      10-19-2018, 10:55 AM   #1
JimmyZ06
JimmyZ06's Avatar
Drives: 2022 X5M Comp
Ceramic Front Brake Pads for F85 X5M ?
Brake dust is unbearable! Does anyone know if these exist? If so, who make them and please share part #'s. I will never buy Carbotech for the street again so please save that suggestion.
2022 Marina Bay Blue X5M Competition
      10-19-2018, 11:29 AM   #2
dorian
Drives: 2017 X5//M
I know zero about them...but once found these:
http://www.shopebcbrakes.com/EBC-Red...ubmodel12_key=
640ijims192.50
      10-19-2018, 01:18 PM   #3
JimmyZ06
JimmyZ06's Avatar
WOW! You did better than me. I wonder how good they are??
Thank you Dorian!
      10-19-2018, 02:27 PM   #4
JimmyZ06
JimmyZ06's Avatar
I found StopTech #105-12940 too
      10-19-2018, 02:50 PM   #5
dorian
Drives: 2017 X5//M
I don't see correct year on those.
thezarb14.00
      10-19-2018, 02:57 PM   #6
Bobby_Drake
Bobby_Drake's Avatar
390
Drives: '16 X5M
https://www.powerstop.com/product/po...W&mo=X5&ss=X5M
F10 M5 guys have some good reviews on them. But they only make rear pads for F85.
      10-19-2018, 03:11 PM   #7
dorian
Drives: 2017 X5//M
Sadly the fronts are the relevant pads.
      10-19-2018, 05:28 PM   #8
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
m5 calipers are the same as X5M just different brackets so i bet the pads would fit. wish there was an easy way to test this out.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      10-19-2018, 05:33 PM   #9
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
tire rack sells them and theyre on ebay. They're centric posi quiet semi metallic
'06 C55 AMG (sold)
      10-19-2018, 05:41 PM   #10
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
these are listed for the 50i not the F85 on the websites
'06 C55 AMG (sold)
      10-19-2018, 06:24 PM   #11
dabimmerman
Drives: 2022 BMW m850i
The X5m has slightly different pad shapes on the front. Found this out when I tried to use some carbotech pads for an m5. The calipers are the same, but the rotors are slightly bigger on the X5m and thus the pads are slightly wider. The length and thickness is the same but it is a little wider to cover the larger rotor. You could run m5 pads, but there will be about 3/4 inch of rotor that won’t be swept (area closest to hub).
      10-19-2018, 06:37 PM   #12
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
The X5m has slightly different pad shapes on the front. Found this out when I tried to use some carbotech pads for an m5. The calipers are the same, but the rotors are slightly bigger on the X5m and thus the pads are slightly wider. The length and thickness is the same but it is a little wider to cover the larger rotor. You could run m5 pads, but there will be about 3/4 inch of rotor that won't be swept (area closest to hub).
If you used F85 pads on them it wouldn't cover but it would cover completely going the other way around. the M5 rotors are only 5mm in radius wider (395 vs 405) which would be about .2" which isn't significant by any means. Which makes me curious! Lol
'06 C55 AMG (sold)
      10-22-2018, 07:45 AM   #13
JimmyZ06
JimmyZ06's Avatar
Exactly!
      10-22-2018, 07:47 AM   #14
JimmyZ06
JimmyZ06's Avatar
Yup, you are correct sir. Thanks.
      10-22-2018, 07:56 AM   #15
JimmyZ06
JimmyZ06's Avatar
Those would probably eat the soft BMW rotors. I ordered the EBC's and will let y'all know how it turns out. I felt like the F10 M5 caliper were the same ( didn't know but looked the same) but BMW and the local Bimmer shops said the pad was different. Size of the F85 rotor makes that make sense.
      10-22-2018, 03:16 PM   #16
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Ah perfect. Why do you think the poi's centric would eat through the F85 rotor? I was thinking of ordering both the EBC pads and front rotors as they're hella cheaper and a decent brand.
'06 C55 AMG (sold)
      10-22-2018, 04:43 PM   #17
JimmyZ06
JimmyZ06's Avatar
EBC pads and rotors is a great idea.
Had an F10 M5 prior to this X5M. I purchased CarboTech pads 1st for it and they were junk IMHO. Huge waste of a lot of $$ for a terribly loud, cheap looking pad (rattled around in the caliper over any bump). Put PowerStop ceramics (they don't make a pad for the F85 from what I can find) on it and loved them! I feel the BMW stock rotors are "soft" and semi-metallic would chew them up. No personal experience with it, just my thoughts.
      10-22-2018, 04:44 PM   #18
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Had an F10 M5 prior to this X5M. I purchased CarboTech pads 1st for it and they junk IMHO. Huge waste of a lot of $$ for a terribly loud (rattled around in the caliper over any bump). Put PowerStop ceramics (they don't make a pad for the F85 from what I can find) on it and loved them! I feel the BMW stock rotors are "soft" and semi-metallic would chew them up. No personal experience with it, just my thoughts.
Ah just figure oem are semi metallic so it would be similar.
'06 C55 AMG (sold)
      10-23-2018, 01:24 PM   #19
JimmyZ06
JimmyZ06's Avatar
I was told the OEM's are carbon-metallic, hence why they dust sooooo much!
Maverik2594140.00
      10-23-2018, 09:27 PM   #20
enzom
Drives: 18 X5M/20 720S/20 992 C4S
Too bad BMW did not see fit to offer full carbon ceramics on this truck. Had them on my Cayenne and they were amazing. One of the most noticeable differences between this X5M and my Cayenne. Big difference in brake performance and cleanliness of the front wheels.
18 BMW X5M
20 Mclaren 720S Spider
19 X7
20 992 C4S
15 458 Speciale
      10-25-2018, 07:53 AM   #21
JimmyZ06
JimmyZ06's Avatar
FYI, EBC part #DP32091C is the wrong pad for the F85 XM5. Sending my order back today.
      10-26-2018, 10:45 AM   #22
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Lol of course. Rotors too or just the pads? I'm assuming they're for the E70 X5M. Did they just send you the wrong stuff or do they actually not carry pads for the F85/86 which is what I'm assuming since for whatever reason no one makes shit for those brakes. Which I woulda known that before buying them over the MPBK.
'06 C55 AMG (sold)
