      03-01-2021, 01:36 PM   #1
andymatt1
Ireland
15
Drives: 2020 45e MSport
Help Telematics Unit location ??
Hi,
Having issues with my gps ..
Any idea where this unit lives in an X5 and does it effect the gps?
Thanks
      03-01-2021, 02:16 PM   #2
andymatt1
Ireland
15
Ok found it .. any idea does the battery go in these
And what happens when it does ?
Thanks
      03-01-2021, 02:19 PM   #3
CatalinP
Drives: BMW X5 F15 2014 3.0xd
You need to replace the battery. It can be ordered via dealer. It is used for SOS call in case of crash.
      03-01-2021, 02:31 PM   #4
ponytuning
122
Drives: '16 F16 50i, 15' F15 50i
Thanks
Where did you find it?
      03-01-2021, 02:56 PM   #5
andymatt1
Ireland
15
Is in a carrier pack on the left side in boot
You need to take out the side cheek to get at it
      03-01-2021, 02:57 PM   #6
andymatt1
Ireland
15
See here ..
      08-05-2021, 08:20 AM   #7
esoom55
Drives: 2017 X5 (F15) xDrive335i
I'm having the same issue but can't seem to find the TCM despite the descriptions above. Could there be an alternate location for this battery?
      08-05-2021, 08:41 AM   #8
Vdesai0326
Drives: BMW X5
2015 bmw x5  [0.00]
What year is your x5
      08-05-2021, 08:53 AM   #9
CatalinP
For newer F15/16 with NBT EVO the module is under the shark fin antenna.
      08-05-2021, 09:04 AM   #10
esoom55
it's a 2017 X5 335i
      08-05-2021, 05:16 PM   #11
Vdesai0326
Drives: BMW X5
2015 bmw x5  [0.00]
it's a 2017 X5 335i
Under the shark fin above headliner
      11-28-2021, 07:26 AM   #12
hairy65
Drives: BMW 335d xdrive
Is the 3g sim card located in this unit?
      11-28-2021, 08:31 AM   #13
CatalinP
Yes, but it is not a Sim card, it is a chip containing an esim. In order to swap the esim you need to de solder the chip.
      11-29-2021, 10:27 AM   #14
hairy65
Thanks for the reply. So the whole unit needs to be changed to one with a 4G esim?
      11-29-2021, 12:13 PM   #15
CatalinP
4G means ATM instead of TCU.
      11-29-2021, 03:02 PM   #16
hairy65
Thanks again.
      03-15-2023, 11:15 AM   #17
ansur
Drives: X5
X5 F15 telematics unit location
first of all gents thanks for all the help,
i have managed to locate unit in my X5 2015
i had this error at start SOS call system fail
the unit is located in boot area standing behind the car left hand side (UK)
remove the side panel and its there very easy to remove and reinstall
please see pictures its less than an hours job
Name:  part number for 2015.jpg
Name:  battery for telematics x5.jpg
      01-16-2024, 05:35 PM   #18
kammy6000
Drives: bmw f15 530d
Hi , is there anyway to find out which telematics part number was in the exactly before it was removed as mines is missing , thanks
      01-21-2024, 01:09 PM   #19
mrfochon
Drives: X5 F15 M package
What about 2015? Where and what type of sim?
      01-21-2024, 01:24 PM   #20
E85 Sport
who is this noob
40
Drives: from Spartanburg
www.realoem.com or call your dealer and they can run your VIN and confirm which p/n you need.
      01-21-2024, 01:28 PM   #21
E85 Sport
who is this noob
40
Post #17 above. 3G.
mrfochon211.00
      05-07-2024, 08:58 AM   #22
kammy6000
hi, so i actually found the telematics control module unit hidden in the car ,but it had been ripped out from its location (rear left )in boot (i know ! dont ask why) the wires were damaged i repaired them and i have bluetooth,satnav,stereo,music ,all working except for (mic for phonecalls via bluetooth,voice commands, and the sos call not possible error on dashboard , when i went looking for the mic above driver side , i found it had been cut from its connection i then wired the mic back up to connector after testing it on computer,i didnt actually get any sound from mic , just google search picked it up what was being said ! on ista there is an error for combox (S 0394) no communication possible with telematics control unit ! . Am i looking at the wrong module here ,next step was to look under the fin for a module but thats in G05 models i think not f15 , so maybe there is another module somewhere(the whiteone which i cant seem to locate ) , any advice please , thanks
