11-17-2018, 12:12 AM | #1 |
Old Time Newbie
51
Rep 85
Tire Change
I looked to see if there is any thread that could answer my concerns but after a couple of hours, I can't seem to find what I am looking for.
So I apologize if this is a repeat... I switched from summers to winters today. My summer set-up was a staggered 20" and switched to a square 19". Prior to the tire shop mounting my winters, the tech checked online to "disable" the air suspension. He didn't mention anything about it after the changeover and I forgot to ask if he did. Is it even possible or needed to disable the air suspension during changeovers? Also, after driving about 100meters, a warning came off telling me that my tires are flat while highlighting all 4tires. I knew none of the tires are flat then It gave me an option to reset the sensor which I did and the warning disappeared. Is this expected every time I change tires? How do I check if the air suspension is working? There is no sensor/warning that it's not working after the tire changeover. Thanks for your help guys. |
11-17-2018, 01:43 AM | #2 | |
Rep 2,388
So for air suspension - there is no need to disable anything during simple tire changeover in BMW. Air suspension is perfectly fine and car can be raised without disabling anything and it will readjust itself after car will be lowered down again. Your air suspension is working rest assured - if it was not you would have felt it right away - ride would be teeth shuddering and your car would be slammed like this: |
F15d_RN50.50 |
11-18-2018, 07:53 PM | #4 |
Rep 979
Did you get this sorted out? I know Canadian M cars don’t have tpms I am not sure if other models have them or not as I don’t touch a thing when I swap from summers to winters, just change wheels and drive , no resetting or anything.
11-18-2018, 10:17 PM | #5 |
Rep 2,388
Canadian duders have ABS module counting revs of each tire instead of tpms and thus approximating which tire has gone low. It's more or less exact up to the point - definitely less to worry about when changing tires, but not as helpful as having direct readings of tpms too.
11-19-2018, 04:29 AM | #6 | |
Rep 535
The RDC system keeps a measure of the rotational distance of the tire w/o having the exact pressure value. The idea is that inflated tires should rotate a fixed distance and if you are loosing air, the distance covered by each rotation will change. I have never had to reset this in my X5 when changing from winter to summer, but once needed it to be reset in my 7-series few years ago.
Present: 2014 X5 50i
DuSh2113.50 |
11-19-2018, 04:35 PM | #8 | |
Rep 7,488
Difference betweeen TPMS (RDC) & FTM (RPA) systems
If you don't have TPMS (actual sensors inside each wheel that sends data to a control module)...then you probably have FTM that as stated...uses tire rotation to determine if a tire has lost air. If you have FTM, you still need to reset the system ANY time that you adjust tire air pressure or change tires etc. TPMS (aka RDC system) FTM (aka RPA system)1 = Wheel electronics system, front left
