      01-13-2008, 12:43 AM   #1
Redline
Drives:
6piston brake on 135i only?
Does not the M5 , M6, or even M3 have 6 piston?
AlpineWhite (deciding)
Black Leatherette (for sure)
Glaciersilver or Highglossblack trim
Sport Package
Active Steering
Manual Transmission
:roundel:
      01-13-2008, 01:38 AM   #2
grant
grant's Avatar
Drives: 1973 Porsche 911
No, the 135i is the only one. May be the start of a new trend (hopefully).
1973 Porsche Carrera RS 2.7 Carbon Fiber (240hp & 1,890 lbs)
      01-13-2008, 04:25 PM   #3
Advevo
581
Drives: M2 Competition, E30 M3 DTM
6 pots brakes are just fantasic. Put in a set of race pads and you can race with them.
      01-13-2008, 04:30 PM   #4
Brandon26pdx
Drives: 2011 135i
They're made by Brembo, so possibly this is the first example of collaboration between the two companies. Ive heard they will make the Brembo 6-piston kit available for the 3-series guys too.
      01-13-2008, 04:34 PM   #5
josh
Drives: E36 M3, 135i
Could someone explain to us newbies what is the advantage of 6-piston calipers over lesser ones? Is it more fade resistance, better 'feel', better heat dissipation, or somesuch?
It seems most disk calipers can clamp on hard enough to lock the wheel, so it can't be 'pure stopping power'.
      01-13-2008, 04:53 PM   #6
Ryephile
Not a Newbie
Drives:
The big advantage is the caliper is fixed to the knuckle, not floating like all over Bimmer brake calipers. This offers a fantastic firm pedal with excellent feel; superior feel to a floating caliper. They're also lighter!
[SIGPIC][/SIGPIC]
      01-13-2008, 05:07 PM   #7
grant
grant's Avatar
I'm still not convinced that there is enough rotor for hard track use (but I love 6-piston calipers).
      01-13-2008, 05:22 PM   #8
Ryephile
Not a Newbie
Drives:
The rotor is 338x26mm, which is probably fine for HPDE's where you're doing 20 minute sessions. It will probably be a while before someone releases a decent brake pad that will last that long though!
[SIGPIC][/SIGPIC]
      01-13-2008, 05:23 PM   #9
aus
Drives: Odysse
Most BMW's up till now had a single piston floating caliper. When you step on the brakes, the piston presses against the rotor and the other side is essentiall pulled towards the rotor. With the fixed caliper, there are pistons on both sides, so the caliper doesn't slide.
As for any real advantage of 2 pistons vs. 8 piston's, it doesn't really matter. It really depends on the piston surface area. The main advantage of a big brake kit, is better heat handling and dissipation.
      01-14-2008, 06:04 PM   #10
Advevo
581
i race with a bmw 130i cup we use 4 piston brembo calipers on original 330mm discs with carbon metallic 01 compound pads no problem discs last 4 race weekends.
135i discs are even bigger. Just use good race pads on track.
      01-15-2008, 03:32 AM   #11
SA135i
14
Drives:
Hey Advevo, I see you still list yourself as driving a 130i. When are you getting into your 135i?
"But don't be surprised if you completely forget about your passengers when driving this car. You will be mesmerised by the feel of the fat, well-weighted steering wheel in your hands, the sound from the specially tuned exhaust, and the in-gear acceleration that will have you grinning like a loon...." TopCar magazine (SA)
      01-15-2008, 04:26 AM   #12
Advevo
581
I still have my 130i 3 doors next to my 135i the wifey drives de 130i. Tommorow my registration for the 135i will be there. So one more day and then drive.
      01-15-2008, 04:36 AM   #13
SA135i
14
Drives:
You must be so excited .
I really don't know how you held out for so long, knowing that the car was there, seeing it, sitting in it but not driving it. I know I would not have been able to hold out for 3 weeks as you have, but then again you did get to go on an extended test drive. Me, I have to rely on feedback over the net and look at pictures as there are no 1er coupes here to even look at nevermind drive.
      01-15-2008, 06:42 AM   #14
PrematureApex
Drives: N55 X1, N54 135, s54 m3
Not really. Did you see the width of the rotors? Not as much capacity as one would first think...
I think its going to take a serious pad on there to withstand hard lapping. Even then, rotor or pad life won't be the same a with a BBK of that diameter, but with a wider rotor.
Not complaining, but these aren't quite the brakes they appear to be at first glance.
      01-15-2008, 11:08 AM   #15
ShifterKart
ShifterKart's Avatar
Drives: 2011 MR/BB E92 M3
As been stated the real advantage is in having fixed calipers and not floating calipers. This can be achieved without 6 pistons and has been done for a long time with 4. Besides for the "cool" factor, the only advantage to 6 pots is more even distribution of the brake force to the pad leading to more even pad wear.
If the brakes can lock up the tries they are adequate for the vehicle. As long as they remain fade free.
      01-15-2008, 02:51 PM   #16
ZAMIRZ
Drives:
Another advantage of ditching the floating caliper is no more uneven pad wear! Hooray. I'm so sick and tired of replacing the front brake pads on my MINI. Outer pad is at 70% or more, while the inner pad is closer to 30.
      01-15-2008, 03:04 PM   #17
SlickShift
SlickShift's Avatar
323
Drives: '11 BMW E90 M3 ZCP, '21 X5 ZMP
Apparently BMW is only putting the 6-piston calipers on the 135i because of fitting issues with the single caliper floating system.
-Nick
2018 BMW 440i - M Sport, Exec
Glacier Silver Metallic/Coral Red Dakota
Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i
      01-15-2008, 03:31 PM   #18
PrematureApex
Why aren't you pulling off the useless tab and swapping sides? You should be able to get a full life cycle out of them doing this.
      01-15-2008, 03:41 PM   #19
ZAMIRZ
Drives:
It's so cheap to just buy new pads rather than swapping tabs and putting them back in place, that I just switch them out to all new stuff. It's not the money, it's just the wastefulness and the hassle of changing them out.
      01-15-2008, 04:10 PM   #20
AwesomeBMW
Freude am Fahren
17
Drives:
oh well. Their engineering problem is our gain
"Oversteer is best because you don't see the tree that kills you" -- Richard Hammond
      01-16-2008, 12:26 AM   #21
aus
Drives: Odysse
What fitting issues?
And BMW has signed a deal with Brembo for future brakes, so we may be seeing more fixed caliper, multi-piston calipers in the future.
      01-19-2008, 05:38 PM   #22
crzy4135i
crzy4135i's Avatar
Drives: 08 135i
They need to do something.. There are many other cars that have 6 piston brakes fitted from the factory.
1addicts
