10-10-2019, 03:48 PM | #1 |
Rep 96
Battery life and reset question
So after replacing my original battery a little over a year ago, my new battery has been flashing the lift icon low power warning with the clock reset on start up. Thing is, I know it's because I only drove it on very short distances for my commute for a couple months.
According to what I've read about our battery system is that the computer will slowly readjust your max capacity to limit overcharging. And because I kept a low power for this long of a period, my max has probably lowered significantly. I'm assuming this is the case because it's starting to happen more frequently regardless of having driven it on a long trip a day or 2 before. My question is, can I simply reregister or reset the battery back to regular capacity, now that I'm driving back to longer distances? |
10-10-2019, 03:51 PM | #2 |
Rep 2,806
Was your new battery registered ? And is the car coded for the correct type and Ah of the battery ?
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
10-10-2019, 09:03 PM | #3 |
Rep 3,071
This ^^. You have to register the battery.
Get a battery tender & plug it in every now & then to keep it charged. There are all types & brands. I have a pretty inexpensive one by Black & Decker. It takes a while to charge but overnight does a decent job. I had a Deltran Battery Tender Plus for years & it was great. Not the least expensive out there but it worked great. If the B&D stops working I'd get another Deltran.
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
10-11-2019, 06:01 PM | #5 |
Rep 96
Yes it was registered properly. Everything was fine until I started driving these very short distances, I guess. It's only my theory that by doing that for several months it neutered my battery.
10-11-2019, 06:08 PM | #6 | |
Rep 96
Maybe I'll give this reregistration a shot. Always wanted to have one of those OBD tools anyways. |
10-11-2019, 06:16 PM | #7 | ||
Rep 6,196
10-11-2019, 06:53 PM | #8 |
Rep 3,071
Short distance like 10 min or ??
10-11-2019, 08:40 PM | #9 | |
Rep 2,806
If the coding and registration are good, your theory may be correct. I understand from your answer to Gangplank a battery tender isn't an option. I would not register a one year old battery that is showing signs of going dead. It might get overcharged and that could be bad. I'd try to find some way to have it properly charged with a recondition mode charger. If that doesn't work best to bite the bullet and get a new one and have it registered and coded correctly. Another possibility - are you sure you don't have any parasitic drain?
10-11-2019, 08:49 PM | #10 |
Bergspyder
1476
Rep 1,215
That battery should have a warranty on it.....use it.
10-15-2019, 06:44 AM | #11 |
Rep 3,547
One of the reasons I am still using my 10 year old battery is failures of relatively new batteries in other cars. I think it is very possible to get a battery that doesn't last long for no discernable reason. Before concluding that is the issue, I think I would:
1) Get one of those little battery packs that will jump start a car. Could be handy for you right now and it also will facilitate step two. 2) Remove the battery, take it inside and charge it. If it is the short trips this will cause the car to work correctly for a short period of time. 3) Get a multi-tester and check for a parasitic draw on the battery. Not all multi-testers will measure amps so you have to see what they do before buying. I have let my car sit for a week before without driving it and it always starts. I do not use a tender. If you do not have a parasitic draw and the battery is just not staying charged, the options are a tender or taking the battery back.
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09 |
Rmtt8221.00 |
12-08-2019, 02:35 PM | #12 | |
Rep 506
Drives: 2010 128i 6MT Sport Pkg. 18"
