      02-20-2018, 08:58 PM   #1
Killacam13
Drives: 2018 X5 sdrive 35i
Removing the emblem on trunk
I ordered black carbon emblems and was trying to replace. I got the front hood one replaced easily but having a hard time getting the trunk one off. Is there aan easy way to remove it? Thanks
      02-20-2018, 09:14 PM   #2
1coolF15D2017
Drives: 2020 X5 G05
Use a flexible plastic spreader. Like from this link. And donn't forget to put painters tape around the emblem to prevent scratching the paint.
https://www.amazon.com/dp/B0015DMGD0...a-383883421371
      02-20-2018, 09:16 PM   #3
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Yep. Autozone or similar carries this as well. Jam it up in there and gently pry off. Obviously she that tape
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      02-20-2018, 09:24 PM   #4
Killacam13
Even though I'm not removing the whole roundel and taking the inside part off o should put tape around it?
      02-20-2018, 09:42 PM   #5
HomeIn2
HomeIn2's Avatar
Drives: 2020 X5 M50i
Hmm...not sure what you mean by ‘black carbon emblems’ or ‘not removing the whole roundel.’ However, if you are asking about replacing the round BMW trunk emblem, a little warm up with a heat gun or hairdryer before you pry, helps release the factory 2-sided tape.
      02-20-2018, 09:50 PM   #6
IndyJer
Drives: '17 F15 MSport
'16 F15 XLine  [0.00]
'17 F15 MSport  [0.00]
The rear rounder is all one piece, you can’t remove just the center part. It’s a different part than the front hood roundel. It’s held on with double sided tape
      02-20-2018, 09:54 PM   #7
Killacam13
Oh, I didn't know. I bought this thinking I can replace.
      02-20-2018, 09:57 PM   #8
IndyJer
Yea different for the rear. You could make a necklace out of the spare or better yet buy another bimmer to stick it on.
      02-21-2018, 12:30 AM   #9
atomic80
Drives: 997TT
The rear was a bitch to take off...it's mainly because of the adhesive that's behind there. I used fishing line first to pry those off before using the trim removal tool to get it off! I did put blue tape around after using the fishing line.
      02-21-2018, 12:57 AM   #10
Doanster
Doanster's Avatar
628
Here you go,OP.
http://f15.bimmerpost.com/forums/sho....php?t=1112728
      03-05-2018, 11:31 PM   #11
Killacam13
Just went with the blacked out front and back from Ind, it was very easy to remove the back roundel. Thanks!!
      03-06-2018, 06:56 PM   #12
IndyJer
Looks great! Now you need the blacked out X5 emblem on the back, or de-badge it, to complete the look.
Copyright ©2000 - 2025, vBulletin Solutions Inc.
