06-27-2019, 03:27 PM | #1 |
Rep 1,297
Welp, I don't imagine this tire is repairable?
Can this be repaired? It's on the rear driver side tire
If it cannot be repaired - I only have 3k miles.. can I get away with just replacing that one? It would suck to have to spend 800 dollars for both right now. Lastly - I don't want to bring the car into the dealer for this. I asked them if I could just bring the tire and they declined and want me to tow the car from my garage to their dealer.. not happening! I suppose I can get the new tire installed and balanced anywhere?
2022 M3 xDrive Comp
2020 M2 CS (retired) 2018 M3 Comp (retired) 2015 335i (retired) |
06-27-2019, 04:03 PM | #2 |
523
Rep 321
The tread looks pretty good, so you should be able to get away with just getting one new tire now, then replace them all together when the time comes.... with the PS4S.
You can get a new tire from wherever is the cheapest. Is the dealer far? Are they planning to replace for no charge? I mean you're going to have to take the time to remove the wheel, go to the tire shop, get the new tire fit and balanced, then go back and put on. If the dealer is close and they're replacing no charge I would say it is worth it unless you just absolutely don't want to have the car towed. I would also recommend taking pictures of the rims before anyone does anything. I had a bad experience where two of mine were gouged pretty bad from the tire shop. Unfortunately no pictures from before they took the rims off to prove it though. I learned from that mistake. |
06-27-2019, 06:21 PM | #7 | |
Rep 10,509
Agreed that the plug and patch is the better way to do it, but it’s such a pain to find someone who will do it, and the “outside twizzler” method has been fine for several years and 20+k miles for 2 all season rft I’ve tried it on. With a key advantage being you can diy in 15 min. |
06-27-2019, 07:35 PM | #8 |
Rep 885
I use those gummy strings on at least 6 - 7 punctures on my motorcycle and even car tires.
I went 15k on a touring moto tire after I plugged a puncture. kits are in all my cars and bikes.
SAFE-GUARD tire/wheel/windshield/paint protection is a FRAUD! do not waste your money!
06-27-2019, 10:55 PM | #9 |
Rep 3,968
OP - you don't list your location so it is hard to help you with options.
2011 1M, Black loaded sans sat radio
2021 911 C4S Gentian Blue, manual 2023 X3 M40i - loaded sans Park Assist |
06-27-2019, 11:11 PM | #10 | |
///Multiple
2993
Rep 4,243
Drives: M4 Coupe | M3 | Z4M Roadster
Garage List 2006 BMW Z4 M Roadster [8.81]
2016 BMW M4 Coupe ( ... [10.00] 2018 BMW M3 (Euro D ... [0.00] 2011 BMW 335is Coup ... [10.00] |
P.S. It's so useless when people don't actually say where they're from. I don't get the ultra paranoia. It seems like there's an awful lot of people in this forum that are in the Witness Protection Program...
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 |
07-02-2019, 09:19 AM | #11 |
Rep 1,297
Hey guys - hoping someone has an answer before I'm forced to drop car off at dealer (h8 this)
I had a flat tire on my rear driver side earlier this week. I took the tire off myself, leaving the car on jack stands.. took the tire/rim to a place that said they could 'patch/plug it' - long story short, the guy couldn't get the tire off rim and I ended up taking the wheel to BMW.. BMW replaced the tire, got the old one off, put new one on.. np.. I put the wheel back on the car, reset TPMS, everything looks good.. but I'm getting a rubbing type noise I did not get before.. you can hear it here: https://soundcloud.com/alexander-garcia-770978023/noise Another tidbit is for some reason BMW didn't fill it up with 32 psi.. it only had 19 psi so I had to put air in it.. but this tire isn't losing air. Any idea what the issue is? i tightened the lug nuts to 105 pounds w/ a torque wrench.. the car isn't wobbling or anything but it definitely wasn't making that noise before and I'm afraid to push it. Any insight would be cool, otherwise, off to dealer I guess.
2022 M3 xDrive Comp
07-04-2019, 06:34 AM | #12 |
Rep 3,968
Weird - correct tire size and all?
My only thought is to lose the lugs, jack it up, and re-tighten in a cross pattern. Even if you did that the first time, try again. alternatively, the first guy could have bent the wheel.. But I think BMW would have noticed that. Once again, you don't say where you are - but in the US, you would have free roadside assistance for this.
