05-10-2019, 09:16 PM | #1 |
Rep 116
20x10 up front. 20x11 in rear
Has anybody converted the wheel width on their F80 M3 yet? If so please let me know whats needed in terms of fitment, as well as how the car handles with wider track. Car is already lowered on HR Sport springs (F=1.2" R=0.8") and has spacers. 18mm up front 15mm in rear.
Currently im looking at the HRE FF04 Flowform's. Gonna be 20" all the way around Do I need to get different spacers? Or at all? What offset will I need? HRE has 23mm 20mm 40mm 43mm What tire size should I be looking at? Is this even a good idea? |
05-11-2019, 04:48 PM | #2 |
Rep 138
Front: 20x10 +23 put a 5mm spacer if you have a drop otherwise will hit springs if they are progressive. You can try without spacers but I recommend them.
Rear : 20x11 +35 265/30/20 front 285/30/20 rear
2014 X5 50i
2018 M3 Indv. |
Champagne_Reign67.50 |
05-12-2019, 06:56 AM | #3 |
Rep 20,742
Drives: 2021 911 turbo
Since you have spacers on your car, you’ve already widened the track by 36mm in front and 30mm in the rear. Going with wider wheels, you will in fact need to reduce the track to ensure the tires fit inside the fenders.
To keep the same “stance” (wheel face position relative to the fender) as your stock wheels with your 18/15mm spacers on 10”/11” wide wheels, you’ll need ET23 in front and ET37 in the rear. Based on the HRE offerings you mention, the ET23 front and ET40 rear would provide the nearest “stance” to your current setup without the need for spacers.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 05-12-2019 at 07:08 AM.. |
05-12-2019, 06:31 PM | #4 |
Rep 116
Thanx for the info. Any idea on if this will improve or degrade my handling? I dont want any understeer.
05-12-2019, 07:09 PM | #5 | |
Rep 4,116
I had the 10/11 combo for over a year year. Did it look great? Yes. Did it drove better than stock? No. Would I do it again? Of course! Lol Currently on 20x10 and 20x12 and can't really complain, but I'm not driving that much. For reference I had 20x10 et20 and 20x11 et25 but this setup is super aggressive. Stock ZCP tires. If you buying new wheels anyway, try to avoid spacers. Last edited by LOW4LYF; 05-12-2019 at 07:29 PM.. |
05-12-2019, 07:25 PM | #6 | |
Rep 116
Im currently running spacers now. whats the reason to avoid them? Im still getting the wheels, but I'll just keep stock width due to your suggestion. I feel like I will stiill need the spacers no? Last edited by Champagne_Reign; 05-12-2019 at 07:31 PM.. |
05-12-2019, 08:58 PM | #7 | |
Rep 116
my mistake, they only have a 20x11 43mm will that work for the rear? |
05-12-2019, 09:34 PM | #8 |
Rep 1,171
I have 20x10 and 20x11. If I could do it all over again, I would have gone with 19 inch instead.
Tires are ridiculously expensive and there is only a handful of selection you can buy. Plus, I felt like my stock 19 inch felt better on curves and turns.
2018 BMW F80 ///M3
570WHP/578TQ |
Champagne_Reign67.50 JeremyDFW458.00 |
05-13-2019, 07:13 AM | #9 |
Rep 4,116
If you getting a 20x10 et20 you can avoid spacers, save weight etc. Makes no sense to buy custom wheels and put additional spacers on.
05-17-2019, 08:45 PM | #10 |
Rep 116
05-18-2019, 11:19 AM | #11 |
Rep 4,116
05-18-2019, 06:49 PM | #12 |
Rep 116
05-21-2019, 10:47 PM | #13 |
3139
Rep 2,953
We've done the 20x10 | 20x11 FF04 several times, here's how it looks on KW V3. There's no issue with fitment against the suspension or fender on 265/30/20 | 295/30/20
Untitled by Justin Shih, on Flickr Untitled by Justin Shih, on Flickr |
05-22-2019, 06:59 AM | #14 |
Rep 4,116
But HRE is not open to share offsets...
05-22-2019, 04:53 PM | #15 | |
Rep 1,171
How are you able to get away with 295/30/20 on 20x11?
2018 BMW F80 ///M3
570WHP/578TQ |
05-22-2019, 05:12 PM | #16 | |
3139
Rep 2,953
Every tire make runs a little different in regards to actual diameter and width. |
05-22-2019, 06:39 PM | #17 | |
Rep 116
what offset is that set up? My only options are 23mm up front and 43mm in rear. Its a "by vehicle" set, but idk how true to vehicle it is. vividracing says its offsets are tailored for the f80 specifically. Open to other opinions tho |
05-23-2019, 12:30 AM | #18 | |
3139
Rep 2,953
Happy to assist you if needed. Their new flow form style is arriving end of June. Definitely recommend holding out for the new styles |
05-23-2019, 07:03 AM | #19 |
Rep 4,116
Really a shame some companies are not willing to share offsets, but anyway... this is a 20x10 et25 and 5mm spacers, so et20. Tire 265/30 PSS and KW HAS V1.
I would not be able to run et23 with the 265/30 an KW HAS V1. Hope this helps.
2SNAILS2085.50 |
07-05-2019, 02:25 AM | #20 | |
Rep 116
Just wanted to tell you thanks for the info. I went with your exact setup recommendation, and everything fits perfectly. Identical to the fitment I had with spacers and stock wheels. no rub, and the 295's are perfect in the rear. |
07-05-2019, 06:34 PM | #21 |
3139
Rep 2,953
09-18-2019, 07:20 AM | #22 | |
Old guy
308
Rep 266
