11-27-2017, 10:15 PM | #1 |
Rep 1,239
water leak
after a day of heavy rain, I noticed my floor was wet on the drivers side rear passengers floor. any idea where it maybe leaking from that can cause this??
A job is nothing but work.
11-27-2017, 10:41 PM | #3 |
HMFIC
372
Rep 522
Drives: 2016 F80 M3
Had this issue awhile ago. If your finding water on the floor board . The water coming in is from the moisture barrier on the door panel. You need to remove the door panel and behind the panel you will see a foam panel. Around the edges of the panel it is sealed to the metal door frame with a black rubber adhesive sealant. Usually you can pull the foam back on the edges and find out where it's loose and not sealed good. Once you find the spot use some acetone on a rag and gently wipe the sealant. This will clean it and make it sticky again. Press the foam down firmly against the sealant and it should stick back good to it.
11-27-2017, 10:54 PM | #4 |
Rep 3,141
Drives: 2014 M5 6MT
E90 with a sunroof- its the sunroof drain tubes, they are clogged.
E92 it's the door seal above the window. I've seen it get stiff, and not seal against the glass.
2014 M5 6MT
11-28-2017, 08:23 AM | #6 |
Rep 56
Had this same issue right after I bought the car, of course it had poured for a day while I was at work so it was terrible.
I took it to BMW the next day, it cost a $1,000 dollars and they said it was the Sun roof drain plus the door seals, they did a really good job cleaning up the mess and drying out the carpets and it hasn't leaked since and I keep checking because it was a nightmare. I asked more about what it was but the service reps really don't know what was done in detail which I can understand to a point, but I wish they could explain in more detail how this happened... |
12-12-2017, 11:27 PM | #7 |
Rep 15
I am having a similar issue. Rear driver foot well is very wet after heavy rain. I have checked the door vapor seal and it is fine. Can anyone explain how they unclogged the sunroof drains or if they found any other causes? Thanks!
