      03-14-2021, 01:40 PM   #1
sean.18883
Drives: BMW X5 F15 35i
Help: X5 35i weird sound when accelerate
Hi guys,
I'm very new to the community. This is my first BMW, a pre-owned 2016 X5 purchased from The BMW Store's in October 2020 in Vancouver, BC, Canada.
Upon purchase, the car has close to 45k km. It is now sitting at close to 50k km.
Starting a few days ago, I started to notice a high pitch sound on top of the usual solid turbo engine sound when I press the gas pedal and accelerate between 0-50 km/hour.
There has been no change to how the car performs and drives except the sound... It is a bit irritating especially when driving in parking lot or accelerate on a quiet street.
Since the car is recently out of warranty (the warranty expired 5 days before I purchased the vehicle), I hope I can gather some thoughts here before bringing my car to the dealership and pay for the diagnostic....
Could someone please share with me on what could cause this high pitch sound to appear? Also, ways to fix this if possible?
Video is attached in this link:
Lastly, if anyone is in Vancouver, BC, Canada and know places that do good repair and service work other than BMW dealerships' service centers, please share some with me.
Thank you all so much in advance!
      03-14-2021, 02:10 PM   #2
turboawd
1687
Drives: 2015 X5 35i
Initial guess would be power steering pump. But you'd only have that if you had the adaptive suspension I think.
Or alternator? Or ac? Does the noise change with ac on or off?
      03-14-2021, 02:29 PM   #3
sean.18883
Thanks for the input! But I don't think it is related to AC, i turned off my fan and radio to catch the noise and there is actually no change. The high pitch sound seems to go together with rpm or engine? when i accelerate the sound increases, then when shift gear goes from 1 to 2, 2 to 3, it pauses/drops then increases as ram rises....
Also, I don't think my car has adaptive suspension since it only comes with basic packages?
      03-14-2021, 03:14 PM   #4
turboawd
1687
Drives: 2015 X5 35i
Do you hear the sound with the hood up and someone revving it?
So since the power steering and coolant pump and fan are electric, that only leaves the alternator and ac pump on the front of the motor. Other possibility is the trans whining. But the transmission on the x are pretty solid.
      03-14-2021, 06:35 PM   #5
scotty339
Drives: 2015 BMW X5 x35i M-Sport
If you suspect turbo noise, go take a look at your charge pipe and make sure its connected on both ends and no cracks. The stock plastic ones can break.
      03-14-2021, 06:49 PM   #6
turboawd
1687
Drives: 2015 X5 35i
That's not turbo. The sound is directly correlated to rpms. Turbo spins faster when under a load. There's no load revving while parked.
      03-14-2021, 07:48 PM   #7
GLU_WEIN
GLU_WEIN's Avatar
Drives: 2018 M5 / 2019 X5 40i
Hi guys,
Check the idler pulley, belt tensioner pulley and alternator pulley, as they age they start making funky noises, this happens a lot in the E series so it wouldn't surprise me that it carried over to the F series. If it is a pulley it will be a lot cheaper to replace also.
      03-15-2021, 05:01 PM   #8
Vdesai0326
Drives: BMW X5
2015 bmw x5  [0.00]
Hi guys,
Yup agree with what he said I would replace drive belt and tensioner and the idler pulley.
Does it make the noise if you are at idle??
      03-16-2021, 10:19 AM   #9
M302_imola
M302_imola's Avatar
873
Drives: '15 X5 35i Xdrive Mineral Whit
Love the gauges. My '15 doesn't look like that.
      03-16-2021, 10:57 AM   #10
turboawd
1687
Drives: 2015 X5 35i
You can retrofit.
      03-16-2021, 02:27 PM   #11
M302_imola
M302_imola's Avatar
873
You can retrofit.
Around how much $ we talking?
      03-16-2021, 02:56 PM   #12
turboawd
1687
Drives: 2015 X5 35i
Maybe 2000?
Search on here for '6wb'
      03-16-2021, 07:15 PM   #13
M302_imola
M302_imola's Avatar
873
Maybe 2000?
Jesus! Nevermind, that's more than I thought.
      03-19-2021, 10:09 PM   #14
sean.18883
Wow man, you are 100% correct. Thank you! I went to the dealer to get it diagnosed, and the technician narrowed down to either idler pulley or alternator pulley. Now the problem is solved by replacing the idler pulley.
      03-19-2021, 10:10 PM   #15
sean.18883
Thanks man!! It is indeed the idler pulley that made the sound per the technician at dealer. The problem is solved now by replacing the pulley.
      03-19-2021, 10:14 PM   #16
sean.18883
Thanks man! You are correct, the technician narrowed it down to the alternator and AC pump area, saying it was either the alternator pulley or idler pulley that made the sound. I got the idler pulley replaced since it is the cheaper option to do, and the problem has been resolved. Really appreciate your help
      03-20-2021, 10:27 AM   #17
GLU_WEIN
GLU_WEIN's Avatar
Excellent! Glad I could help and you got it taken cared of.
