06-13-2019, 10:20 PM | #1 |
Rep 33
RE71R on ZCP 666M
Just got new RE71R
So far, not too loud, maybe even better road manners and better traction than stock PSS. And looks nicer... 245/35 - 20 Fronts 295/30 - 20 Rears |
06-14-2019, 04:50 AM | #2 |
Rep 20,742
Drives: 2021 911 turbo
This is way too much stagger difference. It must be understeering like hell
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
06-14-2019, 08:03 AM | #3 |
Rep 2,162
06-14-2019, 09:57 AM | #4 |
Rep 1,183
Re71r runs wide because it has a stiffer sidewall. totally acceptable. These are my favorite tires.. I have gts fitment 20/19 295/30/20 and 265/35/19 on my firs. I've had 4 or 5 sets now.
your fitment is actually ran on the cayman gt4 Porsches. i used to have 20/20 firs and when i sold the tires it went to a guy with a gt4 in texas. same specs. |
06-14-2019, 05:01 PM | #5 |
Rep 33
Actually the 245 RE71 has wider contact patch than the star BMW 265/30 PSS. Both front and rear contact patch went up about an inch per tire, so it's actually pretty balanced.
06-16-2019, 07:26 AM | #6 |
Rep 715
The both seem to sit pretty square on the wheel.
If the tread width did indeed go up equally at the front and rear, then that would actually be a greater % increase favouring the front, decreasing the stagger. If the provided specs are correct of course.
M4 Times (PSC2): Sandown: 1.21.76 Winton: 1M Times (PSC2): Phillip Island: 1.53.09 Sandown: 1.24.03 Calder Park: 1.07.31 Winton: 1.36.71 |
06-17-2019, 12:18 AM | #7 |
Rep 33
After 1 weekend, I can say the car feels better balanced. More front end feel, a bit quicker steering, more precision and better ride quality over bumps. It is a little louder but doesn't really bother me. The wind noise and radio is louder than the tires. The prodigious grip is night and day over the stock pss. Highly recommended.
08-07-2019, 08:46 AM | #8 | |
Rep 2,286
The stock MPSS in 265/30 R20 is 26.3" and 791 revs per mile and rear 285/30 R20 is 26.8" and 777 revs per mile. Because this setup for the RE-71R has less of a diameter difference and revs per mile difference front to rear as compared to stock MPSS values front to rear - have you noticed any behavioral differences in terms of traction control or other behavior of the car? I like to drive MDM on street and I was worried that less of a diameter differential front to rear might "trick" the traction control into thinking more or different intervention is required - but any anecdotal or scientific answers would be great before I pull the trigger on these... |
08-07-2019, 09:43 AM | #10 | |
Rep 2,286
Hopefully with better monitoring/adjusting of tire pressures throughout the day this "greasiness" can be avoided with these tires on the track. Either way, subject to other responses I get to this thread and another thread I just started on this topic, I'm willing to give them a try for dual street/track use on my 20" 666M rims... |
06-12-2020, 04:26 AM | #11 | ||
Rep 600
06-12-2020, 12:29 PM | #12 |
Rep 1,322
They are awesome when warm and dry, just be sure to respect their limitations when it gets cooler and wetter (particularly as they wear). Would advise keeping all the nannies on too if you're going to run them in those conditions.
06-12-2020, 01:04 PM | #13 |
///M Powered for Life
11510
Rep 10,342
Good choice, great tire that can do DD or go to the track quite happily
06-13-2020, 08:28 AM | #14 | |||
Rep 2,286
06-16-2020, 08:20 AM | #15 |
Rep 125
Any updates after having this setup for about a year now? Any funkiness with MDM or DSC?
I just corded my stock PSS tires and am looking for a new setup. I was thinking about going with a dedicated track wheel + tire and just replacing the PSS tires on my 666M for daily use, but if I can get away with RE71R on the 666M rims, that may be better and cheaper for now. I would need to be able to drive to the track on the tires anyway (no trailer) and the car doesn't see many wet miles in its daily driving life. I'm just worried about heat cycling the tires too many times with small trips or highway drives. And yes, I know I need to address camber before tracking my next set of tires, no matter the type! |
06-16-2020, 08:37 AM | #16 | |
11510
Rep 10,342
You will not heat cycle them on the street. |
