12-13-2016, 03:08 PM | #1 |
Rep 258
0W-40 motor oil for bmw z4 4 cylinder?
i've had a few auto shops tell me for my 5 series and z4 to NOT use 5w-40 but rather to use 0w-40. i live in LA in mild weather. can anyone confirm this?
12-13-2016, 07:16 PM | #3 |
Rep 2,387
0W-40 is the euro oil weight recommended for bmws. There is NO benefit of using this over 5w-30. They both cover the same temperature ranges. I use euro formula because I want to use Amsoil and that's the oil they make that's suitable for BMW. Your service guy is whack.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
12-14-2016, 01:33 PM | #4 | |
Rep 258
longlife-01 longlife-01 FE longlife-01 is 0w-40 compatible http://www.costco.com/Mobil-1-Advanc...100169676.html Last edited by cruisingdownthestreet; 12-14-2016 at 02:02 PM.. |
01-30-2017, 07:30 PM | #7 |
Rep 258
i did my research and Mobil 1 SAE 0w-40 is longlife-1 (LL-1) compatible for both my dad and my BMW.
01-30-2017, 09:15 PM | #8 | |
537
Rep 2,825
a 0w shears quicker then a 5w and regardless of the "winter" W designation, a thinner oil cannot protect your engine at full operating temp as well as a 5w would. a 5w will make your engine run quieter and smoother, as well as maintain temps under a variety of driving/ weather conditions. trust me, you shouldnt use anything else but specifically what the manual specifies. all this 0w drama was started with the strict CAFE requirements in north america for emissions and fuel economy purposes. I suggest you read up on CAFE and dont fall for this bullshit.. |
01-30-2017, 10:11 PM | #9 | |
Rep 258
https://mobiloil.com/en/product-selector?Year=2013&Make=Qk1X&Model=WjQ%3D&Engine=c 0RyaXZlMjhpIDQtQ3lsIDIuMCAoTjIwQjIwQSkgKEdBUyk%3D
01-31-2017, 07:30 AM | #10 | ||
Rep 2,387
Tangent303.00 |
01-31-2017, 08:33 AM | #11 | |
537
Rep 2,825
but a 0W is overall thinner then a 5w. theres no magical chemistry at play here, an overall thinner oil will not protect your engine as well as a thicker one would. if the W weight only applies for cold weather, why is there such a big difference between the two, *even at operating temp* Like i told the other guy, I strongly suggest you read up on the north american CAFE Requirements. you will note that ONLY north american spec'ed engines, and not a single other place in the world requires a 0w oil. even russia, with its frigid temperatures still spec's a 5w. your engine isnt going to be running cold forever. I am simply giving you a heads up because BMW's have looser bearing clearances (to run thicker oil and thus therefore protect critical parts like rod bearings better) and also control oil temperature more effectively. http://syntheticperformanceoil.com/s...es/5w20oil.php if you are interested in learning more about the CAFE requirements, here is a great starter link. |
01-31-2017, 08:36 AM | #12 | |
537
Rep 2,825
if the newer owner manuals suddenly spec a 0w, you are telling me that BMW specifically re-engineered all of their rod bearings with tighter clearances to safely spec a 0w? that doesnt make any sense. again, you didnt read up on the CAFE requirements. |
01-31-2017, 09:20 AM | #13 |
Rep 2,387
Back a couple of years ago when BMW used castrol as their BMW labeled oil, they recommended castrol as an acceptable alternative. But it was the castrol euro formula, which was 0W-40.
My point about the oil viscosity is that 0W-40 is thicker at full operating temp then 5W-30 because a 40 weight oil is more viscous than a 30 weight. Your subjective findings about sound and smoothness aside, that is the property of these oils. In Europe, the 5W-30 oils made by European companies are LL-04 (Check Amsoil, Elf, liqui-moly, etc). LL-04 oils are made for cars running on low sulfur gasoline, which we don't have in the US. This is why 0W-40 is recommended here as an alternative, because it's the required LL-01 spec. Conversations about motor oils always draws a lot of opinions. Use what you like.
02-01-2017, 11:43 AM | #14 | ||
Rep 587
I've been running nothing but Mobil1 0W-40 in So Cal ever since I bought my E46 years ago. It's now at 243,000 miles and purring like a kitten. The last time the valve cover was off at around 215,000 miles when I replaced the VANOS seals it looked shiny and clean under there.
Here's a link (pdf) to a BMW document that shows their approved oils. Quote:
