12-27-2007, 09:50 AM | #1 |
Rep 289
First Service Big Unexpected Bill!!!
So, I'm driving down to the dealer in anticipation of my first service (and also the top-spec X5 they were lending me for 3 days - I wasn't going to wait for the service to be done) and I get a 2 inch nail stuck in my front left tyre just before I park up. It was unrepairable - I saw the tear - all the air came out of the tyre within 2 minutes.
Then I get a call from the dealer saying that my right rear brake disc had a deep half inch groove going all the way round it and the pad had been worn away. Apparently, they found a stone stuck between the pad and the disc that caused enough friction for this sort of damage. I saw the disc and pad and they both looked done. New tyre only available from BMW. New disc. New pair of pads. Parts and labour total bill of £700!! At least the first service was free and I can now open the engine up. Although, it is of some concern that the tyre pressure warning did not engage? Apparently, it was because of an immediate flat? |
12-27-2007, 10:34 AM | #2 |
34
Rep 379
12-27-2007, 11:18 AM | #3 |
Rep 4,128
Drives: M235i & G30 540i
Sorry to hear that. Look at the bright side, now you can step on it :d
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
12-27-2007, 11:53 AM | #4 |
Rep 955
12-27-2007, 11:55 AM | #5 | |
Moderator / European Editor
1552
Rep 6,754
BTW: Does anybody have a description on the TPM? Best regards, south |
12-27-2007, 01:56 PM | #6 |
Rep 110
Drives: Porsche 911 C4S Cab (after M3)
£700!?! Yowzers! More bills for this expensive toy...
How much is the insurance on you E92M, and with which company? What car did you have before, and what was the insurance on that? |
12-27-2007, 06:27 PM | #8 |
Rep 955
12-27-2007, 06:54 PM | #9 |
Rep 65
stone in between the pad and rotor???
if bmw's are anything like benz's you'd have trouble fitting a sheet of paper between the rotor and pad...and if it did somehow get in there, the damage described sounds fishy. seems like you got ripped off. |
12-27-2007, 07:49 PM | #10 |
Rep 4
Ouch! I never trust dealers they always tell something is worn when it doesn't neccessary need replacing.
The disc maybe scored but if the stone was removed then a new set of pads maybe all you need, I don't think it would affect the braking that much. To change the disc and pads is a straight forward job and wouldn't have taken more than an hour, so I don't know how they've charged you £700 including parts... |
12-27-2007, 10:27 PM | #11 |
Rep 65
a score in the rotor will cause noise and vibrations, and if deep enough can reduce the strength of the rotor and possibly crack it.
at my benz dealer we charge: 1.0 hour for front pads only (in reality takes only 10 minutes) 2.5 hours for front pads and rotors (takes 11 minutes) 5.0 hours for all pads and rotors (takes 25 minutes at most) at $150/hour labor, youre best off buying a jack and learning to do it yourself... |
12-27-2007, 11:21 PM | #12 | |
Rep 815
As for the TPMS retrofit mentioned above: Its weird that the euro e92 M3's don't have the TPMS sensors. I always thought that it was a performance oriented safety feature which would be a must for safe autobahn speeds. I'd imagine that it would be impossible to retrofit. You could easilly add the (Beru sourced, about $300 a set) sensors to the wheels, but the car-side sensor would have to be added and the computer would have to be reprogrammed, probably with a US spec program...... and that's if the sensor input exists on the euro ecu. |
12-28-2007, 05:08 AM | #13 |
34
Rep 330
Personally I'd write a stern letter to BMW UK asking them to refund, hinting that this kind of bill for first service would make very bad press and question the quality of engineering on a £55k car that allows this to happen.
I got a 328ci in 2000 and it was an import from ireland, when the delivery driver dropped it off it had to sit in the garage for 2 weeks. When I finally drove it the pads had been stuck to the disks and they were badly damaged and needed replaced, local dealer did it under warranty no questions asked. |
12-28-2007, 08:32 AM | #14 |
Rep 1,761
Drives: S2000, MacanS, M4CS
sorry about your situation, but at least you got a e92m3 and now can WOT all you want.
i don't know what it is with BMW or the tires, but with my e46 m3, I get crap trapped in the wheels from time to time, making very annoying scratching sound. I had a piece of metal trapped in there once, it sounded like someone screaming in horor on the highway.
2020 ///M4 CS, Alpine White, DCT
2018 ///M2 LCI, Metallic Orange, 6MT, Exec Pkg, Apple.. Sold Instagram: Tommys911 |
12-28-2007, 08:34 AM | #15 | |
Rep 289
For M3 V8: around £1100 fully comp after 7 years NCB Insured at £58k including business driving and around 10k miles a year, no excess, free windscreen. Previously for Audi S4: around £800 for the same deal. Oh, and the company is Bell Direct. |
12-28-2007, 08:42 AM | #16 | |
Rep 289
The problem is I'm no mechanic, I'd mess it up. I wish I'd had my camera at the time. The disc was quite damaged though and the pad was as well. Disc would have cracked eventually. |
12-28-2007, 08:42 AM | #17 |
Commander-In-Chief
2206
Rep 8,949
Drives: 2023 M2 Coupe, 2020 GLE 450
TPM type
Where did you get this information. I don't recall seeing that.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
12-28-2007, 08:46 AM | #18 | |
Rep 289
12-28-2007, 08:48 AM | #19 |
Rep 289
Yeah, but what would I say? The puncture is a puncture and the tyre was unrepairable. As for the disc they're likely to argue wear and tear, no?
12-28-2007, 10:24 AM | #21 | |
MacroRisk
109
Rep 2,523
@heyimsexy Thanks for confirming what I had thought ... dealers know how to make money off ignorance like mine (unhandy).
Just thinking of something not so witty ///M3 E92 '09 Jerez Black | 6MT | Ext Fox Red | Tech | Prem | 19s |Heated Seats | iPod |Smartphone | Euro Deliv June 09 Sold: 540iT / 530i / 323i |
12-28-2007, 11:32 AM | #22 | |
Moderator
7525
Rep 19,368
IIRC, BMW actually prefers the wheel speed system (uses DSC sensors), but due to upcoming US regulations, they were forced to implement the other system also. In any country where it is not required, BMW will stick with the former system. Last edited by mkoesel; 12-29-2007 at 04:39 AM.. |
