      03-02-2019, 09:57 AM   #1
rok2774
Drives: X5
Dealer stripped my oil drain plug
They are telling me that they are going to remove the old drain plug and install a larger one on the oil pan?
Is that an acceptable fix or should I push to have them install a new pan? The dealer is the only one who has changed the oil in my X5 thus far....so they are the ones who stripped the bolt.
Appreciate anyone input or thoughts on this.
      03-02-2019, 10:07 AM   #2
CT335xi
CT335xi's Avatar
693
Drives: 2022 x5 m50i, 2005 evo 8
Although and acceptable fix, I would want a new pan. Also I know they will be careful but usually when they install the larger plug it’s usually tapped for bigger plug which means there metal debris, but I’m sure it will be all removed. Good luck
2022 x5 m50i - Dravit grey
2005 evo 8 (current) built 2.3 488/409 mustang dyno
Old stable mates - 87 325i, 88 m3, 90 m3, 97 m3 4dr,
04 325xi, 91 gmc Syclone, 08 335xi, and 13 x3 35i msp
2014 x5 50i msport
      03-02-2019, 10:43 AM   #3
turboawd
1668
Drives: 2015 X5 35i
I'd push for a new pan.
      03-02-2019, 11:16 AM   #4
alphaod
alphaod's Avatar
New pan, gasket, and bolts.
2015 BMW X5 xDrive50i
BMW CCA 509766
cfm56d7b6785.50
      03-02-2019, 11:39 AM   #5
FenixMike
Drives: 2014 BMW M5 Competition
Usually a helicoil or threadsert is stronger than what was originally in there... while I'd also want a new pan if it was my vehicle, chances are, unless you have had every single oil change done there since day one, they are going to say it was someone else's fault, and just occurred while we did the change. That being said, if all your maintenance was done there since day one, let them know it's not normal for the threads to be destroyed on an oil pan, and it's obviously either negligence from a tech over tightening in a previous visit, or from the current one, and you would like the pan replaced.
Although the ocd makes you want it like new, it's common practice with oil pans and won't cause any problems pending they do it correctly. If you want to worry, research how many ford vehicles had to have these installed in the cylinder heads due to stripped plugs
2014 M5 Competition with ESS Tuning Flash
Gone but never forgotten...2015 X5 50i M Sport, 2015 550i M-Sport, 2015 M3, 2014 X5 50i M Sport, 2015 435i M Sport, 2011 550i, 2011 535i
      12-10-2022, 03:16 PM   #6
Snowbunny72
Drives: BMW X5
My dealership stripped my oil plug, didnt tell me, then I found a puddle of oil in the garage. Took it to get it looked at by a local European mechanic who charged $487 to fix what the dealership did. Now the dealership wants to reimburse me only half of the charge. What would you do?
      12-10-2022, 03:52 PM   #7
What you should have done is taken it back to the dealership in the first place.
      12-10-2022, 08:16 PM   #8
crystalworks
crystalworks's Avatar
540
Drives: Many BMW's
^ That.
You're lucky they are offering half the cost.
      12-10-2022, 09:39 PM   #9
G05_FROZN
Insta~ f10_sapphire
172
Drives: BLACK 2015 528I
Originally Posted by crystalworks View Post
^ That.
I would have the dealer install new pan since this is a bmw dealer. Also I wouldn't even take my car back to fix it from them since they are so incompetent that they can't even change oil I would not expect much of a repair of the oil pan. Very risky if you are out of warranty as well they can sabotage the repair risking your cars health. If you in warranty you will probably be fine.
      12-11-2022, 06:24 PM   #10
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
Agree 100%. The dealer should return the vehicle to the original state.
      08-21-2023, 11:38 AM   #11
maddgopher81
Drives: 2016 F15 X5 XDRIVE 35I
I also had a dealer over tighten the drain plug and when I went to change the oil myself, it cross threaded and wouldn't tighten up when I went to put it back. I bought a tap and new plug and re-tapped the oil pan.
      08-21-2023, 03:01 PM   #12
Tomcat_F15_STL
Tomcat_F15_STL's Avatar
191
Drives: BMW F15 & E70
IMHO. No need to get stinky over an oil pan plug. If the dealer performs a proper repair, it will be good as new.
sukhk5272513.00
      08-22-2023, 12:53 AM   #13
tlow98
Drives: 2009 E91, 2014 F15 x35i
Hell, I’m shocked they were honest. That’s a good shop, in my opinion.
sukhk5272513.00
      08-25-2023, 02:53 PM   #14
dyezak
General of the Armies
dyezak's Avatar
Drives: X5M
Oil changes in every BMW require new copper crush rings on the oil drain. Is your dealer going to provide you new crush rings for every oil change?
They should be replacing the pan so you can maintain your car withe proper oil changes including the proper replacement crush rings moving forward.
shimmy232471.00
      08-27-2023, 02:22 AM   #15
suitedcboy
Cattlecar
109
Drives: 16 X5 50i MSport, 21 M50i DHP
Timesert repair is stronger than a new pan. No heli-coil, those are for bolts you install and leave forever like head bolts or valve cover bolt threads. They like to walk out if it is a fastener removed regularly. There are some great rubber o ring sealed drain plugs from several sellers and amazon.
      09-05-2023, 03:48 PM   #16
beattiecj
beattiecj's Avatar
153
Drives: 2012 135i 2017 x5 35i 1988 e30
Agree, get timesert kit and have them insert a steel thread and plug. You can get one on Amazon for $100ish. Will be stronger than the soft aluminum used in the oil pan.
Just use the provided drill bit that prevents any metal particles getting into the pan put the new threads/plug and good to go.
      09-08-2023, 07:44 PM   #17
mikeson
mikeson's Avatar
Drives: 2016 X6 M package
I had same and BMW dealer told me it is very common on F15 and F16. ANd they even have a larger size bolt.
They rethread and installed a larger size bold on my car. (it was the biggest dealer in west coast dealer. Crevier BMW)
ANd since then I don't have any problem so far.
      09-14-2023, 12:14 PM   #18
Laguna Seca Blue
Laguna Seca Blue's Avatar
Drives: E92 N54 MT | 958.1 Cayenne GTS
You do realize that this photo is giving 90% of us hives, right? lol. You have your drain plug lying on your center armrest dripping oil. Why did you bring it inside your car? haha
Edit: Maybe that’s a shadow?
E92 335i 6MT | Balloon White | Black Dakota Leather - Sold
PROcede Rev3 V5 | AE Quad Exhaust | BMW Performance Short Shift Kit | Gunmetal 19" M3 GTS Wheels | BF Goodrich g-Force T/A KDW 2 | AST 4100 Coilovers | Swift Springs F:280 R:560 | ER Charge Pipe | Tial Blue BOV | VRSF 3" Downpipes | VRSF 7" Intercooler
http://www.e90post.com/forums/showthread.php?t=782212
      09-20-2024, 12:56 PM   #19
SunjaKim
SunjaKim's Avatar
119
Drives: 2015 BMW X5 xDrive35i
I've done three oil changes on my wife's 2015 X5 and the two previous times I reused the drain plug broad (12 X 22mm) aluminum crush washer and the last one I used the narrow copper one that comes with the MAHN/BMW oil filter.
What's the preference regarding the two crush washer types and if its the aluminum one where's the best place to buy them?
Copyright ©2000 - 2025, vBulletin Solutions Inc.
