06-05-2019, 10:05 PM | #1 |
Rep 7
X5 f15 Body Brake rotor rusting
Hi.
I got x5 30d f15 body 2017. Keep it underground parking and just wash normal base. All four brake rotors covered rust looks really annoying. I read this forum and serched info. This happened normal doesn't really effect brake performance. But looks quite bed anyway I planning to request service dealer. Anyone serviced same problems and serviced from dealer under manufacturer warranty?? My location syd. Thanks
Aj
06-05-2019, 10:31 PM | #2 |
"Salud"
13848
Rep 4,675
Drives: F01 & F15 / Mineral White
This is something that plague ALL models of BMW and most cars and trucks. It's because they are made from iron. And moisture and iron do not mix. I can't understand why manufacturers won't powder coat them....
06-05-2019, 10:37 PM | #3 | |
Rep 7,160
They won't powder coat or paint because you're not supposed to put a layer of material between the rotor and wheel when they contact. If the powder/paint wears down it will create a gap and could cause your wheel to come loose. I grinder mine and then greased and haven't had rust in 6 months.
06-05-2019, 10:41 PM | #4 | ||
Rep 7
Aj
06-06-2019, 07:52 AM | #5 |
Rep 648
My rotors have the same rust on them. If they weren't almost due to be replaced, I would coat them. (#%^ maintenance plan won't allow replacement until sensor set off)
I recently used a rust "converter" spray on parts of my trailer. Bought it at the autoparts store. The spray binds with the rust, wire brush first, creates a black layer that is supposedly rust resistant? I wonder if that would work well for the rotors? |
06-06-2019, 07:57 AM | #6 | |
Rep 7
I tried rust remover once I sprayed rust gone off. But rusting again. I think rust converter will change to dark colour. My opinion if I clean them and high temperature spray apply will looking better. I thinks dealership will do that this bloody job.
Aj
06-06-2019, 10:11 AM | #7 | |
Rep 1,859
Drives: 23' X7 40i M Sport
06-06-2019, 10:33 AM | #8 |
Rep 2,511
Mine is not as bad but rear rotors are quite rusty, replacing them today with ECS Drilled/Slotted coated rotors and Akebono Euro pads, original brakes are pretty bad for the price not coming back to OEM BMW.
06-06-2019, 10:49 AM | #9 |
Rep 20
Most stock rotor ""hats" are painted/coated. Lots of the replacement rotors are not, so after a few months, they will rust like this. It's only and eyesore, not anything to worry about. Yes, you can remove the wheel and treat, scrape, clean, treat and paint or rust-proof. Just be sure not to treat the rotor itself. Wen I purchase new rotors, I make sure to get the zinc-plated ones. They will never rust. One time I purchases a set of rotors then took them to a local plating shop and had it done. Open wheels = tide rotors. A must .
~MK~
2017 sDrive35i |
06-06-2019, 11:19 AM | #10 |
Rep 993
High temp brake paint. Remove wheel, wire brush surface rust and spray everything. Rotor, calipers, etc. I use "cast coat iron" color from duplicolor. Lasts a year or two. Spray paint will not hurt you pads or rotors. Been painting my rotors and calipers for 30 years.
And I don't know about the comment of paint between rotor and wheel and lug nuts coming loose. Lol. Good theory, but not reality. |
TXSTYLE13848.00 |
06-06-2019, 11:46 AM | #11 | |
Rep 648
Is it a big risk, maybe not, but there is a risk, so why take it? I would just tape/mask the mounting surface and the actual disc surface, before painting the area prone to rusting.. |
Maverik2594140.00 |
06-06-2019, 04:41 PM | #12 | |
Rep 7,160
