02-07-2017, 12:01 PM | #1 |
Rep 4
Drives: BMW 135i
Why everything M3 or E9x and not 1M im confused (E82 Owner)
Hallo, its my first post so be gentle with me please im a virgin
So i spend 3-4 hours trolling this forum for information on how to best upgrade my: 135i 2008, suspension, as it sucks so much.. Now pretty much every post is about M3 or E92 or E93 this and that.. What are we not using the 1M parts? Are the M3 parts better, and what M3 is this then ? E46 or E92 ?? So what i want to change is: Diff: QUAIFE Suspension: KW Clubsport 2 way incl camper plate, so actually 3 way adjustable, but they call it 2 way, don't know why.. Rear subframe bushings: (2) bmw #33312283382 (2) bmw #33312283383 Gearbox bushing: 2 Stk bmw #22322282340 Rear Suspension Arms: i was thinking the 1M ones ????? or are the M3 better? 3 stk per side... Front Suspension Arms: i was thinking the 1M ones ????? or are the M3 better? 2 stk per side Sway Bars Front And Rear, Again i was thinking 1M but are the M3 better or ?? I hope some one can clarify those things and guide me the right way, i really really want to make my order with BMW tomorrow so i can get those things installed and it can be a popper car, not this funky handling stuff haha.. Cheers.....
Thanks
BG |
02-07-2017, 12:40 PM | #2 |
Rep 4
Drives: BMW 135i
It seems i missed this post in my searching and reading.. http://www.1addicts.com/forums/showt...ht=33322283547
So from this it seems most numbers are the same as the 1M only This: 34522283017 - Rear ABS/BVA tube bracket - 2 And the sway-bars seems to be different, all the rest are the same items if its 1M or M3(E9x) So my complete order would look like this and i should be good i hope, any one see issue here or mistakes?? Sway Bars:……………………………………………….... Front ARB (FSB) E93 31352283965 - Stabiliser, front, D=28MM – 1 31352283967 - Rubber mount, stabiliser, lower section – 2 31352283968 - Rubber mount, stabiliser, upper section – 2 31352283037 - STABILIZER SUPPORT – 2 33326768884 - Hexagon nut with collar, M10-10 ZNS3 – 4 Rear ARB (FSB) E93 33552283962 - Stabilizer, rear, D=23,6MM – 1 33552283709 - Rubber mount, stabiliser, lower section – 2 33552283710 - Rubber mount, stabiliser, upper section – 2 33552283714 - STABILIZER SUPPORT – 2 Front suspension stuff 1M:…………………………………. Front Wishbones and tension struts 31102283575 - LEFT tension strut WITH RUBBER MOUNTING – 1 31102283576 - Right tension strut with rubber mounting – 1 31102283577 - Wishbone, left – 1 31102283578 - Right wishbone – 1 Rear suspention stuff 1M: …………………………………………... Rear Wishbones and guide arms 33322283547 - Guide arm, left – 1 33322283548 - Guide arm, right – 1 33322283545 - Wishbone, left – 1 33322283546 - Right wishbone – 1 34522283017 - Rear ABS/BVA tube bracket - 2 (From E9x only non 1M) Rear subframe bushings 1M:……………………………. 33312283382 - Rubber mounting front – 2 33312283383 - RUBBER MOUNTING rear – 2 Gearbox 1M:……………………………………………………. Gearbox supports, from m3 e46 they say are good.. 2 Stk of each below. 2 stk. 22322282340 Sechskantmutter mit Scheibe M8 (22316760944) Unterlegscheibe D=8 (07119907030) Sechskantmutter mit Scheibe M8 (07129904862) Sechskantmutter M8 (07119905515)
Thanks
BG Last edited by BrownGhost; 02-25-2017 at 05:59 PM.. |
02-07-2017, 05:58 PM | #4 |
Supreme Allied Commander
3885
Rep 54,481
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
E82 1M and E9x M3 are basically the same suspension and brake wise.
02-07-2017, 07:23 PM | #6 |
BMW Fan
290
Rep 838
1M was a very limited production run made by raiding the parts bin for the e9x M3. That's why you won't see many used 1M parts around. e9x M3 are plentiful.
Since the 1er is basically a short wheelbase 3er the drivetrain and suspension parts are nearly all interchangeable.
2012 135i Mods: air scoops, CP, K&N filter, PS1, ADE FMIC, BMW PE, JB4, 1M front body, full M3 suspension front and rear, M3 brakes front and rear, M3 rear subframe and LSD
Owned so far: 88 M3 x 2, 95 325is, 95 M3 x 2, 06 Mini Cooper S, 08 335 xi, 09 Z4 35i, 01 M3, 12 135i |
02-08-2017, 01:04 PM | #8 |
Rep 4
Drives: BMW 135i
Ohh great information, thanks to all, that explains a lot
ill go ahead and order my parts now, cant wait till its all installed, going to be great
Thanks
BG |
02-08-2017, 01:28 PM | #9 |
Rep 3,071
If you dig around there is a 1addicts member who did a TON of testing on the M3/1M suspension parts vs e82 parts. He's an engineer and provided an amazing amount of info and knowledge. Some m3 parts have benefits. Some don't.
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
02-25-2017, 05:53 PM | #10 | |
Rep 4
Drives: BMW 135i
-------- To all with 1 series 135i, DON'T buy lover control arms rear 33322283549, they don't fit from the 1M or M3 parts!!! WAY WAY to short..
Thanks
BG |
