01-15-2009, 12:36 AM | #1 |
Rep 2,091
HELP: ran into issues with spring install
Alright so I am super frustrated. Have been working on installing springs for like 7 hours now. Got the fronts done in about 3 hrs working by myself, and I figure the rear would be even easier given there is no need to compress the springs. I followed the following DIY:
http://www.m3post.com/forums/showthread.php?t=183011 In the rear I loosened the two bolts circled to undo the strut and also the lower knuckle of the rear brake disk. So far so good, put the H&R spring in, and here is where I ran into problems and have spent the past THREE hours struggling with. I can't get the fcuking lower control arm and the hole in the lower knuckle to align. I have tried using the jacklift (even used two of them) and the damn holes just do not align anywhere in the jacking arcs. Suggestions would be wonderful as I need to get this done tomorrow morning as I have to drive back to Seattle tomorrow evening. Should I undo anything else in an attempt to get the holes to align (perhaps the sway bar)? Please help!
2012 Audi R8 V10TT| 6MT| Suzuka Grey
2015 Ferrari 458 Speciale| Rosso Scuderia 2020 BMW X7| Mineral White 2024 718 GT4 RS | Arctic Grey |
01-15-2009, 02:46 AM | #2 | |
Rep 1,973
MDCT ... so you can drive and eat a hamburger at the same time. |
01-15-2009, 03:21 PM | #4 |
Rep 2,091
Alright got the car back together. Basically needed some food in my stomach, a good night's rest, and had a buddy come help me in the morning to try and align everything up. Let's just say that having an extra set of hands is HIGHLY recommended for this install. Would have been done altogether yesterday if I had help to just get a few steps done!
01-15-2009, 10:47 PM | #7 | |
Commander-In-Chief
2122
Rep 8,924
Drives: 2023 M2 Coupe, 2020 GLE 450
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
01-16-2009, 10:58 AM | #8 |
Rep 2,091
Honestly Greg with an extra set of hands the install will take much less. I spent a total of around 4 hours doing the front including the time it took to compress and decompress both sets of springs and the time it took to raise/lower the car. The rear is only a two hour job as long as you have someone to lend a hand for 15 min to align the holes in the lower control arm to the lower spindle/knuckle of the brake disc. So total time is about 6 hours with only hand tools and no lift. If I had a lift and air tools like most shops, this is honestly a 4-5 hr job at the very most. I bet the second time around I can probably do it in 4 hrs with my hand tools and no lift. SO my opinion is that it is a bit time consuming, but all in all I enjoy working on cars and learn things about them in the process. Time well spent imho and you also can pocket that 8.9 hrs of labor the shops charge (around $95-100 per hr here in Seattle plus tax)!
