06-19-2016, 04:24 PM | #1 |
Rep 193
Wheel weight
Being new to a Z4 I'm finding it very hard to source information about anything on the car. My question today is does anybody know the weight of the stock 17 x 8 wheel. My car is a 2010 3.0. Hard to look for lighter alternative wheels when you don' t know what the stock ones weigh.
06-20-2016, 06:35 AM | #3 |
Rep 184
OZ Ultraleggera in 19" seems to by an "ultra" lightweight solution.... my Z4 got a set...
Daily:330ix 6MT - PBX, HR SportSprings, Koni Yellows, OZ Ultraleggera 18", PI+PE, CDV off, UUC sways, M235i SportBrake (front), Cquence rotors (rear), 3.64 diffs, LSD rear
Funcar: Z4 3.0i 6MT - HR SportSprings +sways, OZ Ultraleggera 19", 5.00 diff by Drexler, CDV off, Quaife LSD, M235i SportBrake (front), Cquence rotors (rear) |
06-20-2016, 08:41 AM | #4 | |
Rep 1,668
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
06-20-2016, 01:20 PM | #5 |
Rep 679
My guess is that due to the overall $$ of the car, as well as many of us having extended warranties, that data will eventually trickle out here as those run out. There is a ton of data on the n54 on other forums - so all is not lost....
06-20-2016, 04:04 PM | #6 |
Rep 173
Check out this link for the different wheels with weights available for BMWs. TireRack will give you the weight of the tires.
http://www.bmwstylewheels.com/Z/Z4-E89 Typical wheel for 2010 3.0 runs about 12 kg (26.4 lbs). Then add on the RFTs, another 26 lbs for Potenza RE050 and you've got yourself a pretty heavy set up. |
