04-26-2021, 05:31 PM | #1 | ||
Rep 12
NBT EVO HU error when inject CAFD VO
Please help add CAFD to HU_NBT2.
My car has a factory configuration and nothing has changed/added in it and NBT EVO if factory from this car. I coded different blocks (KOMBI/KAFAS2/PMA2/HU_NBT2/....) The car has American settings and I wanted to change the settings to European. I add all sorts of conveniences such as automatically close mirrors / display road signs / FM radio / display 360 cameras while driving and other things. After I changed the Quote:
Also short VIN number is displayed as HU_NBT2 [63] [яяяяяяя] I've already tried: Quote:
and always the same error: Service SA_SK returned a negative response with response code serviceNotSupportedInActiveSession Service WDBI_PLAIN returned a negative response with response code requestOutOfRange As far as I understand NBT EVO is not a locked. (Because the fsc code AppID 368(0x170) FSCStatus not available) About this device: Model: NBT EVO HU Model No: HB B211 EC:308 HW:3.2 Version: US Date 42/16 All FSC codes are standard from the factory. and status says all is well. No patches or modifications were made. carplay/mirroring works without using FSC codes i-step/i-level actual F025-18-03-530 TELEPHONE: TB-006.018.050 MEDIA: MB-006.018.050 HMI: 006.026.050 Software version on map NBTevo_N (fsc code 121 disappeared after coding) How do i get a cafd file back? Maybe I need to look for a problem in the settings of other ECU? Possibly KOMBI/Kafas2/....? I think that my VO is completely original, I don't understand whether it makes sense to change something there. Please tell me where to look for a solution? Similar topics: https://www.bimmerfest.com/threads/h...signal.979009/ https://f30.bimmerpost.com/forums/sh....php?t=1451103 https://www.cartechnology.co.uk/show....php?tid=40450 https://cartechnology.co.uk/showthre...d=67649&page=2 https://cartechnology.co.uk/showthre...=40782&page=19 https://cartechnology.co.uk/showthread.php?tid=52223 https://www.bimmerfest.com/threads/n...yyyyyy.1260730 Last edited by snex; 04-27-2021 at 05:54 AM.. |
04-26-2021, 06:54 PM | #4 |
Rep 2,529
I might be wrong but I thought that you need some VO coding in order to get the region changed. Looks like similar problem described here: https://mhhauto.com/Thread-EVO-id6-r...ange-US-to-ECE
I am not that experienced with coding, you might need help from someone like shawnsheridan or kubax86 |
04-26-2021, 07:22 PM | #5 |
Rep 12
I'm wondering if this problem can be caused by changing the CAFD files of other ECU (KOMBI/KAFAS2/....)?
I will try to experiment as it is written in this answer. https://www.bimmerfest.com/threads/n...#post-12469838 It seems to me that the solution is not to replace the firmware or any manipulations with tool32 / hutools 2.6. I think that esys / ista-d should deal with this problem, but I still can't figure out how. |
04-26-2021, 07:48 PM | #6 |
Rep 41,229
EVO is not Component Protection Locked, it it is VO Code Locked. PM sent.
04-27-2021, 01:50 AM | #7 |
Rep 12
Wrote PM, waiting for an answer.
How to understand "VO Code Locked" it is something that needs to be repaired on NBT using a patch / tool32 / hutool 2.6 (my nbt evo has 18-3 firmware) or it is a problem that I need to configure something correctly in SVT and then when i see the correct display VIN numbers in HU_NBT2 [63] [correct] then the CAFD should probably be accepted. Where to look for this error? Inside in NBTEVO firmware or maybe some eeprom or hard drive? Is the error completely hidden in the correct ESYS -> SVT settings? |
04-27-2021, 02:13 AM | #8 | |
Rep 3,070
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
04-27-2021, 02:43 AM | #9 |
Rep 12
Сan i generate this patch with Hutools 2.6?
What should my current steps be? Please help me find a solution on how to bring it all back to life. My HU_NBT2 have i-step/i-level 18-3. Can the patch damage the options supported by the head unit? AppID 111(0x6F) FSCStatus accepted AppID 160(0xA0) FSCStatus accepted AppID 366(0x16E) FSCStatus accepted AppID 367(0x16F) FSCStatus accepted 609 Navigation System Professional 645 Radio Control Us 655 Satellite Radio 610 Head Up Display 688 Harman/kardon Surround Sound 6AC Intelligent Emergency Call 6AE Teleservices 6AK Connecteddrive Services 6AM Real Time Traffic Information 6AP Remote Services 6CP Apple Carplay Preparation 6NW Telephony With Wireless Charging 6WD Wifi Hotspot |
04-27-2021, 06:03 AM | #10 |
Rep 41,229
04-27-2021, 12:27 PM | #11 |
Rep 12
Thanks to everyone who tried to help. The problem was solved by a paid solution using remote unlocking "VO coding" and then I was able to insert my CAFD file.
Three people offered me this service, I chose the one who was the first. Thank you shawnsheridan for recommending me Gerry Also, if someone knows how to do it on their own then I will be interested in how close I was to the solution) |
04-27-2021, 02:29 PM | #12 |
Rep 41,229
Tags |
cafd, hu_nbt2, nbt evo |
