only get around 300 to 400 miles max.
01-27-2021, 08:14 PM | #16 |
Rep 6
No sir, I don't have a code reader. I'm new to the BMW world. Bought this '15 X5 35d used in '19 with a little over 50k miles. Only issue I've had was a warranty emission component that the dealer replaced last month. Now these issues are driving me crazy. Do you have a good code reader recommendation for a DIY guy like myself? I hate paying the insanely high diagnostic fees at the dealership. I've done the routine maintenance, air/oil/ and fuel filter changes, DEF filling, brakes, rotors and sensors. Transmission fluid arrive is coming next, I assume I'll need some kind of code reader/computer to read fluid temps.
01-27-2021, 08:16 PM | #18 |
Rep 6
That was my main reason for buying the diesel. Hella good fuel economy. Long highway trips it sees 31-32 mpg,. Average driving town and highway is 28 mpg consistently.
01-27-2021, 10:38 PM | #19 | |
1644
Rep 2,995
Look up bimmerlink and bimmercode. Easy to use. And if you want to get more details and diagnostics, look up ISTA. What did you do to the transmission? Just change pan and fluid? You top off the fluid with the engine running? |
01-28-2021, 07:15 AM | #20 |
Rep 6
I look into bimmercode and bimmerlink. I haven't done anything to the trans yet, it's on the to do list after sorting out this chassis stabilization error and parking brake error. Is anybody else other than me and the original poster on this topic experienced this? If so what was the solution?
01-28-2021, 10:00 PM | #21 |
Rep 29
I had the same error come up on mine. A year or so ago. It happened after I replaced my battery. https://www.bimmerpost.com/forums/sh...php?p=25365374. Might not be the same issue but got the same error. Just a thought
01-28-2021, 10:27 PM | #22 | |
Rep 2,527
https://f15.bimmerpost.com/forums/sh....php?t=1683268 https://f15.bimmerpost.com/forums/sh...1432532&page=3 |
