04-05-2020, 12:14 PM | #1 |
Long Time Lurker
Rep 11
KOMBI no communication
Hello everyone !!
Long time lurker but first post hope someone can help me ! . I'm fairly new to coding and using tools on my f15. Issue is couple months ago I was driving and all of sudden my dash went black. Meaning no illumination lights from the cluster . I figured it was something small like a blown fuse or just needed a battery reset or something . Nothing worked. I'm struggling now months with this and it's hard to drive as I can not see the dash at night . The needles work , the rpm, speed works properly, it's just the illumination , there is no light . I checked the dimmer switch and made sure it's all the way up which it is . Anyways back to my question I recently ran inst-D diagnostic on my car to show faults , at first there were many probably due to battery disconnect. I cleared the faults and re run diagnostics. This time only 2 faults and both from KOMBI unit . I was playing around with inst- d and noticed that there was pretty much updates to every single ECU in my car since it's been a while since I been In service . I read on forums that some updates afterwards don't allow coding anymore , so I made sure I didn't update anything but I noticed this very strange request under the plan it was telling me it wanted to preform. Attached is a photo of what came up and a video of what actually is not lighting up . I could pay if need be but with losing my job due to the virus things are very tight . Right now with the coronavirus I help local seniors here in NJ, USA get around and they depend on me . I really need to be able to see my dash again at night . Any help will totally be appreciated |
04-05-2020, 12:30 PM | #2 |
1644
Rep 2,995
Is it possible you have a bad connection to the cluster? A bad cluster?
Not sure if an update will fix a communication issue since your can't communicate with the cluster. Have you tried just banging on the dash to see if it gets it working? Lol |
Rated M4Speed2.50 |
04-05-2020, 12:36 PM | #4 | |
Long Time Lurker
Rep 11
Thanks a lot for the input 🙂 |
04-05-2020, 12:39 PM | #5 |
Long Time Lurker
Rep 11
Yes I checked the fuses , they looked fine . Can you confirm which exact fuses if you know ? Hell, I went as far to pull everyone of them out and check each one .
I did notice now my passenger side fog light is out as well , not sure if they all interconnect some how . Doubt it though . I was considering removing the cluster again , opening it up and checking each of the components to see maybe if short somewhere ? Just can't locate a schematics for it . Thanks for the input . |
04-05-2020, 02:06 PM | #7 | |
122
Rep 359
I found this fuse box diagram: https://fuse-box.info/bmw/bmw-x5-f15...uses-and-relay It looks like it's fuses 50, 52 for the instrument cluster. |
04-05-2020, 03:39 PM | #8 | |
Long Time Lurker
Rep 11
[QUOTE=ponytuning;26011449]
Thank you kindly , I will double check again now ! |
05-03-2021, 03:21 AM | #12 | |
Rep 2
psdzdata
Hi, I have exactly the same problem like you luv2vexx. Could you send me instruction how to coding, please ? I have enet cable and ISAT D and ISTA P but no idea how to. Thank you Cez |
05-03-2021, 07:24 AM | #13 |
Rep 552
Just FYI (and not sure if it'll work for you)
I had a similar problem on MY14 F15. It wouldn't comunícate to the KOMBI and the HU using ISTA+. I retrofitted to a 6WB, and my vehicle had ISTEP of 2013. Everything works fine, just keep getting faults when I run ISTA+. I updated it recently to 2020 ISTEP and all my fault logging issues went away (updated all ECUs with latest data). The only issue I have is that it still tells me it has issues communicating to the HU and the RSE and it's because I have an Android Screen installed (and I'm sure it's because of the additional harness I have to use). But everything works fine. Not saying this will fix it for you, just saying what I did and my issues went away. |
05-03-2021, 04:12 PM | #14 |
Rep 2
Today I connected a new rectifier and after charging for about 2 hours my meter showed a result of 14.86v. To my surprise, after turning on the ignition, the cluster appeared and everything was back to normal except the clock. I ordered a new battery because ISTA + also showed connection errors:
Thank you for any information |
