11-08-2018, 01:03 PM | #1 |
///M
196
Rep 272
Drives: 2015 F15 X5 50i M Sport
LED Headlights pointing down?
I was doing some basic coding on the Bimmercode app the other week and I've noticed that my headlights are not illuminating as far forwards as they used to. They're now lighting up ~20-30ft in front of the vehicle and it's killing my night driving. It's been more noticeable during my commute since daylight savings ended.
Is there anything I may have screwed up while coding with Bimmercode? I didn't touch anything in expert mode..
2015 F15 X5 xDrive50i - M Sport - Space Grey Metallic - 21" 612M - Accelera Iota ST68's - Black Dakota - Leather Dash - Poplar Wood - Ceramic - Shawdowline - Anthracite - Adaptive M - Full LED - Executive - DA+ - Surround - HUD - Enhanced BT - Soft Close - B&O - ACC Stop & Go - Multi Contour - 4 Zone Climate - Comfort Seats - Cold Weather - Muffler Delete - Akrapovic Tips - F85 Grille - 35% Tint - BMW All Weather Mats -- Missing DHP, NV, Active Steering, Rear Entertainment, & Cooled Seats
11-08-2018, 01:16 PM | #2 |
Rep 11,857
Drives: MY24 G01 AW Msport
what did you code?
do you see them move when you turn on the car in mornings? |
11-08-2018, 02:06 PM | #3 |
1152
Rep 2,426
If you did VLD, it will point down and wide for slower driving.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
11-09-2018, 09:15 AM | #4 |
///M
196
Rep 272
Yes, they go through the initial startup movements like they always have. And they still move left/right with the steering wheel.
11-09-2018, 09:17 AM | #5 |
///M
196
Rep 272
I was looking intro VLD but did not code it. At least I don't think I did? I am second guessing myself at this point... Regardless, the light beam they are putting out just seems to be unacceptably low
11-09-2018, 09:21 AM | #6 | |
80
Rep 360
2010 335i Rwd 6spd
MHD Wedge tune, VRSF Exhaust,FMIC, DP and CP, PR Inlets 2014 X5 50i BMS stage 1, Dinan intake, F85 Knee Bolsters |
11-09-2018, 12:20 PM | #7 | |
Rep 648
Drives: 2016 F15, 2015 F83
Start the vehicle. Turn on the headlights, low beam only. Now toggle back and forth between low and high beams and observe the left headlight beam. Did it move to the right with the high beams on and then to the left with low beams? If so, you have VLD. You can also observe the beam moving when you toggle the fog lights on and off, or watch the left beam move towards center at 30mph. All of these are VLD movements.
2016 F15 X5 50i M-Sport
2015 F83 M4 |
11-13-2018, 07:48 AM | #8 | |
///M
196
Rep 272
11-13-2018, 08:16 AM | #9 | |
Rep 190
Drives: 2020
11-13-2018, 09:06 AM | #10 |
Rep 110
If the headlight aim is too low, you can manually adjust the aim with a phillips screw driver. It's the white plastic screw on top of the light on each each side. You can raise the right beam a bit higher than the left beam so that you can see the traffic signs and things on the right side of the road more. Dont raise the left beam too much or you will get flashed by people going opposite direction as this left beam will blind them.
11-13-2018, 12:14 PM | #11 | |
///M
196
Rep 272
But on a serious note - thanks for the suggestion, I'll check it out tonight
Tags |
bimmercode, code, headlights, led |
