03-06-2019, 01:12 PM | #1 |
112
Rep 357
Drives: E70 X5M
Anyone Tried xDelete?
Really curious about this android based app. Seems pretty awesome to have full control over the xDrive system for only $150. Claims support for all E70/71 specs.
Has anyone tried this out? https://xdelete.app/xdelete_faq.pdf
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
03-06-2019, 01:35 PM | #2 |
Rep 177
Drives: 2012 BMW X5M
Or just remove the front driveshaft. Isn't that what the Jeep Quadratrac peeps did?
03-06-2019, 01:35 PM | #3 |
77
Rep 357
Why would someone needs this? X5m is awd but at high speed more power is transfer to the rear or should i say its a rear wheel biased but awd when needed when slip occurs.
03-06-2019, 01:36 PM | #4 |
112
Rep 357
Drives: E70 X5M
The idea with this though is that it's way less work and you can switch between AWD and RWD. Removing front axles is more of a "permanent" way to get RWD. This just leaves the clutch in the diff open so no power goes up front.
03-06-2019, 01:38 PM | #5 |
112
Rep 357
Drives: E70 X5M
Not sure it's a question of need but more of a novelty I suppose? For only $150 just seems like something cool to mess around with.
03-06-2019, 01:51 PM | #6 |
Rep 550
I dont think its available for the cars with the 8 speed trans yet, only the 6sp autos.
A lot of people have messed with it in the E9X cars and it seems like it works well. I plan on doing it when it gets released. |
03-06-2019, 01:55 PM | #7 | |
112
Rep 357
Drives: E70 X5M
I may have to just pull the trigger soon and try it out if no one on here has. Just seems like an option that should be available from the factory and some of the newer xDrive cars do have the ability to switch from AWD to RWD on the fly.
03-06-2019, 03:42 PM | #8 | |
Rep 550
Negative. Early E70/71s may have come with 6spd but the LCI cars came with the 8spd that are found in the F series cars. |
03-06-2019, 04:07 PM | #9 | ||
112
Rep 357
Drives: E70 X5M
03-06-2019, 07:00 PM | #12 |
112
Rep 357
Drives: E70 X5M
That was fast! Did you already have a cable and just paid the $150 for the app license to give it a try?
Lighter steering was one thing I was wondering about - is it a pretty pronounced difference in feel? Having the ability to switch between RWD in good weather and back to AWD in adverse conditions just sounds amazing. Please keep me posted with how you like it over the next couple weeks!
03-06-2019, 08:37 PM | #13 |
Rep 433
I flashed xdelete last week and it's completely changed the way my X5 drives now. The steering is lighter, less oversteer and I feel the power coming from the rear wheels. Flash took 1 min
2012 X5d | Deleted & BRR Tuned | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Thread https://www.xbimmers.com/forums/show....php?t=1529213 |
03-06-2019, 08:58 PM | #14 | |
Rep 235
03-06-2019, 09:01 PM | #15 |
Rep 235
Yea i love the fact that it can be switched back and forth at anytime desired, how are you liking it so far since you've had it installed much longer I'd like to hear your input!
03-07-2019, 07:04 AM | #17 |
Rep 1,579
I really like how the X5 feels in 2WD. The AWD is overly intrusive and feels like it is binding under power and turning. It is tuned for safety on slick roads and does not have different modes like more modern AWD does.
My 2WD experiment was because the dealer claimed I had a bad transfer case. So I disconnect the module (by the battery on pre-lci) and drove around for a few days. The problem did not go away so the dealer was not correct. And disconnecting the module also disables stability control and ABS (I think). But I liked it enough that I may try the app. They could call the app S-Drive . |
03-07-2019, 07:50 AM | #18 |
Rep 714
I'm another interested person- I wonder if you'd notice an MPG increase over time, even 1mpg would make a differecne to me with how much I drive. But with the diesel, I'm REALLY concerned about my rear diff. Is the x5's rear diff up to handling 500ish torque through it? I'm Sutphin tcu, and about to be dudmd stage 2 (which dyno's comparably to JR 2.8 I believe). That's a lot of force going through just the rear diff, to move 5000 lbs...
03-07-2019, 09:38 AM | #19 |
Rep 550
I know its not apples to apples but from reading around in the E90 forums, the AWD and RWD cars use the same rear differential. Those that used xdelete did not suffer any consequences since the differential was built to handle the power and torque of the RWD car.
I would assume since some of these engines are shared between models, the differential power handling ability would be similar as well. |
03-07-2019, 09:55 AM | #20 |
Rep 714
I read that too, which seems solid on the 335's, but the systems in the x5 are a bit different. I'm not sure if any of the V8 x5's came only in Sdrive, and therefore would prove that our x5 rear diff is up to 450+ torque on it's own.
03-07-2019, 10:10 AM | #21 |
Rep 550
Yea. Completely valid point. I threw it out there in case people smarter than me saw it had any idea if there were parts shared between the different model platforms. A lot of the parts around the diff are shared. The differential itself isnt the same but maybe some of the internals are? Or at least machined/manufactured to the same level?
03-07-2019, 11:04 AM | #22 |
94
Rep 398
This is interesting, curious how the X5M would drive in RWD mode. Might be a nice option in the summer months when AWD isn't needed as much.
'17 Porsche C4S Sapphire Blue Metallic / Bordeaux Red - Softronic tune - Soul Sport Cats - Soul Exhaust
'13 E70 X5M Black Sapphire Metallic / Bamboo Beige - Full Dinan Suspension - Dinan Exhaust - BPM Sport Tune - xHP Flashtool Transmission Tune |
