03-12-2016, 11:18 AM | #1 |
Rep 2,402
Strongflex Tension Strut/Control Arm Bushing Install
I was buying Strongflex tension strut poly bushings (hydrobearing replacement) for our X1, and decided to spring for the same plus the control arm polys for the 135.
Installed using tools similar to these: This was the install on my X1, but similar for the 1er (I removed the control arm entirely), left the TS in: My god, just did these the other day. Can't believe I waited so long! Turn in, steering feel, etc. All moving back toward proper BMW. Old bushings and new came out/in pretty easily...so in all, it was hardly more work than full arm replacements. Very nice, cheap upgrade. Sorry for the quick post, if anyone wants more info, will post more details later.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
03-12-2016, 01:08 PM | #2 |
European Editor
10607
Rep 22,992
Cool, thanks for posting!
I wonder if you could use these for the M3/1M rear subframe bushings. ?
03-12-2016, 02:25 PM | #3 | |
Rep 2,402
So if you only pay for shipping once, it makes sense to order as many different applications as you'll use. I paid less than $180 total shipped for the X1 TS polys, the 1er TS polys, and the poly control arm bushings. The company gets good reviews, and from what I saw, the quality was there. Grease channels, both radially and axially on the outer arm to bushing surfaces. Knurling to hold grease on the bushing insert bore. Good fit, etc .
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) Last edited by PrematureApex; 03-24-2016 at 08:14 AM.. |
03-12-2016, 04:27 PM | #4 | |
1Addict
3237
Rep 7,902
Gonna look into their stuff vs white line. Thanks for the post!
03-12-2016, 05:02 PM | #5 | |
Rep 2,402
Just for kicks I even tried a 3-jaw puller to see if it would push one of the TS hydros out on a friend's car. It did, easy: http://www.harborfreight.com/3-piece...-set-8832.html All the talk that a 20 ton hydraulic press is needed for these installs is 100% wrong. Just have a GOOD cordless impact to drive the threaded presses and you're all good.
03-12-2016, 05:16 PM | #6 |
1Addict
3237
Rep 7,902
Hm. Better put this on my to do list then. Are the strongflex bushes one or two piece?
03-12-2016, 05:35 PM | #7 |
Rep 2,402
One piece for the TS, two for the control arm. Some guys have cut the TS bushing in half making the install really easy.
03-13-2016, 07:55 PM | #8 |
Rep 4,040
Drives: 130i coupé ;)
More pics of the install or the bushing you are referring to?
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is |
03-15-2016, 09:58 AM | #9 |
Rep 2,402
Unfortunately, didn't take many pics.
The TS bushings look like this. Simple, one piece. $25ish per. The control arm bushings are the two-piece ones in the middle bag. The install is pretty self explanatory. Receiver on one side, pusher on the other. Or use a three-jaw puller. Tons of anti-seize lubricant. Like, an uncomfortable amount.
03-15-2016, 10:02 AM | #10 |
1Addict
3237
Rep 7,902
You killed me... haha
03-15-2016, 11:57 AM | #11 |
Rep 1,623
Drives: Alpine White 128i Cabrio
Awesome.
I'm getting a clunk on my right front suspension somewhere. It's pretty annoying and even has a feel to it. You can feel the clunk. I replaced the endlinks and sway bar bushings thinking that it might be them. Those parts were cheap but did not fix the clunk. I checked my top mounts and strut nut and those were tight. Does anyone think it could be my control arm bushings, or tie rods? I might look into just replacing the bushings if it was that easy with a puller. What I'm worried about is the ball joint being the culprit, so swapping bushings on the inside won't do anything. Could it be the strut itself? I recently installed a Sachs coilover kit. Rebuild time?
2008 128i E88 / Alpine White / Boston Leather Sport / 6AT / M3 Paddle Shifters / Bilstein B8 / H&R Springs / Dinan Fixed Camber Plates / BMW 335i Front Brakes / PIAA Xtreme White 4150K Angel Eyes / Rear Fogs Enabled / Cyba Air Scoops / Euro Airbox / BMW Performance Exhaust / Stubby BMW Antenna
03-15-2016, 03:34 PM | #12 | |
1Addict
3237
Rep 7,902
Dr182.00 |
03-18-2017, 11:52 AM | #14 |
Rep 989
Relevant bump for the observant- I ordered the TS bushings from strongflex in January, polish tracking says they got to Warsaw Feb 4. No update since
Update, they sent out a new set immediately and came in two weeks. Hoping the first set shows up in the months ahead LOL
MHD | BMS | VRSF | APEX | RECARO | TC Kline | BERK | Turner Motorsport | Eibach | BMW Performance
