| 01-05-2022, 06:47 AM | #1 |
Rep 6
Drives: 2016 BMW X5M Donnington Gray
Brake Squeal - Where does it emanate from?
Hi All,
I have excessive brake squeal in my 2016 F85 X5M with 40K KMs (25K miles). I've replaced the discs/rotors and pads (EBC Yellow Stuff) with correct bed-in procedure and the brake squeal is getting worse. I've spent many hours researching the causes and solutions, of which there seem to be many aftermarket solutions that claim to eliminate the squeal. What I can't find is a definitive answer on, where does the squeal emanate from? My many years of mechanical knowledge suggests there is two possible/logical areas; A: Vibration between the disc/rotor and the friction material of the brake pad. B: Vibration between the brake pad backing plate and the caliper piston(s). There is aftermarket solutions for both possibilities; For A: BG Stop Squeal. Applied to the friction material of the brake pad and allowed to penetrate it thoroughly before reinstalling brake pads. https://www.bgprod.com/catalog/brakes/bg-stop-squeal/ For B: CRC Disc Brake Quiet. Applied to the brake pad backing plate and allowed to get tacky before reinstalling brake pads. https://www.crcindustries.com/produc...t-4-fl-oz.html There are many more solutions for possibility B from reputable manufacturers such as Brembo, Bendix, DynaGrip, Permatex, Würth etc. Interested on everyone's thoughts, knowledge and experiences in this area. Cheers, Chris.
Cheers,
Chris. ///M |
| 01-05-2022, 08:38 AM | #2 |
![]() ![]() 166
Rep 348
Brake squeal happens because of the material used in OEM brake pads. Powerstop pads and OEM Rotors are best combo for squeal free and low dust solution. I replaced oem pads with powerstops few months ago and no squeal whatsoever. Remember initial bite is about 90% compared to oems. I am very happy with them
Power Stop Z23-919B Rear $54.00 https://www.amazon.com/dp/B00O6PVEHS Power Stop Z23-1738 Front $116.00 https://www.amazon.com/dp/B086M7J4DV Hella Pagid 355251731 (2) $13.00 https://www.amazon.com/dp/B01IP984EG |
Longboarder3669.00 Slickrick2224.50 |
| 01-05-2022, 09:14 AM | #3 | |
![]() ![]() 202
Rep 363
2017 X5 ///M
2019 X3 XDrive 30i 2003 Porsche C4S |
sly1types505.50 |
| 01-05-2022, 11:24 AM | #4 |
![]() ![]() 166
Rep 348
| 01-05-2022, 09:22 PM | #5 |
Rep 1,529
I dono, have haven't seen many AMGs, RS or Porsches squeal like ours, it gets so bad like metal on metal.
And its not like our brakes are that good. The squeal is due to compound, and the dust that is on the rotors. If you do a couple of hard stops, it goes away. But then you are wearing away more of your rotors/ pad. |
| 01-06-2022, 01:48 AM | #6 | |
Rep 47
| 01-06-2022, 05:38 AM | #7 |
![]() ![]() 202
Rep 363
I don’t think my BIL’s GLE63 and my neighbor’s RS6 Avant squeal like the F85.
2017 X5 ///M
| 01-06-2022, 08:52 PM | #8 |
Rep 1,529
Exactly Mercedes, Audi, Porsche all managed to figure out how to stop thier cars without massive squeal.
I know people are running powerstop and are happy with 90% of the OEM initial bite, i'm not. I would gladly pay OEM pricing for the pads, if they give the same stopping power, just minus the squeal. And that BG stuff is not the answer, as another member has managed to wash it off whilst washing the car. |
| 01-09-2022, 03:24 PM | #9 | |
Rep 4
thank you. |
| 01-15-2022, 05:46 AM | #10 |
![]() ![]() 159
Rep 304
Drives: 2017 BMW X5M
We should have some sort of lawsuit against BMW for this problem… car is a lot of money to be driving around sounding like a bus when stopping.
4
| 01-16-2022, 04:39 AM | #11 |
![]() 127
Rep 183
Kinda look at this matter as par for the course. I rarely if ever stick with OEM pads for any vehicle. Aftermarket tends to have superior alternatives at a reasonable cost. Speaking of brake squeal, Porsche's PCCB on my GT4 hurts the ears when they get some use and brake dust accumulation.
| 03-05-2022, 01:37 PM | #12 |
![]() 96
Rep 96
Sometimes I press the brake pedal for about 3 seconds while maintaining throttle input. To "clean" the surfaces. Not a perm solution though. Not hard, just to engage. Someone lmk if this is anreally bad thing to do. Kinda like left foot braking on the track.
| 10-21-2024, 04:26 PM | #14 | |
![]() 506
Rep 1,073
Are you still liking them? Thanks Kevin
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
| 10-24-2024, 11:37 AM | #15 |
Rep 2,791
Drives: F85 X5M, F80 M3 ZCP
I can verify that compared to my F85 X5M, my W211 E63 AMG never squealed as loudly as the X5M. Although my AMG did squeal and very low speed 1-2 mph when lightly applying the brakes, but the X5M squealed like a stuck pig.
![]() Ever since I found carbon ceramic pads for the AMG, I have never looked back. Now I run them on all my vehicles including the F80 M3. Now that are many companies that manufacture these types of brake pads. And I couldn't tell you which is the best. But the Z26 pads from Power Stop work so well, that I would change them. Anytime, I purchase a vehicle one of the first thing I purchase is new pads and rotors for the future. So, I purchased Akebono carbon ceramics for the M3, for my next pad change, but that will not happen for a few years. And one the greatest things about carbon ceramics, are that there rotor friendly, meaning they don't wear out the rotor like semi metallic pads do.
| Bookmarks |
