      05-25-2015, 06:51 PM   #1
wjbender
wjbender's Avatar
Drives: 2022 X5, 2024 Z4 M40i
Lug nut torque spec?
Anyone know where I can lookup the lug nut torque spec for the F15?
      05-25-2015, 07:30 PM   #2
MysticBlue
I don't know for sure on the f15, but every other BMW I've owned or still own is 88 ft/lbs.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra.
      05-25-2015, 08:56 PM   #3
kskpsu
kskpsu's Avatar
Drives: 1M; E90 M3 ZCP; M4 GTS
'11 BMW 1M  [9.83]
Discount Tire paperwork says 105, FWIW
-kskpsu
      05-25-2015, 11:07 PM   #4
DDS2015
Drives: 2018 M3CS
2021 BMW X3  [10.00]
2023 BMW M4  [10.00]
+1 on this. Couldn't find it in the manual either.
aracka60.00
      05-27-2015, 12:17 PM   #5
stewy604
stewy604's Avatar
293
You'll be fine in the 90-100 range...thats what I've always done.
2007 Suzuki GSX-R 750
      05-27-2015, 01:11 PM   #6
Kief
Kief's Avatar
4685
Drives: '24 iX50; '23 Audi RS etron GT
Previous E-chassis 88ft/lbs across all series
Current F-chassis 105ft/lbs across all series
'24-I20 iX 50; '23 RS etron GT; '23-G26 i4 M50*; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired
      05-27-2015, 09:44 PM   #7
42pilot
42pilot's Avatar
623
Drives: 2014 X5 35d MSport
If you don't mind, what is your source?
thx
      05-28-2015, 12:20 AM   #8
solrac6262
84
Drives: bmw X5
is the 105ft/lbs for the 21" wheels
I was installing new wheels my self today, but one of the rears it was imposible to get it out, last week my car was at the dealer and they inspected that side and removed the wheel the idiot probably was using impact wrench..
      05-28-2015, 06:21 AM   #9
Kief
Kief's Avatar
4685
thx
Post #7
http://f80.bimmerpost.com/forums/sho...ue+settings%3F
      05-28-2015, 09:29 PM   #10
42pilot
42pilot's Avatar
623
Yep - it is typical as time is money. Most guys who have been working on cars will get it close with an impact and they think its good. And for most of us driving the roads, it probably is. For me, I even torque the wheels on my 05 pickup. On the track, it's absolutely required. Here's something that will blow your mind - on my 79 turbo Porsche, I used anti-seize on the threads. The lug nuts were aluminum and the studs were steel.
And I always re-torque when I buy new tires or get the free rotate and balance. Even when I ask for a specific spec, rarely do I find them tightened correctly.
One last point - it would crack me up to see a Sears Craftsman torque wrench at the track, seeing the value was set and probably left at XX ft lbs since the last event. If you want to do it right, buy a good wrench, unload it after each use (set to 0) and take it by a machine shop every couple years for calibration.
      05-28-2015, 09:46 PM   #11
MysticBlue
Thanks for the info. This is why I keep coming back to these forums... always something more to learn.
Time to go re-torque my wheels.
      05-29-2015, 06:03 AM   #12
Kief
Kief's Avatar
4685
Post #7
http://f80.bimmerpost.com/forums/sho...ue+settings%3F" rel="" target="_blank">http://<a href="http://f80.bimmerpos...ettings%3F</a>
I take it you were able to read the thread/post as what I attached apparently isn't showing via the mobile app
      05-29-2015, 07:26 AM   #13
E90Fleet
South Africa
1414
Drives: BMW
M14 bolts 140NM (103.2lbf)
M12 bolts 120NM (88.5lbf)
F15 uses M14 bolts
From BMW
BMW if you are reading, I need a job, Please.
Appreciate 4
      05-29-2015, 08:16 PM   #14
42pilot
42pilot's Avatar
623
F15 uses M14 bolts
From BMW
Now that's proof. Thanks for sharing the data sheet.
      05-30-2015, 12:04 AM   #15
wjbender
wjbender's Avatar
Just a little tidbit for those who are unfamiliar - Please do not tighten all the way to 103 lbf at once. I follow the sequence in the chart, but get to full torque in three steps
      04-15-2016, 04:56 AM   #16
Baunton
Baunton's Avatar
England
327
Drives: X5 45e 2021
Lug Nut Size?
Does anyone know what size the lug nuts are for the F15?
I have the 20" wheels, not that it probably makes a difference and I want to buy a wheel wrench but want to be sure I get the right size.
Thanks.
      04-15-2016, 09:23 AM   #17
Thanks.
The lug bolt head is 17mm hex.
      04-15-2016, 09:59 AM   #18
JonM
Drives: E90 M3 Sedan
I used to buy Craftsman torque wrenches. To me, they always seemed to go out of calibration after a year or so and I didn't trust them. Spend a little more money and you can buy CDI brand (basically Snap On without a Snap On brand logo) and they seem to last longer and work better.
Jon Maddux
coupenut.blogspot.com
x5nut.blogspot.com
16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe
      04-15-2016, 01:14 PM   #19
Baunton
Baunton's Avatar
England
327
Drives: X5 45e 2021
r33_RGSport many thanks.
      12-15-2020, 10:32 AM   #20
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
F15 uses M14 bolts
From BMW
Bump for others changing to winter wheels, I used this info today.
I had two tires replaced during the summer they used the air wrench to tighten.... idiots!!!
      12-17-2020, 12:38 AM   #21
F15GorDe
F15GorDe's Avatar
Drives: F15d, F10
Yep, don’t want to be too frugal with the money you spend for your torque wrench.
      12-18-2020, 10:51 AM   #22
DenBel
246
Drives: F15 50i, F13 650i
140 nm as per newtis
