04-04-2020, 05:48 PM | #1 |
122
Rep 359
X5 rear jacking point (not M)
I'm a couple days away from flushing my own brake fluid on the x5 50i and not exactly sure where to jack up the car from the rear. I did find a post about it but it shows an x5m which has a beefier differential.
I have circled the place where i think can be used to lift up the car. Can someone please confirm it's the correct one? |
04-04-2020, 05:55 PM | #2 |
Rep 592
04-04-2020, 06:02 PM | #3 |
Rep 7,525
The TIS says you can lift the rear using a trolley jack under the rear diff...but take note of #3...where it warns NOT to place the jack below the rear diff’s cover. You can placed it below the diff...but make sure the jack won’t damage the diff’s cover.
I think many people see that “X” and don’t look close enough and presume it means not to place the jack under the rear diff...but it just mean to clear the cover of the rear diff:
04-04-2020, 09:07 PM | #6 |
122
Rep 359
04-04-2020, 09:13 PM | #7 |
1641
Rep 2,995
04-04-2020, 09:16 PM | #8 |
122
Rep 359
04-05-2020, 01:23 PM | #9 | |
Rep 7,525
And if sections #3 in the TIS diagram may still be confusing some...take note that there are TWO arrows pointing toward the rear diff. The one circled in green shows where to lift...the one circled in red shows where NOT to lift.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-05-2020 at 08:45 PM.. |
04-05-2020, 01:53 PM | #10 | |
122
Rep 359
04-05-2020, 02:44 PM | #11 | ||
Rep 1,179
04-06-2020, 09:50 PM | #13 |
122
Rep 359
Update: i did the brake flush today and jacked up by the diff, not its cover. I was really nervous but worked like a charm.
Brake flush was also successful, used a schwaben brake bleeder and 1.5L of dot 4 ate fluid, no ista since I forgot to hook up my laptop. Regardless, brake feel seems firm/no different than before although I had some micro bubbles in the lines when I was pushing the new fluid through the rear right and left brake pistons, but I made sure to get rid of them. Entire job took me 3 hours. |
