01-24-2015, 10:46 AM | #1 |
Rep 122
Finally got Homelink working
After several unsuccessful attempts at programming my garage opener, I came Across these instructions for the e39, which did the trick. Much more detailed than the M3 manual.
http://www.bimmerfest.com/forums/sho....php?p=4363430 |
01-24-2015, 11:21 AM | #2 |
Rep 11,891
Hardest part is when you have to hold down the mirror button and remote button to register it.
The trick is in the placement of the remote and mirror when you're getting the mirror to register the remote code. On my 08 M3, I literally had to touch the remote to the mirror. I just programmed my 2012 X5 last night, and it was a breeze, and did it on the first try. I think something was changed in late build models where it is now easier to get the mirror to register the remote. |
01-24-2015, 02:06 PM | #4 |
Güdentyte
1174
Rep 1,210
Instructions from the manual is frustrating to read. I too had to have my garage remote literally touching the mirror from the side to correctly capture the frequency code. On my 335i, I can do it 6 inches apart and will register.
CURRENT - 991 GT3 | Future Classic 1M | Model 3 | T4R TRD Pro Lime Rush
SOLD - MB M2 CS | SMB F80 M3 CS | E90 M3 | E90 335i | E46 M3 Vert | E39 M5 | E34 525i |
01-24-2015, 02:47 PM | #6 |
///M'n it Up
17
Rep 344
I just setup the homelink on my new car. Took me a while to figure out the right combination of steps - since there are all kinds of varying instructions on the internet. Here's what worked for me.
1) Car off 2) Turn car on, but do not start. (Press start button without foot on brake) 3) (optional) Hold 1 & 3 buttons on car for 30 seconds until small light next to button 1 blinks quickly. This erases old codes 4) Hold garage door remote near your rearview mirror. Then hold the button on the garage door remote and the 1,2 or 3 button on the rear view mirror for about 5 seconds until the light near 1 button starts to blink rapidly. The car's homelink can now emulate the frequency and format of the code sent by the remote. If you have a very old garage door opener that now works, that's it. But you may also consider replacing that garage door opener, because as you can see - it would be very easy for anyone to open it. For modern garage door opener units, you'll need to continue... 5) Press the program button on your garage door receiver (motor that's mounted to the ceiling) 6) Quickly go to the car and hold the button in the car that you programed in step 4. Your garage door receiver should flash a light or somehow indicate that the programming worked. Let go of the button on the rear view mirror when it does. 7) Press the same rear view mirror button for about 2 seconds to test. Garage door should go up or down. Last edited by wildag; 01-24-2015 at 02:53 PM.. |
01-25-2015, 10:37 AM | #7 |
Rep 11,891
I thought these were simple videos to follow
01-25-2015, 12:21 PM | #8 |
Rep 1,168
The newest openers by LiftMaster (and maybe others) require a HomeLink repeater to work in 3+ yr.old cars, like in my '12 M3.
Learned that the hard way. |
02-21-2015, 03:09 PM | #12 | |
Rep 837
11-02-2016, 08:46 PM | #14 |
Rep 657
Finally got it to work by following the directions on Homelink.com. No need to do the remote learning step at all. Hold all 3 buttons until light goes out, hold the button you're programming until solid light (2 seconds), hit learning button on garage door control unit, push and hold Homelink button for 2 seconds, then again, and success. Finally!
11-03-2016, 07:07 AM | #15 |
Rep 1,181
Drives: 2011 E92 M3 6MT ZCP
I recently successfully programmed mine and the variable appeared to be the distance I held the opener transmitter from the homelink. Took me three of four tries following the directions in our owners manual but it worked.
