| 11-08-2022, 11:34 AM | #1 |
Rep 8,181
Drives: F90 M5 / F15 50i / X7 M50i
I'll link a couple videos I used but couldn't find anything worth my time on the forum. Plus I'll link the codes I got to start this. Basically HPFP, MAF #2, and cylinder 5 misfire. Didn't want to deal with injectors and I know there is a 10/120 extended warranty on them anyway so figured I'd start with the pumps. Then if needed the MAF and if still an issue let dealer tackle the injector.
There will also be some differences depending on what year you have. I am 2014 March build. So the HPFP had a new magneto and plug type which required splicing the wiring. Ordered all from FCP Euro and thanks to them for all the parts I needed based on their system recommendations 2x Bosch HPFP 13518604232 2x camshaft followers 11327601233 4x T30 bolts 13517632572 2x wire harness 12518638006 2x rubber gaskets 11127588416 Tools: Small pry tool 5mm hex 17mm wrench T30 Video I followed:
'07 Yamaha R1 (sold)/'05 C230k (sold)/
'06 C55 AMG (sold)/'14 X5 50i (Dad’s now) '20 M5 '21 X7 M50i DSE (Wife's) |
| 11-08-2022, 12:13 PM | #2 |
Rep 8,181
1) remove rear engine bay cover. Just pulls up and out
2) you will both pumps readily available on either side just behind both intake tubes. 3) disconnect oxygen sensors from Clip and if needed you can completely disconnect them and push to the side. I broke this clip on both sides. Lol so I zip tied them after. 4) use 5mm hex to unscrew both bolts on either side or pump. Try not to drop them. You won't reuse these. New bolts have thread sealant to prevent oil from seeping out and you will see some on threads. 5) use 17mm wrench to loosen both hard fuel lines. I just broke them loose and used my hand to further loosen until I could let them slide down the pipe away from the pump. Put rag or paper towels under tips as fuel will drip. 6) on driver side there is an additional flex fuel line with a yellow pressure ring that I used a pry tool to compress and then pulled off. Place tag or paper towels here and fuel will drip. 7) if you are like me and have to install new wire harnesses for new plug type then just use a pair of snips and cut the plug wires as close to the plug as possible. If not proceed to step 8. The wires were not very long and I wanted as much play as possible to crimp the new wires at the end. Don't toss them away yet as you need to know what color wire goes to which side of the plug. Either a 1 or 2 will be indicated on plug and this must correlate to new plug wires labeled 1 and 2. DONT just assume that same color scheme on wires means they attach together. For my passenger side the colors were literally opposite. Green and white was in plug 2 on original and plug 1 on new plug. Stupid. 8) carefully use a 90deg pick and release gray lock and then on the bottom of the plug slip in the pick and apply outward pressure and either tug slightly on wires or try and apply pressure with pick off plug. This was tough and I ended up breaking it. Good thing I didn't need it in the end. 9) attempt to remove the pumps. This was really tricky on the driver side for me. You are gonna have to be patient and use a pry tool apply pressure on the rigid fuel lines to get them out of the pump so you can lift it out. Took me some time. Had to use one hand to pry the line slightly and another to twist and pull on the pump. The drive side forward line gave me the most trouble. The passenger side aft line was the trouble there. Eventually once you can get them popped out of the pump the pump should pull straight out. 10) remove gasket and camshaft roller with a pick. Install new ones. Apply some oil on gasket like an oil filter. 11) install new pumps. Use that patience and pry tool to get the line tips to pop back into the new pump. Then gently thread on hard lines. Don't make full tight. 12) screw in T30s until secure. I hand tightened everything but the T30s take 15nm if I recall. Don't quote me. 13) hand tighten fuel lines. 14) reinsert plug. 15) if you are installing new plug and harness then before installing cut the new harness down to maybe 6". Up to you and what you're comfortable working with. I used some waterproof heat shrink style red butt connectors. Believe the wires are 18gauge. Installed on the new wire harness first. Then before connecting wires check to see which color wire goes to the 1 and 2 pug. Once you determine this then you can crimp oem wire harness into the butt connector. I doubled up the heat shrink with a big one that goes over both butt connectors and the oem wire loom plastic. I heated the butt connectors first then slid the shrink wrap over it all then heated that. 16) plug in new connectors. Reattach the flex fuel line with yellow locking ring tab on driver side. Reinstall oxygen sensors on both sides and if you didn't break the clips. Reclip or zip tie. Install engine bay cover. 17) clear codes with your preference of coder. 18) start it up and go for a ride. I couldn't erase all error codes. So it requires me to turn the car off and let it sit over night and this morning the CEL was gone.
5
| 11-08-2022, 12:36 PM | #3 |
Rep 8,181
Photos
bimmer_believer0.00 dimaka_77231.50 |
| 05-01-2023, 12:39 PM | #4 |
Rep 2,777
Drives: e92 + g05
Posting to say thanks for the DIY. 3/15 build
Proved to be very helpful after getting 11A002 codes for High Pressure Fuel - pressure too low, and multiple misfires. Ordered everything except the harnesses. Once installed, codes are gone and running smoothly. Took about two hours for me going slowly and including an air filter swap. Side note, the markup is crazy on the OEM BMW vs Bosch. $1075.99 vs $137.99! |
Maverik2594751.50 |
| 05-01-2023, 03:24 PM | #5 | |
Rep 8,181
zero2sixtyZ1113.50 |
| 04-09-2024, 02:38 AM | #6 | |
Rep 3
| 04-09-2024, 08:37 AM | #7 |
Rep 2,777
Drives: e92 + g05
| 04-22-2024, 07:15 PM | #9 |
Rep 8,181
| 08-15-2024, 04:50 PM | #10 |
Rep 6
Great Write up!!!
Truly appreciate the time you put into this write up! I'm ordering parts soon for my car. I have a 2013 Alpina B7 (Basically 750i). How would I know if I need to purchase the updated harness connectors or not? Thanks in advance
| 08-20-2024, 03:55 PM | #11 |
Rep 8,181
You do based on your year.
| 08-21-2024, 09:19 PM | #13 |
Rep 6
Changed out pumps, lifters, gaskets, new pigtails (was able to source them locally today, and pick them up from ECS tuning) and air filters. Was way more complicated to change out on the Alpina than in this video, but I was able to get it done in 5 hrs. dealing with the complexity of the turbo intakes. Thanks again for this post it was the motivation i needed to tackle it myself!
Maverik2594751.50 |
| 08-22-2024, 12:02 AM | #14 | |
Rep 8,181
Dealer wanted to charge me 20hrs and $5500
| 08-22-2024, 05:37 AM | #15 |
Rep 6
I should have worded it as O-ring seals for the pumps. Sorry for the confusion. I just followed your list of parts, cam followers for the pumps,etc. Plus, air filters, I wish I would have changed the plugs and coils while in there, but I'll put that on the spring 25' to do list.
| 08-23-2024, 10:17 PM | #16 | |
Rep 8,181
| 08-25-2024, 08:36 PM | #17 |
![]() 9
Rep 59
I am having multiple misfire issues, new plugs and coils didnt resolve anything. I am wondering if the HPFP or injectors are to blame. I have a bunch of misfire codes but zero fuel codes.
basically if I accelerate hard it will go into DM mode... if I just drive normally it won't. |
| 08-28-2024, 09:29 PM | #18 | |
Rep 8,181
| 08-29-2024, 10:43 AM | #19 | |
![]() 9
Rep 59
the reason I believe it might be is when I accelerate hard thats when it shuts down and goes to DM. just normal light driving it won't do it. |
| 06-20-2025, 04:13 PM | #20 |
Rep 2
This post has been super-helpful! Full of confidence after reading this, I replaced one of my HPFPs yesterday. But in my rush, I forgot to check the plug... :-( Have now bought the wiring harness (why didn't anyone design an adapter instead??) and will attempt splicing this weekend. Will it be obvious which wire goes where? Or does anyone have pics of their surgery you can share? Is it simply hot and ground or more complicated?
| 06-20-2025, 05:01 PM | #21 |
Cattlecar
226
Rep 366
Power and ground. Not polarity sensitive but you can note positions of the two wire color relative to the latch tab and put them back as found.
| 06-21-2025, 04:18 AM | #22 | |
Rep 8,181
| Bookmarks |
