02-20-2017, 10:13 AM | #1 |
Rep 570
DYI Brakes replacement F15?
Hello,
I just passed my 50k mile mark and getting close to needing new brakes...The Dealership tries to sell me on another 1year 25k maintenance plan which would run me about $1400, and at my driving....good for another 7months or so... They said if I would bring it in without the plan it will run me about $3500... now the questions... Has anybody done their own brakes, pads/disc repalcement...and if so where did you get the parts? Can the mile indicator be reset without running ISTA, not that that would be a problem...Brake Fluid drain...OEM...Aftermarket... Did anybody maybe even find a step by step instruction... I have done brake replacement on older cars but not quite sure if there might be something that needs to be considered...electronics ect... Thanks for your input! Also does anybody know if there is anything additional or different to the E70? Last edited by MrTookies; 02-20-2017 at 10:40 AM.. |
02-20-2017, 10:53 AM | #2 |
Rep 1,547
Have you physically checked the life on the pads? I reset my service indicator twice before I did the MPBK on my F15, still had lots of life left on the pads. For sourcing the parts when the time comes, all depends if you want to go OEM or aftermarket. getbmwparts.com is a good place to start. I have a good relationship with my local dealer and the Parts Manager gives me good prices, so I buy local when needed. After you do the brakes, you'll just need to reset the service indicator.
1230vani652.50 |
02-20-2017, 10:59 AM | #3 | |
Rep 570
Is OEM the best way to go here? I know sometimes aftermarket have benefits as well. |
02-20-2017, 01:36 PM | #4 |
Rep 554
Here ya go. I did the DIY on my last car (535i GT) and it's pretty simple. It's pretty much the same for all BMW's. Stick with BMW rotors. They're 2 piece and much lighter than aftermarket cast ones. You can go with EBC, Akebono, Brembo pads if you're looking for something different.
http://www.bimmerfest.com/forums/sho...d.php?t=932538 http://www.bimmerfest.com/forums/sho...d.php?t=934641 |
02-20-2017, 01:57 PM | #5 |
Rep 211
I just did the rear brakes and rotors on my 2014 X5. Used akebono euro pads and Zimmerman zcoat rotors. Easier than expected, I was worried about the e-brake not allowing the piston to be retracted. Turns out the parking brakes on the F15 are the inner drum type. The ebrake actuates them and not the actual regular disc brake so you can compress the piston in just like any other vehicle. Also learned how to reset the brake pad wear indicator. turn the vehicle to on but do not start. hold odometer reset switch until display appears, select appropriate pads reset(35000 kms). Hope that helps.
02-20-2017, 03:11 PM | #6 | |
Rep 570
02-20-2017, 03:12 PM | #7 | |
Rep 570
02-21-2017, 07:00 AM | #8 |
Rep 211
The oem pads were toast at 57000Km. That is not good for rears. On every vehicle I have ever owned the rears last twice as long as the fronts. I asked the service why the rears are worn out so early and the fronts are still good, he said because of the dynamic AWD system. It applies the brakes in turns even when you aren't on the brake pedal...lol I call BS as that being the reason they are worn. I think they must have stuck a bit OR more likely they are just below average pads. I also wanted to make sure to have minimal brake dust, the akebono euro do not give off much at all. Didn't save any money VS OEM high quality aftermarket parts are not cheaper.
MrTookies457.50 |
02-21-2017, 11:29 AM | #9 |
Rep 554
On almost every BMW (at least with the 5,6,7,X series cars), you'll end up going through around 2 sets of rears for every 1 set of front pads, both with RWD and AWD. I went with Akebono pads mainly because of brake dust. I have aftermarket wheels and with the OE pads, the wheels were constantly dirty. After installing the Akebono pads, there was hardly any brake dust.....like my wheels looked clean even 2 weeks after washing. The downside, at least in my experience, is that I felt the braking power was, somewhat, sacrificed. It didn't have the bite like the OE ones, especially, for such a heavy vehicle. I went with Zimmerman rotors also and they were fine. Rotors are rotors. The Zimmerman ones are German made, 1 piece cast so you'll add about 3-5 lbs per wheel compared to BMW's OE ones. If I were to do it again on my current car, I'd go with drilled rotors (for looks mainly) and EBC red pads for stopping power.
02-22-2017, 05:48 AM | #10 | |
Rep 10,185
E39 and back used fronts up first
BMW if you are reading, I need a job, Please. |
03-27-2018, 11:49 AM | #11 |
Rep 3
Has anyone tried to change rear brake pads on F15 or F16 (2015 and above models). Are there any instructions? It seems that the Electric Parking Brake system is a bit different on the newer models.
03-27-2018, 01:58 PM | #13 | |
Rep 18,715
It is not like the 5/6/7 series where it uses the rear brake system itself for the E-Brake.
03-27-2018, 03:55 PM | #15 |
Rep 1,915
03-27-2018, 04:47 PM | #16 |
Rep 272
Get new sensors.
Duke
2018 X5 50i 2015 911 C2S 2017 X4 M40i (gone); 2010 X5 (last of the NAs); 2007 550i (still missed, except in the snow); 1991 525i manual (great 17-year run) |
03-27-2018, 08:49 PM | #17 | |
Rep 18,715
It is a simple closed loop sensor. When the end that sitting inside the brake pads shaved off and break the loop, that's when the light indicator will turn on.
02-09-2019, 11:45 AM | #21 |
Rep 192
I think it would depend on the rotor thickness, but most dealers will replace the rotors or they won't warranty the work. If you have any pulsating when braking I would say you'd want to replace them. I usually just replace them as it's not worth bedding in a new set of pads and then getting a pulsation from the rotors. BUT I've seen some dealership when they CPO a car will just replace the pads and put it out on the line for sale.
mindcontrollerone808.00 |
02-09-2019, 11:50 AM | #22 | |
480
Rep 317
*X5 50i with rotor size 365x36 mm Min thickness 34.4 mm (-1.6mm) *X5 35i with rotor size 348x30 mm Min thickness 28.4 mm (-1.6mm) The Rotors must not have any deviations ie warping or scoring on its surface this is done by sampling 8 diffrent sections on the rotors Also you should run your finger vertically on the braking surface to check for scoring if any you should replace it. *On all X5 max allowed is deviation 0.01 mm If your running metal on metal with your brakes just replace the rotors. most rotors these days are throwaway as they dont have much metal on them in the first place, added that we have extended brake service intervals (50k-60k) by the time its due for brake service the rotors has already worn down for replacement. Min spec Source https://www.newtis.info/tisv2/a/en/f...kes/1VnYNU7dPi |
