| 12-01-2022, 12:33 AM | #1 |
![]() 24
Rep 88
Fuel pump control unit
Hey guys can anyone please share with me the location of the fuel pump control unit on a 2018 f85 would appreciate some pictures thanks !
| 12-03-2022, 12:27 AM | #3 |
Cattlecar
226
Rep 370
If you are looking for the electric fuel pump control, it is under the back seat. You pull up on front of seat bottom on both sides 2-3 inches in from sides to release the cushion. The back edfe of cushion is tucked under the seatbacks and I think one of the seatbelt latches may have to be fed through the seat bottom upholstery hole. The area under seat has a foam insert you remove by undoing the 4 bolts/screws that hold the braces and the module is on left side secured to floor next to the fuel pump access port. The power supply module for engine management system is at rear passenger bulkhead under the cabin air filter housing. I'm not sure the fuel pump feed is from there or from the electrical stuff beside/behind glove box. I don't have any pictures, sorry.
| 06-04-2023, 08:58 PM | #5 |
Rep 1
X5 F15 3rd Row 7-seater fuel pump control module location?
My X5 stalls within a few minutes after exiting to local from driving on a freeway for more than 30-45 minutes. I did some research and it seems others with a similar problem may end up replacing the fuel pump control module. I have difficulty finding the location of the fuel pump control module for my X5 which has 3 rows of seats. Does anyone know?? Any pointer is greatly appreciated! Thank you!
| 06-05-2023, 10:01 AM | #6 | |
Rep 9,825
See A98 in illustration below: (appears to be located below the rear seat (1st row)) Functional description
![]() Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 06-05-2023 at 10:08 AM.. |
| 10-15-2024, 07:53 PM | #7 | |
Rep 1
Hi mosrock I am having a similar issue with my x6. It will stall out at highway speeds especially on hotter days and I will have to wait a few minutes until the fuel pump kicks on again. Did replacing the fuel pump control module fix your issue or was it something else? |
| Bookmarks |
