05-11-2016, 03:30 AM | #1 |
Rep 8,639
135i Rear Toe Arms
Does anyone have experience with any upgraded rear toe arms? One issue that is imho near tragic on the 135i, is side to side deflection / rear end flex on hard acceleration... the car literally bounces side to side. My car had the M3 rear subframe bushings done and this fixed the up and down bounciness but the car had insane side to side flex when accelerating onto a highway ramp or any scenario of that sort. Does anyone know what fixes this?
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
05-11-2016, 07:41 AM | #3 |
53
Rep 379
I'm no expert, but it would seem to me like the issue is the bushings in play here, not the arms themselves. I would think switching to poly bushings or even better, spherical bushings, would probably help a lot.
Living the 1-life since 2013.
05-11-2016, 07:44 AM | #4 | |
Rep 8,639
05-11-2016, 08:17 AM | #6 | |
Rep 8,639
05-11-2016, 08:28 AM | #7 |
Rep 3,856
What about the rear trailing arms? For safety purposes, the arm should remain stock so in a crash it bends away from the fuel tank (arm is identical on M3), but you can upgrade the bushings. No expert, but don't people usually point to the RTAB when it comes to an unstable rear?
05-11-2016, 08:33 AM | #8 |
53
Rep 379
I dunno, this sounds like it could be an out-of-alignment setup or perhaps a bent rear suspension arm??? I have my car bone stock, and I get instability in the rear accelerating out of slow corners at the track. It's not that bad, it's just slower than it should be.
How are you determining you have side-to-side flex in the RSF?
05-11-2016, 08:40 AM | #9 | |
Rep 8,639
This happens on hard straighline acceleration, its so bad and disconcerning... suspension is fine.
05-11-2016, 10:44 AM | #11 |
Rep 8,639
are you saying something is damaged or bent? Because I know that is not the case.
05-11-2016, 11:23 AM | #13 |
Rep 6,196
05-11-2016, 11:33 AM | #14 |
1Addict
3237
Rep 7,898
Easiest thing to start with IMO
05-11-2016, 11:47 AM | #15 | |
Rep 8,639
05-11-2016, 11:48 AM | #16 |
Rep 8,639
What spec would you recommend?
05-11-2016, 11:56 AM | #17 | |
Rep 6,196
Maybe try 0.15 deg toe in on both sides. Last edited by MightyMouseTech; 05-11-2016 at 12:08 PM.. |
05-11-2016, 12:07 PM | #18 | |
Rep 8,639
05-11-2016, 12:22 PM | #19 |
Rep 6,196
05-11-2016, 02:37 PM | #20 | |
Supreme Allied Commander
3885
Rep 54,481
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
05-11-2016, 02:39 PM | #21 | ||
Rep 8,639
05-13-2016, 07:38 AM | #22 |
Rep 2,402
Same issues here, made a thread about it. Had 25 people chime in that it's the alignment.
I've run everything from 1/16" to 1/4" of rear toe. It it absolutely not alignment related. There's a large amount of flex and/or dynamic toe change going on back there. Feels like a rubber band winding up and releasing at times. I bought some Whiteline poly bushings for both the toe and trailing arms...being dragging my feet installing...but I will soon. I'll let you know.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
