12-14-2014, 07:19 PM | #1 |
BimmerPost Supporting Vendor
2003
Rep 6,916
2015 BMW M3 Mineral White/Sakhir Orange gets the works!
Finally with the move to the new shop and all the holiday specials we have been working on I had some time to get some work done on my own car.
I was lucky enough to pick up a 2015 Mineral White M3 without any major imperfections. Let's start with the interior clean up first. We pulled out all the wrapper and a few of the decals on the glass. Did a vac and wipe down with a cockpit cleaner, followed by a nice leather cleaning and conditioning to prevent denim transfer. Glass was done as well as door jambs were sealed. Here is a list of products used on the interior. 1Z einszett Cockpit Leather Master Strong Cleaner Leather Master Barrier Auto Finesse Crystal Glass Cleaner 1Z einszett Gummi Pflege Stift Rubber Care Stick Tools used Metro Jumbo Vac n Blow Uber Leather and Carpet Brush Uber Microfiber Towels Uber Microfiber Applicator Pad Before Removing the tags and wrapper left in the car Leather cleaning and conditioning - even though the car is new I decided to clean with Leather Master Strong Cleaner followed with Leather Master Barrier to do some preventive maintenance to protect the leather from denim transfer. Door Jambs cleaned and protected - Sonax Polymer Net Shield was used on the jambs Door seals cleaned and protected with 1Z einszett Gummi - great way to keep them fresh and new as well as during the winter months its keeps your doors from freezing shut. After shots Moving on to the exterior prep and Xpel Ultimate installation. Exterior - Wheels were cleaned - Tires were cleaned and dressed up with Adam's Super VRT - Wheel wells were cleaned up - Washed with 1Z einszett Glanz Shampoo - Decon with Sonax Fallout Remover - NanoSkin AutoScrub Mitt - Clay - Door jambs were cleaned up - Dried - Masking - Paint Measurement - Final Polish - Sonax Perfect Finish 4/6 - Cleaned paint with Menzerna Top Inspection - Last step - Sonax Polymer Net Shield (will apply a coating when I can put more time on the car) - Inspection with LED, Fenix and natural sunlight - Rubber and Plastics Treated - Exterior windows and mirrors cleaned - Exhaust tips cleaned Products used: 1Z einszett Glanz Shampoo Uber Clay Bar Sonax Fall Out Remover Auto Finesse Oblitarate NanoSkin AutoScrub Mitt Sonax Perfect Finish Sonax Polymer Net Shield Adam's Super VRT Menzerna Top Inspection Auto Finesse Crystal Glass Cleaner Tools used Uber Quick Detail MF Towels Uber All Purpose MF Towels Griot's 3 inch Random Orbital Polisher Rupes BigFoot LHR 21ES Random Orbital Polisher Rupes BigFoot LHR 15ES Random Orbital Polisher Uber Buffing Pads Defelsko Paint Meter Fenix TK35 2 Grit Guard Buckets with Caddies Adam's Firehose Nozzle Metro Air Force Blaster Before shots Wheel cleaning - Sonax Wheel Cleaner Plus and various brushes Uber Boar's Hair Brush for the lugs Wheel Woolies for behind the spokes and the first 1/2 of the inner wheel barrels EZ Detail Brush for the back half of the wheels and in between the calipers and wheels - super tight especially with the stock 19's. Smaller Wheel Woolies for between the spokes Adam's Boulder Brush for the face of the wheels - super gentle. Rinse them off. Decon with Sonax Fallout Remover (it pulled up quite a bit of iron particles and fallout with only a few hundred miles on it) After all the decon wash pressure washed off we foam the car Rinse and blow dry With the darker/matte wheels I have found we always need to go back and hit them up with a detail spray to ensure they are perfectly clean. Washed and Dried - next up clay bar Making sure the car is perfect prior to the Xpel Ultimate Clear Film installation. A good polish with Sonax Perfect Finish and the Rupes LHR21 with Rupes Yellow Pad. After the complete prep we made sure all the areas that were getting protected with Xpel were cleaned a few times with an IPA wipe down. Areas being covered - front bumper, full front fenders, full hood, mirrors, headlights, a pillars, front of the roof, door cups, full side skirts, luggage area on the back bumper and behind the rear wheels on the rear bumper. Some final touches - Glass cleaned after the Xpel Ultimate was installed - Getting the tires cleaned and dressed - using Stoner's Tarminator, Auto Finesse Obilitarate, Adam's Super VRT No after shots with the stock set up we went to Ben and Mark at Rogue Engineering for some goodies. Rogue Engineering installed H&R Springs, Rogue Engineering Spacers 12 mm, and Rogue Engineering Stainless Steel Brake Lines stock H&R RE 12MM Spacers Front and Rear RE SS Lines Stock RE SS lines installed Back at DD it was cleaned it up and took some final shots. Inside Outside Hope you enjoyed it, email me with any questions about this write up or anything else detailed related. |
12-15-2014, 01:05 AM | #2 |
Rep 524
Looks awesome. Just had some questions on the clearbra. Did you remove everything (grills, headlights, door handles, etc.) when installing it?
What did you do about the headlight washers? Did you cut around it or wrap underneath the washer covers? How did you re-attach the hood emblem / what did you use? Did you clean the surface with isopropyl after applying xpel and use 3m adhesive to reattach front the emblem? |
12-15-2014, 08:37 AM | #3 |
2003
Rep 6,916
sure thing, we have been using software and a plotter to get our film done, so most of the car is plotted out and we call out the extra to wrap around the fenders etc.
The hoods are done custom, while most bumpers are done with the plotter. As far as the headlights we plot them out its exact and is much cleaner. The bumper was plotted out, our thought process is it will reduce the amount of times the blade is on the car, which will reduce the chance of cutting the paint. We did not remove the BMW emblem. |
12-15-2014, 09:03 AM | #6 |
Rep 2,148
Phil,
Is Leather Barrier new? I've been using the three step process with Strong Cleaner, then Leather Vital, followed with Leather Protection Cream. |
12-15-2014, 10:15 AM | #7 |
2003
Rep 6,916
yes it's relatively new but I believe its based off of Protection Cream.
The 3 steps is still a great option, but you can do strong to protection or strong to barrier. I still favor the 3 step on older interiors. |
12-15-2014, 02:48 PM | #9 |
Gone Fishin’
7318
Rep 12,125
Looks good. I really need to protect my Full SO. Would you suggest using those products on the seats and the full dash? Did those products take away from the matte finish?
12-15-2014, 10:01 PM | #11 |
Gone Fishin’
7318
Rep 12,125
12-21-2014, 08:25 AM | #13 |
Gone Fishin’
7318
Rep 12,125
Just finished putting on the second layer of barrier after letting the first dry overnight. The Leather Masters products work great. Did this on my Full SO including all dash and doors. Left the finish matte like original but leather feels softer.
12-31-2014, 11:57 AM | #16 |
Rep 205
Wow, looks great! Quick question for you Phil, what do you recommend for taking care of the exterior door trim that surrounds the windows (the hard black plastic)? TIA
12-31-2014, 12:22 PM | #17 |
10833
Rep 27,611
wow thats impressive!
Don't mean to thread jack but I have some gunk on my lower rocker panel by the front of the doors like showed in your pics that I can't get off. Any suggestions on what I could use to get that off? looks like a thick residue wasn't sure what would hurt the paint. Basic soap isn't working. Thanks
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
01-17-2015, 07:34 PM | #19 | |
2003
Rep 6,916
01-17-2015, 07:35 PM | #20 | |
2003
Rep 6,916
what polishes do you have on hand? |
Tags |
bmw m3, f80 m3, mineral white m3, xpel ultimate |
