05-30-2022, 09:01 PM | #1 |
Rep 1,444
(100%) OEM Muffler Mode + Custom CF Tips (DIY)
Hello guys,
I have done the Oem Muffler Mode + CF Tip installation. I can tell you this that Muffler looks 3K worth, Lookwise and soundwise. I will share the steps so you can also DIY . One of the hardest part of the project was removing the most awkward design tips. They are welded and Oe tips needs to be cutted. After that you have welding mess around which needs to be grinded. After that you can use band saw to cut within 5 min. What i found helpful is to use a zip tie to mark your cutting points. The points i marked are based on the inner diameter of my Tips. They are few mm more sticking out than oem tips but looks definitely larger than the oem tips. Opening the box pretty easy. Try to cut the top part closer to edges. Do not go all the way end otherwise you will be cutting the inner piece which is not advised. I cut from 3 point. If i would do it again i would cut from 4 corner and take the piece out so i wouldnt have to bend back and align again. As a note, Each perforated pipe double sided. One on the top, the other one on the bottom. Instead of cutting the both top and bottom of the muffler, i have done something better which i got the idea from someone on the forum but i dont know his handle so i cant tag him but i do know he has an X6m So what i did is, i cut the perforated part and reach at the bottom side. Then i welded proper size pieces there then welded another piece on the top part. After that i closed the box with my terrible welding skill, But hey it was my first time and it did the JOB! After all i painted the box in black with a little touch : https://youtube.com/shorts/v3ZrcxlOTZM?feature=share https://youtube.com/shorts/X6SdH5fIsHA?feature=share And After that it turned into this : https://youtube.com/shorts/Qlo5L_xqxDk?feature=share https://youtube.com/shorts/MmrPHMnFKl8?feature=share https://youtube.com/shorts/WYWhioksqtE?feature=share I do produce this Tips and they are specifically made for F85 X5M and F86 X6M. These are 1 of 1 in the market for 2 reason. 1- They have hidden upwards clamps which is not visible when you look under the vehicle. 2- They also have a slanted option just like Factory cut. And can be purchased here Final Results : Another OEM+ mode succesfully done. Enjoy!
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 05-31-2022 at 09:07 PM.. |
7
islandman22.50 daytonaviolet1256.00 Slickrick2214.00 Surgx573.50 christianfayb94.00 Blue By You639.00 GotV8?1070.00 |
05-30-2022, 11:14 PM | #3 |
Rep 1,444
Definitely looks super classy and sounds just as good as it looks. Worth every minute and penny i spent.
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
05-31-2022, 11:02 PM | #4 |
271
Rep 354
I did exactly the same thing, including the tips, on my 2016. I liked it better than a number of aftermarket ones I've heard. I like it better than the Dinan I have on my 2017..
The one thing that I think makes these cars sound better is an X-pipe. I welded an x-pipe in both of mine. It's well worth doing.
2019 M5 COMP. DGM, Individual Caramel full leather, Dinantronics tuned, MAD Downpipes, More to come.
Owner, Designer, Tuner- A&A Corvette Superchargers WWW.AACORVETTE.COM |
06-01-2022, 01:09 AM | #5 | |
Rep 1,444
06-01-2022, 09:15 AM | #6 |
271
Rep 354
None. It has a smoother, more exotic sound. It also takes a little bit of raspiness off it.
I'm thinking about taking my Dinan off and opening it up to do something similar. I also just did the same thing on my C8 Corvette. I added similar CF tips as well. I do it all the time on C6 Z06 Corvettes at my shop. Actually, the x-pipe I used came off my C7 Z06. It lines up perfectly.
SaNGRia1159.00 |
06-01-2022, 12:27 PM | #7 |
Rep 1,241
Looks and sounds great!
I wish I had someone local who could do all of this for me. Minus the exhaust mod, I might have my muffler/pipes and bumper heat shields painted black (maybe with the M logo like you did) so that the aluminum look is minimized. |
SaNGRia1159.00 |
06-01-2022, 04:36 PM | #8 | |
Rep 1,444
M logo looks super classy not like ratchet. I strongly suggest you to do it. I used a small caliper sticker which was bigger than my OEM caliper logo and was laying around. Good thing was each piece of that logo was precut. What i did is i placed each strap with a distance so after painted it will show each stripe properly.
06-01-2022, 04:38 PM | #9 | |
Rep 1,444
06-01-2022, 09:06 PM | #10 | |
Rep 27
06-02-2022, 01:05 AM | #11 | |
Rep 1,444
88bimmer19.50 |
06-02-2022, 03:23 PM | #12 | ||
Rep 27
06-02-2022, 07:42 PM | #13 |
Rep 1,444
06-03-2022, 12:50 PM | #15 |
Rep 1,444
Yes, you cut from the tip of the muffler pipe. Flap function way behind this. You can see in the picture where the actuators located actually.
