| 07-20-2021, 01:25 PM | #1 |
![]() 220
Rep 97
VRSF N55 F15 FMIC install and review
Hello,
I recently installed the VRSF race FMIC on my n55 xdrive35i F15 and it made a huge difference. IATs stay pretty flat throughout multiple gears. I purchased the intercooler from EuroKlasse : https://euroklasse.com/products/vrsf...b232521f&_ss=r Pictures of the VRSF and Stock FMICs Bringing down the stock FMIC was easy, just pop off the underbody panel, a few plastic shields unde rather fmic, the stock C clips, and 4 screws that secured the FMIC to the radiator support and the stock unit comes down. The install wasn't bad (I've installed several FMICs on n54s). I used my jack to raise the VRSF, I then had to trim about an inch off of the plastic radiator support to get the VRSF into position (easy, did it with a razor blade). The factory style connections were a headache, though, as the charge pipes need to be precisely lined up to slide in and clip. I sanded down the inner diameter of the in/outlet on the VRSF very slightly to make the charge pipe connections easier to jam in. I wasn't interested in removing the front bumper, I may have been able to save some trimming time if I did. Here's some install pics below: Here's the before and after IAT on the custom E30 tune I cooked up. Both pulls start around 76*, 2nd gear 3.5k rpm to middle of 4th gear Last edited by WOT808; 07-20-2021 at 01:36 PM.. |
| 07-26-2021, 05:07 PM | #2 |
![]() 9
Rep 149
I installed an AA IC on my n54. how would this compare? I did it on ramps with bumper still on. I did have to trim the front plastic a bit but the biggest pain was lining up the charge pipe with the lower IC connector pipe that came with the IC. Sounds like the same headache.
| 07-26-2021, 08:45 PM | #3 | |
![]() 220
Rep 97
| 07-28-2021, 09:29 PM | #4 |
![]() 879
Rep 1,522
Appreciate you documenting this DIY and more importantly the IAT's before and after. Also, very cool you developed a E30 custom tune. Any plans to put it on the dyno? Are you running catless downpipe? I'd love to see your dyno numbers.
| 07-29-2021, 07:29 AM | #5 | |
![]() 220
Rep 97
Here's vs stock flash minutes apart from each other. Ebay DP. |
ggunn9161.50 whoismorggan577.00 |
| 07-29-2021, 09:35 AM | #6 |
![]() 879
Rep 1,522
Wow! Fantastic numbers! Sounds like you know what you're doing in the tuning department. What platform tuning service are you using to build your custom tune (BM3)? Do you have a 93 octane tune as well?
| 07-29-2021, 09:42 AM | #7 | |
![]() 220
Rep 97
I flash via MHD. I have a BM3 account but haven't flashed via BM3 yet because MHD is just convenient. I've poked around in the BM3 editor and they have a ton of defined tables it's awesome. I have a 93 map and also a full e85 map, haven't had dyno time with either. |
ggunn9161.50 M302_imola878.50 |
| 07-31-2021, 01:43 PM | #8 | ||
Rep 23
| 08-02-2021, 10:45 AM | #9 |
![]() 879
Rep 1,522
| 08-02-2021, 11:00 AM | #10 |
![]() 879
Rep 1,522
I guess I question whether an aftermarket FMIC is really needed if you're not tracking the car or beating on it. I mean I get reducing IAT's but I'm not quite sure that IAT's in the 90s would pull timing or reduce output. Someone more educated set me straight.
| 08-02-2021, 04:48 PM | #11 | |
![]() ![]() ![]() 370
Rep 364
Drives: F15 M50d / ex E90 335i / Panda
However, if you start modding your engine, the upgraded fmic is always the very first thing to do. Always. But I'm pretty sure that's kind of obvious and that wasn't really your question, was it? |
anthony231.50 |
| 08-02-2021, 07:10 PM | #12 | |||
Rep 23
M302_imola878.50 |
| 08-02-2021, 07:17 PM | #13 | ||||
Rep 23
| 08-03-2021, 08:29 AM | #14 | |
![]() 220
Rep 97
Sure, 90* isn't iat isn't horrible. I'm sure you've seen delta between the stock and upgraded fmic, big difference (especially in the following gear). The stock fmic couldn't keep up with the demand of multi gear pulls. It 'works' for a 0-60 or merge situations but that's about it, after that the iats rise rapidly. |
M302_imola878.50 |
| 08-03-2021, 09:16 AM | #15 |
Rep 1,089
Drives: BMW X5 XDrive35i
So is the general consensus in getting the VRSF or Wagner cooler to work to use the vanjen clamp on either the ER or factory lower charge pipe? I'm looking to do this soon-ish.
2017 X5 XDrive35i X-Line | Sophisto Grey | MHD Full Flexfuel Tuned | Mosselman Turbo | Sutphin Tuning TCU | Nostrum Stage 2 HPFP | Walbro 450 | S63 EU5 Injectors | ER Charge Pipe | FTP F10 Inlet | Midnight Motorsports Intake | ApexBuilt Catted DP | VRSF FMIC | Zeitronix Flexfuel Kit | KateCool Oil Cooler | Variant Wheels | Conti DWS06+ | Custom 3.5" Catback | M18 Racing Oil Breather Cap | Turner Catch Can |
| 08-03-2021, 11:06 AM | #16 | |
![]() 879
Rep 1,522
Also, did you guys go 1 step colder on the plugs? Something else I haven't gotten around to. I sure as hell don't want detonation. Guess I need to get on top of it. |
| 08-04-2021, 07:31 AM | #17 | |
![]() 220
Rep 97
I run the n20 plugs. |
| 08-07-2021, 03:53 PM | #19 |
Rep 23
sukhk5272895.50 M302_imola878.50 |
| 08-07-2021, 11:03 PM | #20 |
![]() 220
Rep 97
I've seen one step colder on one site, another site says they're similar to the stock plug heat range. I changed plugs because I was experiencing a slight misfire post shift. Turns out my AFRs were dipping too low (stft goes to 0/open loop , n55/s55 thing) causing the stutter. Fine tuning the fuel scalar is pretty important as it resolves large deviations in actual AFR vs target in these open loop situations.
M302_imola878.50 Shoop40527.50 |
| 08-08-2021, 05:40 PM | #22 |
Rep 1,089
Curious to know why Wagner as well. Seems like both would have fitment issues without the clamp fix.
| Bookmarks |
