M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Regional Forums > ASIA
      11-27-2016, 05:26 PM   #1
Philip Park
Philip Park's Avatar
South Korea
7
Drives: F10 m5 2013
Jb4 M5 - Sae Dyno Test On South Korea
yesterday i run dynotest wiy my F10 M5 2013 JB4 SETTING
RUN S.A.E MODE
NOT STD MODE....
Run result
runfile 0,1 : JB4 MAP1 SETTING 615~626HP / 83~84TORQUE
runfile 2 : JB4 MAP4 (OEM STOCK SETTING ) 515HP / 72TORQUE
runfile 3 : JB4 MAP2 SETTING 547HP / 75TORQUE
I think jb4 map2 program is something is trouble on my m5
sometimes i run map2 is over 6000rpm~ when its stop here 1seconds
and run overflow.... it
i think it's transmission is slip or A.F.R IS some need it..or fuel cut ?
http://blog.naver.com/rpm8300/220871230699
here is my blog on south korea have dyno video and more my data
      11-27-2016, 05:42 PM   #2
ARC550
Drives: M3, X5, 720s, X5, 750xi
RUN S.A.E MODE
NOT STD MODE....
Run result
I had same results.. Map 2. Looks like your having issues with Stock tune. You need a Backend flash to run map 2 without hiccups.
I had same problem.
Also your map 1 was almost identical to mine.
Car is healthy!
      11-27-2016, 06:10 PM   #3
Philip Park
South Korea
7
Drives: F10 m5 2013
I had same problem.
Car is healthy!
sir how to change map2 run flash ?
are you resolve this problem?
      11-27-2016, 08:03 PM   #4
ARC550
I had same problem.
Car is healthy!
You need a Ecu flash to run map 2 successfully. This is rather common.
Once you do that you should see considerable gains over the map 1.
      11-28-2016, 02:00 AM   #5
Philip Park
South Korea
7
Drives: F10 m5 2013
I had same problem.
Car is healthy!
so you mean ecu resetting mean ? from bmw service center ?
or jb4 cand reflash it ?
      11-28-2016, 08:09 AM   #6
ARC550
I had same problem.
Car is healthy!
You need a Tune.
You need an aftermarket tune from a reputable company.
      06-08-2017, 12:11 AM   #7
hjl113
hjl113's Avatar
South Korea
17
Drives: F10 M5
필립님, 저 니M이다에요 ㅎㅎ
2번 맵 문제없이 쓰려면 결국 맵핑을 하라고 하네요...
근데 맵핑하면 JB4가 필요한지 ㅋㅋ
m5post
