Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > Regional Forums > CANADA
      02-12-2015, 12:52 AM   #1
redfox
INSTAGRAM: @yaasplease
redfox's Avatar
Drives: 2015 YMB M4
What's everyone planning to do to their M once...
the snow melts?
I'm getting a new set of wheels. Which btw, means my TE37s could be for sale if you are interested.
I'm also waiting for the right springs to arrive. That's all for now.
2015 ///M4: M/Vorsteiner Aero, P3Cars, HRE R101, Dinan S2, Coils & Intake; Eis/Akra Exhaust
2013 WRX Hatchback: LED Conversion, Blacked Out, Rally Armor
2015 Macan Turbo: Techart Exhaust, Cargraphics Lowering Module, Blacked Out
      02-12-2015, 05:33 AM   #2
M4LAKA
Drives: 2022 M5 Comp
What wheels brother?
      02-12-2015, 10:08 AM   #3
pyceasyas123
pyceasyas123's Avatar
390
Drives: M3
Wheels and a drop probably in the works for me. Waiting for bilstein pss10's to release. Can't seem to decide on what wheels to get though...
      02-12-2015, 10:32 AM   #4
Gearhead999s
Gearhead999s's Avatar
817
Drives: RR Velar R=Dynamic M2C R1200GS
I have a 19" Track setup coming.Forgestar F14's 19x10 19x11 with Yoko AD008R's in 275/30/19 295/30 19.I have to run a tire with a wear rating of 140 or better to be legal to run in the Ontario 1500 in September.I also ordered a Cayman GT4 for myself.
www.ontario1500.ca
      02-12-2015, 10:59 AM   #5
myzmak
Advocatus Douchebagus. Sex Marxist.
myzmak's Avatar
Drives: Lucy.
2015 F80 M3  [10.00]
2013 MB E350 Wagon  [10.00]
Get the damn winters off and put the summers on.
I'll just be running stock wheels/rims this summer. I like the look of the 19" rims enough I don't see changing those for a long time, if ever.
Drivin' Lucy
      02-12-2015, 01:56 PM   #6
pyceasyas123
390
Drives: M3
www.ontario1500.ca
gt4...
      02-12-2015, 02:37 PM   #7
Soundstream
Drives: 2021 BMW X7 40i
Originally Posted by redfox View Post
the snow melts?
Take delivery.
      02-12-2015, 02:49 PM   #8
E92LNGCGY
Drives: F97/Q5/982 GT4
Take the car for a couple of runs to break in the JB4.
      02-12-2015, 02:50 PM   #9
brianeck
Part Time Firetruck Crash Barrier
brianeck's Avatar
788
Drives: 2022 M340ix Mineral Grey
Hah I can't wait to get my stock rubber back on the road! I love the wheels, and my traction control really hates rolling around with 255s in the back!
m340ix Mineral Grey/Tacora Red
      02-12-2015, 03:32 PM   #10
Gearhead999s
817
Originally Posted by pyceasyas123 View Post
gt4...
Here is a conceptional picture of my build.
      02-12-2015, 04:16 PM   #11
pyceasyas123
390
Drives: M3
Amazing! Can't wait to check one of these out in person.
      02-13-2015, 01:26 AM   #12
bornyesterday
Drives: F82, E92
I'm interested in your TE37s!
Keep me posted.
      02-13-2015, 10:54 PM   #13
redfox
redfox's Avatar
Drives: 2015 YMB M4
its a secret for now...
      02-13-2015, 10:55 PM   #14
redfox
redfox's Avatar
Drives: 2015 YMB M4
www.ontario1500.ca
nice! what offsets are you running?
      02-14-2015, 06:58 AM   #15
Gearhead999s
817
25P front 37P rear.
      02-14-2015, 08:33 PM   #16
redfox
redfox's Avatar
Drives: 2015 YMB M4
25P front 37P rear.
How did you come up with your setup?
I'm doing a track/show setup as well and have been doing some research. Are you lowering your car? ET37 is aggressive for the rear for a track setup. It's perfectly flush with a 11 inch wide rim and 295s. Full compression may cause some rubbing. I'm going with 40 at the back and running 295 to give myself a little margin for safety.
I also did some research and was told that 275 is doable on the front, but may rub on full lock. Again, just based on my research. Hence sticking with 265 on 9.5 inch wide rim and ET20.
      02-15-2015, 07:24 AM   #17
Gearhead999s
817
Not lowering my car as it has to stay stock under the rules that we will be running under.The original spec was 33p from Forgestar with them knowing my tire sizing.I did my own estimating and went to 37 which I am hoping will be ok.275's up front should not be a problem as I already test fit an 18" on the front but had no brake clearance.I ran 275's on my E92 M3's with no rubbing at all.
      02-15-2015, 09:55 AM   #18
gthal
gthal's Avatar
Drives: 2018 340i xDrive
Track wheels and tires... that's all for now.
Gearhead999s ... I am so damn jealous!! That will be a beautiful car!!
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery
2016 M2 | Long Beach Blue | 6MT
2015 M4 | Austin Yellow | DCT
2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3
      02-15-2015, 10:57 AM   #19
redfox
redfox's Avatar
Drives: 2015 YMB M4
With ET25 up front. I think you will have no issues with the fender. However, apparently the front suspension assembly is fairly bulky on the F80/82. I'm gonna call some people and verify. I would like to run 275s up front to increase breaking performance and reduce understeer without going to a stickier tire, but don't want any contact with the suspension either.
      02-15-2015, 11:14 AM   #20
Gearhead999s
817
The key thing is too keep the tire heights close to stock.I ended up going with a 19" setup due to availability of tires with a tread wear of 140 or better again due to the rules.
      02-15-2015, 11:16 AM   #21
redfox
redfox's Avatar
Drives: 2015 YMB M4
My proposed setup with be about 7mm taller. You think that's an issue?
      02-15-2015, 11:24 AM   #22
Gearhead999s
817
I was originally going with C7 Z06 but GM will not build it the way I ordered due to "commodity restrictions" which means waiting till 2016 to get the car that I ordered.Not sure when the GT4 will arrive as the dealers do not have allotments yet so the plan is to use the M4 till that happens.At that point I will make a decision about keeping the M4 as a DD or get something else for that purpose.By the way GM can go screw themselves!
f80post
