09-20-2016, 05:57 AM | #1 |
sportscars only
3291
Rep 3,211
sun visor-spring broken?
The passenger side one if that matters. When it was being pulled down, heard a large 'SNAP' like an internal spring broke or something. There is still some tension when moving the visor but not as taut as the undamaged one. Have you guys come across this and can I open it up to fix myself? Tx.
10-05-2016, 08:29 AM | #4 |
Rep 1,668
no but i get most parts from GetBMWparts.com Look for interior parts and i suspect you can find a replacement visor.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
10-05-2016, 09:36 PM | #6 |
Rep 906
Drives: 2008 535xi / 2011 Z4 35Is
Called a torx bit. They are used all over the car. Buy a set of screw driver bits so you can work on things more difficult than a sun visor when the time comes.
Go to Amazon and search on "torx bit set" and you will see some options. |
tranquility3290.50 |
10-06-2016, 03:45 AM | #8 |
Rep 157
No pita - Torx screws are very common here and have several advantages over hex, cross head and of cours flat head screws (http://bit.ly/2dGMHTZ)
10-06-2016, 07:51 AM | #9 |
Rep 906
Right on Mick!
These are not security screws. These screws are used on everything. I use them in woodworking and home improvement projects a lot. Life is more than terrible Philips head screws! |
10-06-2016, 05:09 PM | #10 |
sportscars only
3291
Rep 3,211
Tx for the heads-up. Yup, I found the bit in my drill set. Will try again.
