10-05-2015, 07:50 PM | #1 |
Member
942
Rep 2,036
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [10.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
Instrument cluster (6WB)
Does anyone know what the bars are between the two gauges when in Eco Mode?
2019 X5 Alpine White M-Sport
Software Version 11/2022.31 2023 M2 (HEA) Brooklyn Gray 2021 330i XDrive Alpine White M-Sport |
10-05-2015, 08:02 PM | #2 |
Member
942
Rep 2,036
Here is a pic
10-05-2015, 08:45 PM | #3 |
Rep 5,070
I've tried searching on the owners manual for the X6 and I couldn't find anything on it.
Unfortunately, US X5's don't have the 6WB so maybe our european, Australian, or Canadian members might chime in. We do have some members here who retrofitted the 6WB.. maybe they know what it is
10-05-2015, 08:59 PM | #4 |
Rep 222
my guess is that it's an allusion to the fact that EcoPro is so efficient, when driving down the road, it is like the BMW bobsled zooming down the run Last edited by wearenh; 10-06-2015 at 12:54 PM.. |
10-05-2015, 09:03 PM | #5 |
Rep 1,808
Drives: 2016 X5 35d
10-05-2015, 09:03 PM | #6 |
Rep 5,070
Haha! Sounds like a good one wearenh
If I had to guess I would think it is the active cruise control meter gauging the distance from the car in front of you or measuring the efficiency of eco pro or coasting?
10-05-2015, 10:45 PM | #7 |
Rep 186
I don't have active cruise control but have the same bars. I think they are just static image, don't remember them changing.
10-06-2015, 01:15 AM | #9 |
Rep 1,170
That means "Take the next exit and and go through supersonic LED tunnel"
But on a serious note, if it's not related to ACC then it must be a standard graphic 6WB display that simply changes between red and blue.
2014 X5 xDrive50i Last edited by kanvas; 10-06-2015 at 01:30 AM.. |
10-06-2015, 06:25 AM | #10 |
Member
942
Rep 2,036
I'm not the primary driver but I'm almost certain it changes. My wife has said that she saw fewer bars the other day. I'll have her take another pic. It's not a big deal, just curious.
10-06-2015, 12:45 PM | #11 |
Rep 491
for the non 6WB clusters in the US, does anything show in the middle part of the screen?
Thought i saw something the other day but can't replicate it. Thanks
F85 (17) - DG/AB
F87 6MT (20) - Comp - BSM F80 DCT (18) - Comp - AW F30 6MT 335i - EBII |
10-06-2015, 01:22 PM | #13 |
Rep 2,190
For cars without Active Cruise Control, it's just a static display.
For cars with Active Cruise Control, it is used to show the distance setting between you and the car in front of you. |
10-06-2015, 03:40 PM | #14 |
Rep 2,194
It indicates your miles "saved" or added onto that tank of gas. When you first put it in Eco mode it should show +XX miles, meaning you've added that many additional miles to your tank. Those blue bars are equal to 10km or miles. So when you've managed to add let's say +20 there should be two blue bars filled in.
It has nothing to do with ACC, those appear higher on the display. |
10-06-2015, 08:03 PM | #16 | |
Member
942
Rep 2,036
Mystery solved!
"the bar symbolize the gained bonus fuel range in stages. The more bars that appear, the more efficient you are in using eco pro mode. It looks like you guys are pretty fuel efficient drivers". My wife drives it in Eco Mode and getting 10.4L / 100 KM all city so far. I'm sure all this will change when I get behind the wheel and throw in MPPK.
10-07-2015, 01:13 AM | #17 |
Rep 2,194
Use the BC button to cycle through all the options, it's on your turn signal lever.
10-07-2015, 01:29 AM | #18 | |
Rep 2,194
This is when you first set it/turn it on, or if you change the distance setting. |
10-07-2015, 12:38 PM | #20 | |
172
Rep 378
