| 05-21-2016, 02:06 AM | #1 |
![]() 29
Rep 67
BMW F15 coding instruction
Re-Code for Dazzle Headlights (LED Adaptive Headlights like EU-Spec):
Change FA (VO) to Remove 5AP & 8S4 from VO. Save and Write FA to Vehicle VO Code BDC Body Module Read FA(VO)Activate FA(VO)Read SVTRight-Click ECU & Select Code VO Code KAFAS2 Module or FLA2 Module Read FA(VO)Activate FA(VO)Read SVTRight-Click ECU & Select Code VO Code FLE (43) Module Read FA(VO)Activate FA(VO)Read SVTRight-Click ECU & Select Code VO Code FLE (44) Module Read FA(VO)Activate FA(VO)Read SVTRight-Click ECU & Select Code Now Proceed to code FDL Changes to both FLE(43) & FLE (44) Modules (below) Once all above is completed, you can proceed to code any FDL Changes to the other ECUs listed above, as VO Coding is completed in those ECUs. Re-Code for Enhanced Bluetooth: Change FA (VO) to Remove 6NH from VO & Add 6NS to VO VO Code HU_NBT Read FA(VO)Activate FA(VO)Read SVTRight-Click ECU & Select Code Now Proceed to code HU_NBT Module … or re-code if coding was already present IF YOU NEED TO DO EITHER OF THE ABOVE … FOLLOW THE INSTRUCTIONS FOR “HOW TO CHANGE FA” in my BMW f series Coding Guide. This needs to be done FIRST … meaning before you perform FDL Coding or Changing Werte Values ACSM Module: SeatBelt Reminder Lights OFF: set all to nicht_aktiv 3000Gurtzustandsanzeige_Beifahrer_GFW_GZA_BF 3000Gurtzustandsanzeige_Fahrer_GFW_GZA_FA Disable Welcome 3 Gongs: 3000 Initialwarnung_GWF_IW = nicht_aktiv SeatBelt Reminders/Sound OFF: set all to nicht_aktiv 3000SBR_PreWarning_Fahrer 3000SBR_PreWarning_Beifahrer 3000SeatBeltReminder_SBR_Fahrer 3000 SeatBeltReminder_SBR_Beifahrer BDC_BODY Module: Auto Start/Stop OFF by default 3023TCM_MSA_DEFAULT_OFF set to: aktiv Auto Start/Stop – Remember LAST Setting 3023TCM_MSA_MEMORY set to: aktiv Unlock all doors with engine off (Single-Pull Handles): 3040 VAM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK set to: aktiv Electronics off when door opened 3020TCM_LOGIC_R_OFF_DOOR set to: aktiv Close Mirrors/Windows/SunRoof from FOB or CA – set all to: aktiv 3056KOMFORTSCHLIESSUNG_FB 3056KOMFORTSCHLIESSUNG_PA 3110ASP_BEIKLAPPEN 3110ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN 3110ASP_BEIKLAPPEN_NACH_KOMFORTSCHLIESSEN Set Mirror Fold Delay Time 3056KOMFORT_SCHLIESSEN set to werte=00 Start Car by pushing button (hold brake not needed) 3020TCM_STARTLOCK_BRAKE set to: nicht_aktiv 3020TCM_STARTLOCK_DRIVINGREADINESS set to: nicht_aktiv Tilt Passenger Mirror farther down when in reverse 3110ASP_BORDSTEINAUTOMATIK_DELTA set to: werte=4B Opening FRONT doors won’t interrupt windows: 3050FH_TUERAUF_STOP_MAUT set to nickt_aktiv Opening REAR doors won’t interrupt windows: 3051FH_TUERAUF_STOP_MAUT_REAR set to nickt_aktiv Fog Lights stay on w/ High Beams 3068NSW_AUS_BEI_FL set to nicht_aktiv Ambiance Lighting controlled independent from Dimmer Switch 3070 AMBIENTE_NACHFUEHRUNG set to: nicht_aktiv High-Beam Assistant – Auto-On: 3068FLA_AKTIVIERUNG set to: LDS_in_A_oder_2 Increase Angel Eyes Brightness to 100% Xxxx MAPPING_STANDL_V_L_PWM_LEVEL_1 = 100% Xxxx MAPPING_STANDL_V_R_PWM_LEVEL_1 = 100% Xxxx MAPPING_PARKL_V_L_PWM_1_LEFT = 100% Xxxx MAPPING_PARKL_V_L_PWM_2_RIGHT = 100% Change Mirror Un-Fold Automatically at XX Speed (Binary value in Werte): 3110 ASP_GESCHWINDIGKEIT_AUTO_AUSKLAPPEN werte=14 (12Mph) Change Triple-Blink Count to another Value: 3068 BLINKZYKLEN_ANZAHL_TIPP – Werte = # blinks-1 (4 blinks = werte=3) Turn on Brake Force Flashing with Hard Braking: 3068 ESS_AKTIVIERBARER_AUSGANG = bremsclicht blinkend Turn off Amber Side Markers next to Headlight: 3063 MAPPING_SIDEMARKER_L_OUTPUT set to: OFF 3063 MAPPING_SIDEMARKER_R_OUTPUT set to: OFF Enable Illumination of Exterior Door Handle LEDs when in Reverse 3070OVT_BEI_REUCKFAHRLICHT set to: aktiv Turn on Fog Lights with Welcome Lights: 3063 MAPPING_NEBELSCHW_L_PART_OF_WL set to: werte=01 3063 MAPPING_NEBELSCHW_R_PART_OF_WL set to: werte=01 Activate Rear Fog Lights: (In conjunction with REM Module coding) 3068 NSL_Verbaut = Verbaut Disable Headlight Washers 3080 WW_SCHEINWERFERREININUNG set to: nicht_aktiv Auto Light Sensitivity Increase 3130RLS_DEF_FLC_SCHWELLWERT_SATZ set to: option below 3130RLS_FLC_SCHWELLWERT_SATZ set to: option below Options: normal = mornal empfindlich = sensitive sehr_empfindlich = very sensitive unempfindlich = insensitive Turn On Tail Lights with DRLs: 3063 MAPPING_TAGFAHRL_1_V_L_OUTPUT = tfl_l 3063 MAPPING_TAGFAHRL_1_V_R_OUTPUT = tfl_r 3063 MAPPING_TAGAHRL_2_V_L_OUTPUT = werte=04 3063 MAPPING_TAGAHRL_2_V_R_OUTPUT = werte=04 Activate Rear Fog Lights feature for lighting switch: 3063 Mapping_Nebelschlussl_L_output = nsw_l 3063 Mapping_Nebelschlussl_L_Function = nebelscheinwerfer 3063 Mapping_Nebelschlussl_R_output = nsw_l 3063 Mapping_Nebelschlussl_R_Function = nebelscheinwerfer FLE (43) & FLE (44) ECUs (must completed coding in both ECUs: Euro LED Anti-Dazzle Headlight Coding (part 2): 3003 Stadt_V_Idx set to: F015Wert 3003 SAE_Idx set to: F015Wert 3003 H_plus4_Idz set to: F010Wert_SA552_US 3003 Blendfreies_Fernlicht_Idx set to: F015Wert 3003 Volles_Fernlicht_Lichthupe_Idx set to: F015Wert HKFM_LS Module: *** May take up to 30 minutes to begin working after coding *** Close/Open Rear Hatch from Fob & Kick Panel 3010SCH_FBD set to: aktiv – werte=01 3010SCH_TOEHKI set to: aktiv – werte=01 3010TASTER_FBD set to: aktiv – werte=01 HU_NBT or HU_CIC Module: (Not all available in CIC Headunit) High-Beam Assistant – Auto-On 3000HIGH_BEAM_ASSISTANT set to: aktiv Set cell phone ringer as primary 3001INBAND_RINGING set to: aktiv Enable Siri Voice Control 3003CE_DEVICE_SPEECH_RECOGNITION set to: aktiv Disable Auto-Locking of Doors once begin driving 3000DOOR_LOCK_AFTER_DRIVING_AWAY set to: nicht_aktiv Enable Sports Displays 3000EFF_DYN_SPORT_CID set to: aktiv 3000EFF_DYN_SPORT_UNIT set to: aktiv * To change units displayed to be ft lb and hp KOMBI3008DREHMOMENT set to: lb_ft (displays ft lb) KOMBI3008LEISTUNG set to: ps (displays hp) Enable Turn Signals in HUD 3001HUD_TURNSIGNAL set to: aktiv Change Navi Voice to British English 3000LANGUAGE_ENGLISH_UK set to: master 3000LANGUAGE_ENGLISH_US set to: nicht_aktiv Video-in-Motion activated: 3000 SPEEDLOCK_X_KMH_MAX werte = FF 3000 SPEEDLOCK_X_KMH_MIN werte = FF 3000 VIDEO_HANDBRAKE set to: nicht_aktiv 3000 VIDEO_FRONT_LOCKED set to: nicht_aktiv 3000 VIDEO_SPEEDLOCK_CONDITION set to: none=00 Navi Trip-Import 3000NAVI_TRIP_IMPORT set to: aktiv Navi Fuel-Stop Proposal Along Route 3000NAVI_FUELSTOP_PROPOSAL set to: aktiv Enable Video Files from USB 3000ENT_CODEC_XVID set to: aktiv 3000ENT_CODEC_XVCD set to: aktiv 3003API_USB_VIDEO set to: both Add GPS Current Location to Navi Menu Items 3000NAVI_POSITION_MENU set to: aktiv Add Turn-Signals to HUD 3000HUD_TURNSIGNAL set to: aktiv Enable the function of saving video files to NBT Hard Drive for play later 3000 ENT_MC_VIDEO_SUPPORT set to: aktiv Disable Office Function Speed Lock-Out 3000 OFFICE_MESSAGES_SPEEDLOCK_CONDITION set to: nicht_aktiv Enable Full Text Lines in Office While Driving 3003 PIM_DRIVING_TEXT_LENGTH set to: whole text_07 Disable Audible Chirp/Beep When Locking Car 3000 ACOUSTICAL_LOCK_CONFIRM set to: nicht_aktiv Enable Speeach Input for E-Mail or SMS 3003 SPEECH_2_TEXT set to: aktiv Enable Time-Stamp Display for Call Log 3003 TIMESTAMP_DISPLAY set to: aktiv Add Temperature & PSI to tire monitor screen 3001RDC_SAFETY set to: aktiv Disable Legal Disclaimers 3001LEGAL_DISCLAIMER_TIME set to: kein_ld 3001MACRO_CAM_LEGALDISCLAIMER set to: kein_ld 3001MACRO_NIVICAM_LDISCLAIMER set to: kein_ld Change i-Drive Animation to ///M Logo 3001STARTUP_EMBLEM set to: variant_01 Enable IPCE Web Server @ 172.16.222.1 3000IPCE_WEBSERVER set to: aktiv Enable WiFi Hot-Spot (Need to install a DLNA/UPnP media sharing server on your laptop or phone to be able to use this) 3000ENT_MC_WLAN_STREAM_DMP_COVERART set to: aktiv 3000ENT_MC_WLAN_STREAM_DMP_VIDEO set to: aktiv 3000ENT_MC_WLAN_STREAM_DMP set to: aktiv 3003WLAN_STATUS set to: aktiv 3003WLAN_MODUS set to: ap 3003WLAN_SIGNAL_STRENGTH set to: outdoor Enable Developer Menu 3000 ENTWICKLER_MENUE set to: aktiv 01 IHKA Module: A/C System Remembers Last Setting 3000OFF_MEMORY set to aktiv-werte=01 Always Remember Air ReCirculating 3000MEMORY_UMLUFT set to: aktiv KAFAS2 Module: High-Beam Assistant – Auto-On 3050FLA_ON_OFF set to: aktiv – werte=01 KOMBI Module: Show Digital Speed in MPH in Cluster 3000BC_DIGITAL_V set to: aktiv-werte=01 Show Turn Signals in HUD 3008HUD_PIA_BLINKER set to: aktiv 3000BLINKER_HUD_ENABLE set to: aktiv Enable GPS-Sync for Clock 3000GPS_UHR set to: aktiv PMA_PDC Module: Enable Rear-View Camera at all Speeds 300BD_SCHWELLE_2_KMH set to: Werte = FF 300BV_SCHWELLE_2_KMH set to: Werte = FF http://bmw-f-coding.blogspot.com/ |
| Bookmarks |
