01-27-2015, 03:10 PM | #1 |
Rep 36
Steering Issue
Hello all. I'm experiencing an issue with my 2011 e92 M3 Comp package, hopefully some of you can help.
During right turns, while accelerating, the vehicle and steering wheel begin to shake hard. It literally feels like my wheel is going to fly off. After diagnosis at a local German auto shop, they were unable to identify the cause. Recently performed alignment, which eliminated some of the shake; however, it is still there. After reading about related issues elsewhere, people have indicated that the issue may be related to CV Axle being bent, Control arm being bent, or worn bearing. I've also learned that EDC may potentially be causing the issue considering my vehicle is currently lowered on KW's. Side note: warranty is no longer active. Any insight is would be greatly appreciated! |
01-27-2015, 05:25 PM | #2 |
Rep 536
Your control arm bushings are probably worn/wearing out.
I had the same problem when i had a Lexus. They were all cracked up and needed to be replaced. You can also re-grease them if your on a budget. But it won't last too long |
01-27-2015, 06:54 PM | #4 |
Rep 36
01-27-2015, 06:56 PM | #5 |
Rep 36
Thank you for the info. Would this mean the bushings on right side control arm considering shake only occurs during right turns?
01-27-2015, 07:34 PM | #6 | |
Rep 36
I removed left front wheel recently and noticed that the coilover has a little bit of tire residue on it - possibly the tire is rubbing the coil during right turns causing it to shake. Your thoughts? One thing I noticed is that the moment I remove my foot from the accelerator the shake stops. Do you think a bulge or bubble can cause such a drastic shake? |
