12-18-2007, 06:21 PM | #1 |
For the love of ///M3
4
Rep 16
E92 M3's top speed?
hello
i have a question for everyone i know that e92 m3's top speed up to 155 mph with electronic limited E92 M3 WITHOUTs electronic limited, what it will be top speed? more than 200 mph? |
12-18-2007, 06:23 PM | #2 |
Reincarnated
245
Rep 4,227
12-18-2007, 06:41 PM | #3 | |
91
Rep 388
Drives: e46 M3, e46 M3 CSL
Best regards, CSL Last edited by CSL-Fanatik; 12-18-2007 at 06:56 PM.. |
12-18-2007, 06:44 PM | #4 |
Rep 10,407
12-18-2007, 06:59 PM | #5 | |
Rep 10,407
Tire diameters are: std. calculation: Without tolerances: [(265 x 0.4) x 2 + (18 x 2.54)] * pi = 2.10 m Michelin website: 63,360 divided by revolutions pre mile = rolling circumference in inches: For the 265/40ZR18 PS2 Michelin states 790 revs per mile so 63,360 / 790 = 80.202 inches = 2.037 m. Keep in mind that simply a new tire vs. well worn tire would make more of a difference than these variations as well! |
12-18-2007, 07:10 PM | #7 |
Rep 147
12-18-2007, 07:50 PM | #8 |
Commander-In-Chief
2206
Rep 8,949
Drives: 2023 M2 Coupe, 2020 GLE 450
Top speed
That sounds about right. The E46 was just around 170.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
12-18-2007, 11:52 PM | #9 |
4
Rep 16
12-19-2007, 04:12 AM | #12 | |
Moderator / European Editor
1552
Rep 6,754
Best regards, south |
SG-GM13.50 |
12-19-2007, 04:31 AM | #13 |
Rep 8,027
As I has said already else where on other threads, that when the M-DCT box arrivals with it's 7 gears the M3's topspeed WILL increase and the gearing will NOT be set up so that it's 7th and the manual's 6th will be the same.
The circumference as South states will actually be small due to the weight of the car compressing the bottom of the tyre slightly and so reducing the actual speed. |
12-19-2007, 08:20 AM | #16 |
Commander-In-Chief
2206
Rep 8,949
Was this with GPS speed measuring? German speedometers ar notoriously optimistic.
12-19-2007, 08:24 AM | #17 |
Commander-In-Chief
2206
Rep 8,949
Sure, it has up to 360 hp.
12-19-2007, 09:55 AM | #18 |
Rep 8,027
I have known V8 S4s and Mk1 RS4s which have been reaching speeds in excess of 170~175mph so I wouldn't doubt that the CSL could reach over 180mph, the same goes for the new M3 but there is a big difference between achieving 180mph and over 200mph.
12-19-2007, 10:16 AM | #19 |
Rep 563
Drives: 2007 E92 M3
If the top speed is drag/power dependent, you will most likely need a lower ratio for the DCT to be faster.
12-19-2007, 10:23 AM | #20 |
Commander-In-Chief
2206
Rep 8,949
Top speed gearing
I believe top speed in the E46 M3 is achieved in 5th. A closer ratio 7-speed would give you the option of 5th or 6th.
12-19-2007, 10:26 AM | #21 |
Rep 1,243
An E46 M3 without a limiter on it would struggle to do more than 170mph +- 4 mph. Back in the day mine would hit an indicated 165 and stop but BMW's have speed errors of up to 10% in the speedometer. (I have a letter for BMW NA about this). So if you state going 170mph you could only really be doing 153 MPH which is feasible.
12-19-2007, 10:29 AM | #22 |
91
Rep 388
Here are the M3 gear Ratios
Final Drive 3.64:1 1st Gear Ratio 4.23:1 2nd Gear Ratio 2.53:1 3rd Gear Ratio 1.67:1 4th Gear Ratio 1.23:1 5th Gear Ratio 1.00:1 6th Gear Ratio 0.83:1 red line is 8,400 rpm as you guys know. Best regards, CSL |
