      02-18-2018, 02:48 AM   #1
Live4USMC
Live4USMC's Avatar
86
Drives: 2024 IX/2006 Z4 3.0SI
Problem with autohold
My x5 50i lurches forward approximately 6” when I’ve come to complete stop with the auto hold on and then let off of the brake pedal. It stops again on its on and stays stopped. This is a recent development and I was wondering if anyone else has had similar issues and if the dealer has been able to rectify this.
Thanks
      02-18-2018, 10:20 PM   #2
spike5150
Drives: 2020 X5 M50i
Mine had done this since day one. Is more pronounced the colder it gets. Dealer has been unable to reproduce, so I have had to live with it for 57,000 miles and counting. June 2015 50i.
      02-18-2018, 10:49 PM   #3
Live4USMC
Live4USMC's Avatar
86
Mine is temperature dependent as well. It was 65 degrees today and it worked fine. Cold weather seems to cause this issue.
      02-19-2018, 10:24 AM   #4
turboawd
1685
Drives: 2015 X5 35i
What exactly is holding the vehicle? Parking brake? One of the calipers?
      02-19-2018, 11:48 AM   #5
CeeTeeX5
Tried the auto hold for the first time this morning in 38f temperature and no lurching forward. Maybe this was fixed in a sw update?
2018 X5 35i M-Sport
Dinan Stage 1 Tuner
M-Perf Exhaust and lip
2018 X1 28i M-Sport
      02-19-2018, 04:57 PM   #6
spike5150
My wife's 35i built one month later does not exhibit this problem.
      02-19-2018, 05:43 PM   #7
CeeTeeX5
Interesting, might just be a 50i issue. All those ponies just don't want to be held back!
2018 X5 35i M-Sport
Dinan Stage 1 Tuner
2018 X1 28i M-Sport
      02-19-2018, 10:08 PM   #8
IndyJer
Drives: '17 F15 MSport
'16 F15 XLine  [0.00]
'17 F15 MSport  [0.00]
Parking brake.
I keep the brake pedal pressed until I feel the parking brake engage and then lift off. No lurching for me.
      02-20-2018, 07:32 AM   #9
DuSh
DuSh's Avatar
2184
Drives: F15 X5 50i
Originally Posted by IndyJer View Post
Parking brake.
Are you certain? I've read that Auto Hold uses regular brakes and NOT parking brake (which makes sense btw as parking brake is too slow to engage and disengage to be used constantly in stop and go traffic). I've heard that Auto hold only uses parking brake as a failsafe last option
      02-20-2018, 06:58 PM   #10
IndyJer
As certain as anything else you hear on the inter webs... I’ve not looked at the regular brakes with auto hold engaged to see if they’re used, but I am assuming it’s the parking brake since the parking brake symbol lights on the dash when autohold is engaged and the vehicle is at a stop. See near the 2:37 mark of the video...
      02-21-2018, 07:36 AM   #11
absolutegtr
Drives: 2015 X5 35i M-sport
I believe the autohold uses the front brakes. I say this because just once there was a minor glitch when using the autohold in heavy traffic. And I tried to accelerate and I could feel the front brakes still grabbing. (Happened very quickly)
Also in my X5 with ACC STOP AND GO the car will stop itself and hold itself stopped by itself using (obviously) the front brakes.
      02-21-2018, 08:49 AM   #12
CatalinP
Drives: BMW X5 F15 2014 3.0xd
Automatic hold function
The automatic hold function is activated using a button behind the parking brake button. The button is connected to the Dynamic Stability Control (DSC). When the function is selected, the vehicle is hydraulically braked from the first application of the brake by the DSC until it comes to a complete halt. When the engine is switched off, the parking brake assumes the holding function.
Pressing the accelerator pedal releases the wheel brakes. The vehicle begins to move. The automated braking and release process supports driving in urban traffic or in jams, for example. Automatic releasing of the brake is also possible outside the automatic hold function.
https://www.newtis.info/tisv2/a/en/f...-brake/XokjYm0
      02-21-2018, 08:52 AM   #13
CatalinP
That is not true. While the engine is running, the brakes are automatically applied to all 4 wheels. If the engine is stopped, then the "hand brake" is engaged on the rear wheels.
DuSh2183.50
      02-21-2018, 09:16 AM   #14
DuSh
DuSh's Avatar
2184
Drives: F15 X5 50i
That makes sense - all 4 brakes for autohold and parking brake if engine is off (since pump is not working for regular brakes with engine off). So any surging forward like OP has during autohold is due to either bad sensor or some module or worn brakes (highly unlikely that all 4 brakes get so worn that they can't hold on autohold)
      02-22-2018, 10:48 PM   #15
spike5150
I’ve got mine in for scheduled maintenance and asked them to look at the auto hold again. It’s in the 20’s here so they better be able to reproduce it this time. Will let you know if they figure it out.
      02-23-2018, 04:46 PM   #16
spike5150
Well they were able to reproduce the problem but no clue hoe to fix it. They are starting a PuMa case with BMW so my x5 is a hostage for the weekend.
      02-23-2018, 06:24 PM   #17
absolutegtr
Right.....That’s exactly what I just said...
Edit* and by ‘front’ brakes I was implying all 4 wheels and NOT the handbrake. This system is quite similar to the Mercedes HOLD function
      02-24-2018, 02:17 AM   #18
CatalinP
Yeah, right, front brakes = all 4 wheels.
      02-28-2018, 12:50 PM   #19
spike5150
Update - They said the problem is with the DSC and Hydraulic module. Special order parts from Germany +/- 2 weeks. I get the car back this afternoon for now - will try to get the PUMA case number for others with this issue to reference.
      02-28-2018, 06:50 PM   #20
spike5150
Thanks
Hope it helps you out - my PUMA case # is 64073055. Now waiting on parts from Germany for +/- 2 weeks, so not necessarily resolved yet. My paperwork says it is $4,000 worth of parts, but covered under warranty since I first brought up the issue when I was still in warranty.
      03-23-2018, 07:16 PM   #21
spike5150
Well, they replaced the DSC stuff and still not fixed. Had a Regional Tech look at it today, and he claims it is normal. I am calling BS on that! Might have to escalate to BMWNA.
      01-20-2019, 03:45 AM   #22
utsc
Drives: 2015 BMW X5
Issues with Auto Brake Hold
Did you get the problem resolved ?
